Текущее время: Чт сен 03, 2026 01:51
 Заголовок сообщения: Re: DFL-800 и PPPoE
СообщениеДобавлено: Пт дек 21, 2012 18:18
можите показать сниф инвайта ?!
можно в личку
СообщениеДобавлено: Сб дек 22, 2012 18:14
Internet Protocol Version 4, Src: 169.254.172.198 (169.254.172.198), Dst: 88.200.176.4 (88.200.176.4)
    Version: 4
    Header length: 20 bytes
    Differentiated Services Field: 0xa0 (DSCP 0x28: Class Selector 5; ECN: 0x00: Not-ECT (Not ECN-Capable Transport))
        1010 00.. = Differentiated Services Codepoint: Class Selector 5 (0x28)
        .... ..00 = Explicit Congestion Notification: Not-ECT (Not ECN-Capable Transport) (0x00)
    Total Length: 535
    Identification: 0x5234 (21044)
    Flags: 0x00
        0... .... = Reserved bit: Not set
        .0.. .... = Don't fragment: Not set
        ..0. .... = More fragments: Not set
    Fragment offset: 0
    Time to live: 126
    Protocol: UDP (17)
    Header checksum: 0x8870 [correct]
        [Good: True]
        [Bad: False]
    Source: 169.254.172.198 (169.254.172.198)
    Destination: 88.200.176.4 (88.200.176.4)
User Datagram Protocol, Src Port: 10711 (10711), Dst Port: 5060 (5060)
    Source port: 10711 (10711)
    Destination port: 5060 (5060)
    Length: 515
    Checksum: 0x40ab [validation disabled]
        [Good Checksum: False]
        [Bad Checksum: False]
Session Initiation Protocol
    Request-Line: REGISTER sip:88.200.176.4 SIP/2.0
        Method: REGISTER
        Request-URI: sip:88.200.176.4
            Request-URI Host Part: 88.200.176.4
        [Resent Packet: True]
        [Suspected resend of frame: 1]
    Message Header
        From: <sip:78482xxxxxx@192.168.50.17>;tag=40d3f590-f32a8c0-13c4-55013-1813a-4611dd04-1813a
            SIP from address: sip:78482xxxxxx@192.168.50.17
                SIP from address User Part: 78482xxxxxx
                SIP from address Host Part: 192.168.50.17
            SIP tag: 40d3f590-f32a8c0-13c4-55013-1813a-4611dd04-1813a
        To: <sip:78482xxxxxx@192.168.50.17>
            SIP to address: sip:78482xxxxxx@192.168.50.17
                SIP to address User Part: 78482xxxxxx
                SIP to address Host Part: 192.168.50.17
        Call-ID: 1d98200-f32a8c0-13c4-55013-1813a-1a84edfe-1813a
        CSeq: 1 REGISTER
            Sequence Number: 1
            Method: REGISTER
        Via: SIP/2.0/UDP 192.168.50.17:5060;rport;branch=z9hG4bK-1813a-5e0caf4-7dd0b93d
            Transport: UDP
            Sent-by Address: 192.168.50.17
            Sent-by port: 5060
            RPort: rport
            Branch: z9hG4bK-1813a-5e0caf4-7dd0b93d
        Max-Forwards: 70
        Supported: 100rel,timer,replaces,UPDATE,INFO
        User-Agent: LG-Ericsson iPECS-LIK 100 5.5Gt
        Expires: 600
        Contact: <sip:78482xxxxxx@192.168.50.17>
            Contact-URI: sip:78482xxxxxx@192.168.50.17
                Contactt-URI User Part: 78482xxxxxx
                Contact-URI Host Part: 192.168.50.17
        Content-Length: 0
Привёл сниф. Номер телефона скрыл символами xxxxxx.
Хотя при чём тут инвайт я не знаю: меняется IP адрес с которого идёт сам инвайт. Внутри инвайта нечего не меняется. В приведённом снифе неправильный адрес 169.254.172.198, а должен быть реальный адрес моего PPPoE подключения...
СообщениеДобавлено: Вс дек 23, 2012 10:58
странное поведение ,
такого не встречал , странно конечно . тут надо думать где источник . попробуйте например атс через управляемй коммутатор вынести в отдельный влан .... могу подозревать что какой то хост в сети может слать ложные пакеты и DFL начиает путатся .
СообщениеДобавлено: Вс дек 23, 2012 11:35
Путаться на входе будет, а у меня проблема с выходом.
СообщениеДобавлено: Вс дек 23, 2012 11:54
в вашем случае , я бы наверное порекомендовал в офис ..... за несколько лет я впервые встречаю такое поведение на DFL. темболее что это в вашем случае лечится перезагрузкой DFL.
СообщениеДобавлено: Вс дек 23, 2012 12:10
я подозреваю ваш pppoe теряет реальный адрес. посмотрите его в свойствах интерфейса PPPoE в момент наличия проблемы.
СообщениеДобавлено: Вс дек 23, 2012 13:02
тогда syslog
СообщениеДобавлено: Пн дек 24, 2012 05:47
Попробуйте явно указать ip-объект в параметрах РРРоЕ соединения
Хотите считать с него трафик?
