Текущее время: Пн ноя 09, 2026 09:18
 Заголовок сообщения: DAP-2690 [SYSACT] AP warm start
СообщениеДобавлено: Пт мар 29, 2013 16:56
Прошивка 1.15 17:49:33 09/03/2012
На одной из 2-х таких точек вдруг начались обрывы. в логах
Mar 29 10:51:02 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:07:59 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:30:13 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:32:15 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:35:13 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:39:15 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:51:51 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 11:58:54 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:00:49 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:02:47 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:15:50 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:21:12 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:23:53 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:26:30 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:27:30 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:29:16 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:30:17 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:31:18 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:32:18 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:33:38 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:35:00 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:38:14 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:43:53 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:44:44 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:50:44 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 12:55:56 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 13:01:43 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 13:06:14 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 13:08:14 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 13:14:17 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 14:07:09 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 14:08:11 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 14:09:21 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 14:10:17 bm-5221.ap.local [SYSACT] AP warm start
Mar 29 14:11:18 bm-5221.ap.local [SYSACT] AP warm start
Что это ? Есть более свежая версия прошивки ?
До этого такие ребуты были раз в несколько дней
 Заголовок сообщения: Re: DAP-2690 [SYSACT] AP warm start
СообщениеДобавлено: Пт мар 29, 2013 17:28
Добрый день,
Если есть возможность, поменяйте точки местами (вместе с адаптерами питания, если они используются).
AP warm start - перезагрузка ОС точки без отключения питания
AP cold start - перезагрузка точки с отключением питания (при подаче питания запускается загрузчик, потом ОС и применение конфига)
Если это проблема именно точки, а не окружения, то обратитесь в наш сервисный центр (http://www.dlink.ru/ru/contacts/)
СообщениеДобавлено: Пт мар 29, 2013 23:19
Есть возможность сделать логи более подробными ?
Есть смысл подключить консоль и на ней мониторить сообщения ?
Есть большое подозрение, что это результат атаки на точку или неадекватная реакция на происходящее в эфире.
35 ребутов за 3 часа. Наиболее часто к точку подключались следующие МАС-и
Число_подключений МАС
    17 10:F9:6F:CF:98:EA
    17 1C:4B:D6:B6:59:C6
    17 B8:F9:34:7D:B2:05
    19 00:C6:10:AE:C9:ED
    19 0C:74:C2:67:41:EA
    19 D4:20:6D:CC:7A:BE
    23 88:30:8A:E8:DE:5D
    23 98:03:D8:E8:FE:D0
    23 CC:FE:3C:35:91:4C
    29 98:52:B1:94:25:74
    30 00:23:15:30:F8:18
    30 18:87:96:A2:20:97
    31 7C:61:93:E8:D7:04
    36 18:87:96:89:1D:9A
    61 60:21:C0:AC:65:68
СообщениеДобавлено: Пн апр 01, 2013 18:42
За субботу - 4 warm start за промежуток 14:16:22 - 14:19:34.
сегодня - 0 рестартов
Придется заменить их на DAP-2360, там прошивка вроде стабильно работает. А если еще баг с dhcp исправят, то станет реальной заменой DWL-3200AP.
Биться несколько месяцев за новую прошивку нет никакого желанья, как и покупать беспроводную продукцию вашей фирмы.
СообщениеДобавлено: Пт апр 26, 2013 12:14
Сегодня опять начались ребуты. Вот консольный лог.
Падает ядро в атеросовском драйвере.
Пока D-Link использует проприетарные драйвера для atheros - не будет стабильной работы!
DAP-2690.log.gz [46.6 KiB]
СообщениеДобавлено: Пт май 17, 2013 16:14
Новая прошивка с исправлением указанной ошибки появиться ? Или ревизию A1 похоронили ?
