Текущее время: Ср ноя 11, 2026 19:12
СообщениеДобавлено: Ср апр 03, 2013 07:19
Добрый день!
Организовал туннель между DI-804HV и DI-824VUP+. Оба находятся за NAT
Какое-то время он работает, затем перестаёт. Помогает только перезагрузка маршрутизаторов.
После обрыва туннеля маршрутизаторы пишут логи:
Время на маршрутизаторах немного расходится...
[b]DI-804HV[/b]
Wednesday April 03, 2013 08:46:27 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:46:47 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:46:48 Send IKE (INFO) : delete wan_IP_DI-804HV -> ext_NAT_IP_DI-824VUP+ phase 1
Wednesday April 03, 2013 08:46:48 IKE phase1 (ISAKMP SA) remove : wan_IP_DI-804HV <-> ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:46:48 Send IKE M1(INIT) : wan_IP_DI-804HV --> ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:46:53 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:46:58 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:08 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:18 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:38 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:39 Send IKE (INFO) : delete wan_IP_DI-804HV -> ext_NAT_IP_DI-824VUP+ phase 1
Wednesday April 03, 2013 08:47:39 IKE phase1 (ISAKMP SA) remove : wan_IP_DI-804HV <-> ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:39 Send IKE M1(INIT) : wan_IP_DI-804HV --> ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:44 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:49 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:47:59 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:48:09 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:48:29 IKED re-TX : INIT to ext_NAT_IP_DI-824VUP+
Wednesday April 03, 2013 08:48:30 Send IKE (INFO) : delete wan_IP_DI-804HV -> ext_NAT_IP_DI-824VUP+ phase 1
Wednesday April 03, 2013 08:48:30 IKE phase1 (ISAKMP SA) remove : wan_IP_DI-804HV <-> ext_NAT_IP_DI-824VUP+
[b]DI-824VUP+[/b]
Wednesday April 03, 2013 08:38:03 Receive IKE M1(INIT) : ext_NAT_IP_DI-804HV --> wan_IP_DI-824VUP+
Wednesday April 03, 2013 08:38:03 Try to match with ENC:DES AUTH:PSK HASH:SHA1 Group:Group1
Wednesday April 03, 2013 08:38:03 Send IKE M2(RESP) : wan_IP_DI-824VUP+ --> ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:04 Receive IKE INFO : ext_NAT_IP_DI-804HV --> wan_IP_DI-824VUP+
Wednesday April 03, 2013 08:38:04 Receive IKE M1(INIT) : ext_NAT_IP_DI-804HV --> wan_IP_DI-824VUP+
Wednesday April 03, 2013 08:38:04 Try to match with ENC:DES AUTH:PSK HASH:SHA1 Group:Group1
Wednesday April 03, 2013 08:38:04 Send IKE M2(RESP) : wan_IP_DI-824VUP+ --> ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:05 IKED re-TX : RESP to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:06 Send IKE (INFO) : delete wan_IP_DI-824VUP+ -> ext_NAT_IP_DI-804HV phase 1
Wednesday April 03, 2013 08:38:06 IKE phase1 (ISAKMP SA) remove : wan_IP_DI-824VUP+ <-> ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:09 IKED re-TX : RESP to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:09 receiving a re-Tx MM msg, response the last msg
Wednesday April 03, 2013 08:38:09 IKED re-TX : MM to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:14 IKED re-TX : RESP to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:14 receiving a re-Tx MM msg, response the last msg
Wednesday April 03, 2013 08:38:14 IKED re-TX : MM to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:23 receiving a re-Tx MM msg, response the last msg
Wednesday April 03, 2013 08:38:23 IKED re-TX : MM to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:24 IKED re-TX : RESP to ext_NAT_IP_DI-804HV
Wednesday April 03, 2013 08:38:33 receiving a re-Tx MM msg, response the last msg
В чем может быть причина?
СообщениеДобавлено: Чт апр 04, 2013 05:49
Неужели ни у кого нет никаких мыслей?)
СообщениеДобавлено: Чт апр 04, 2013 20:26
Неужели всем нечего сказать. Помогите хотя бы понять что значат логи...
СообщениеДобавлено: Пт апр 05, 2013 05:51
Заметил, что VPN-канал восстанавливается только после перезагрузки обоих роутеров, перезагрузка любого из них в отдельности не помогает...
СообщениеДобавлено: Пт апр 05, 2013 07:43
http://dlink.ru/ru/faq/92/508.html
СообщениеДобавлено: Сб апр 06, 2013 06:33
Спасибо за ответ!
DI-824VUP+ являлется у меня шлюзом для подсети 192.168.1.0/255.255.255.0, его IP адрес 192.168.1.1
DI-804HV является шлюзом для подсети 192.168.2.0/255.255.255.0, его IP адрес 192.168.2.1
В полях Keep-alive изначально я прописывал 192.168.2.1 и 192.168.1.1 для DI-824VUP+ и DI-804HV соответственно.
Логи свидетельствуют именно о возникновении объясняемой по ссылке проблемы?
Если да, то почему не работает механизм keep-alive, если нет - то о чем свидетельствуют логи?
