Текущее время: Чт окт 01, 2026 04:01
СообщениеДобавлено: Чт янв 31, 2013 05:36
Добрый день!
Стенд: 3200-10 С1 из коробки, модуль SFP DEM-330T V.B1, патчкорд, конвертор оптический, ПК с tftp. Подключаю коммутатор 10м портом через конвертор к ПК. Дальше что делал отражено в логе:
Boot Procedure V4.00.002
Power On Self Test ........................................ 100 %
MAC Address : 90-94-E4-41-5F-D0
H/W Version : C1
Please Wait, Loading V4.02.004 Runtime Image .............. 100 %
UART init ................................................. 100 %
Starting runtime image
Device Discovery .......................................... 100 %
Configuration init ........................................ 100 %
DES-3200-10 Fast Ethernet Switch
Command Line Interface
Firmware: Build 4.02.004
Copyright(C) 2012 D-Link Corporation. All rights reserved.
UserName:
PassWord:
DES-3200-10:admin#
DES-3200-10:admin#download firmware_fromTFTP 10.90.90.100 src_file DES3200R_4.34
.B007.had
Command: download firmware_fromTFTP 10.90.90.100 src_file DES3200R_4.34.B007.had
Connecting to server...................
TFTP Establish session fail!
Fail!
DES-3200-10:admin#sh ports 10 desc
Command: show ports 10 description
Port State/ Settings Connection Address
MDIX Speed/Duplex/FlowCtrl Speed/Duplex/FlowCtrl Learning
10 Enabled Auto/Disabled Link Down Enabled
Auto
Description:
DES-3200-10:admin#conf ports 10 speed 100_f
Command: config ports 10 speed 100_full
Success.
10 Enabled 100M/Full/Disabled 100M/Full/None Enabled
Auto
Description:
DES-3200-10:admin#download firmware_fromTFTP 10.90.90.100 src_file DES3200R_4.34.B007.had
Connecting to server................... Done.
Download firmware...................... Done. Do not power off!
Please wait, programming flash......... Done.
Success.
DES-3200-10:admin#save
Command: save
Saving all configurations to NV-RAM.......... Done.
DES-3200-10:admin#reboot f
Command: reboot force_agree
Please wait, the switch is rebooting...
H/W Version : C1
Please Wait, Loading V4.34.B007 Runtime Image ............. 100 %
Firmware: Build 4.34.B007
UserName:
PassWord:
DES-3200-10:admin#
DES-3200-10:admin#
Description:
Данное поведение выявил, когда пытался отловить баг на стенде. Баг который пытался поймать не смог обнаружить, нашел другой. Изыскания по своей проблеме продолжу, завтра запланировал выезд на узел, а пока описываю вот эту проблему. Проверьте у себя на стенде.
СообщениеДобавлено: Чт янв 31, 2013 09:08
А конвертер какой?
СообщениеДобавлено: Чт янв 31, 2013 09:15
rubytech FE-C120S3.S20.
СообщениеДобавлено: Чт янв 31, 2013 09:43
Вопросы к конвертеру.
Схема DES-3200 C1 + DEM-330R и DMC-920T работает и на автоопределении.
СообщениеДобавлено: Чт янв 31, 2013 10:03
Так оно работает. Повторит точь в точь, что я сделал. Если после этого опять выставить скорость и сохраниться и перезагрузиться, то настройка останется.
СообщениеДобавлено: Чт янв 31, 2013 12:02
Не стал создавать отдельную ветку, думаю проблема имеет общие корни с данной.
По сути проблемы:
Есть свитч DES3200-28F rev. C прошивка DES3200R_4.34.B004.had после установки, примерно, через сутки свитч с загрузкой 100% был отправлен в перезагрузку, т.к. не было видимых причин, для подобной загрузки, кол-во broadcast/multicast все было в норме, loopbackdetect не отрабатывал, stp не включено.
После перезагрузки не поднялся ни один из 23 портов под (SFP 100Мбит/с) , по индикации все были down, при этом mac-address`а с портов приходили и пакеты бегали в обе стороны, порты были настроены в autonegotiation.
Сделали downgrade прошивки до DES3200R_4.33.B008.had, ситуация не изменилась.
В итоге порты были переведены в 100_full жестко. Интерфейсы по индикации ожили.
Но начали увеличиваться счетчики:
DES3200-28F:admin#show error ports 7
Command: show error ports 7
Port Number : 7
RX Frames TX Frames
CRC Error 0 Excessive Deferral 3076
Undersize 0 CRC Error 0
Oversize 0 Late Collision 0
Fragment 0 Excessive Collision 0
Jabber 0 Single Collision 0
Drop Pkts 504 Collision 0
Symbol Error 0
не нравится кол-во "Excessive Deferral 3076".
SFP пр-во китай, встречные конвертеры Planet.
Нет причин грешить на конвертеры и SFP, на других узлах с ними же стоят DES-3200-28F rev. A. Таких проблем не встречалось.
СообщениеДобавлено: Пн апр 22, 2013 14:20
Maxim N. Begovatkin
Ошибка исправлена в последней прошивке, можете обновляться.
СообщениеДобавлено: Пн июн 17, 2013 18:55
Добрый день. Та же самая проблема с версией С. Можете выслать прошивку или указать где её взять?
СообщениеДобавлено: Вт июн 18, 2013 08:20
viewtopic.php?f=2&t=92700
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 139
