Текущее время: Чт сен 10, 2026 05:21
 Заголовок сообщения: Ограничение arp
СообщениеДобавлено: Ср дек 19, 2012 16:28
Здравствуйте
сеть из коммутаторов серии DES-3526 и DES-3028
в сети периодически происходит вот такая вещь
11:31:32.253724 IP 10.0.16.108.49905 > 224.0.0.253.3544: UDP, length 40
11:31:32.254895 arp who-has 10.0.16.108 tell 10.0.11.91
11:31:32.255076 arp who-has 10.0.16.108 tell 10.0.9.130
11:31:32.255127 arp who-has 10.0.16.108 tell 10.0.18.95
11:31:32.255675 arp who-has 10.0.16.108 tell 10.0.8.205
11:31:32.255789 arp who-has 10.0.16.108 tell 10.0.12.4
11:31:32.255794 arp who-has 10.0.16.108 tell 10.0.5.240
11:31:32.255997 arp who-has 10.0.16.108 tell 10.0.8.49
11:31:32.257555 arp who-has 10.0.16.108 tell 10.0.1.45
11:31:32.257957 arp who-has 10.0.16.108 tell 10.0.17.210
11:31:32.258121 arp who-has 10.0.16.108 tell 10.0.7.25
11:31:32.258786 arp who-has 10.0.16.108 tell 10.0.8.148
11:31:32.258828 arp who-has 10.0.16.108 tell 10.0.4.74
11:31:32.258919 arp who-has 10.0.16.108 tell 10.0.5.251
11:31:32.259085 arp who-has 10.0.16.108 tell 10.0.17.152
11:31:32.259220 arp who-has 10.0.16.108 tell 10.0.18.66
11:31:32.259297 arp who-has 10.0.16.108 tell 10.0.17.164
11:31:32.259866 arp who-has 10.0.16.108 tell 10.0.4.240
11:31:32.260171 arp who-has 10.0.16.108 tell 10.0.19.219
11:31:32.260194 arp who-has 10.0.16.108 tell 10.0.4.219
11:31:32.260570 arp who-has 10.0.16.108 tell 10.0.3.11
11:31:32.260781 arp who-has 10.0.16.108 tell 10.0.11.236
11:31:32.261414 arp who-has 10.0.16.108 tell 10.0.9.166
11:31:32.262206 arp who-has 10.0.16.108 tell 10.0.16.37
11:31:32.262643 arp who-has 10.0.16.108 tell 10.0.12.130
11:31:32.263036 arp who-has 10.0.16.108 tell 10.0.8.83
11:31:32.263153 arp who-has 10.0.16.108 tell 10.0.20.98
11:31:32.263445 arp who-has 10.0.16.108 tell 10.0.16.100
11:31:32.263814 arp who-has 10.0.16.108 tell 10.0.12.219
11:31:32.263983 arp who-has 10.0.16.108 tell 10.0.1.74
11:31:32.264401 arp who-has 10.0.16.108 tell 10.0.6.168
11:31:32.265063 arp who-has 10.0.16.108 tell 10.0.9.38
11:31:32.265124 arp who-has 10.0.16.108 tell 10.0.5.242
11:31:32.265903 arp who-has 10.0.16.108 tell 10.0.6.218
11:31:32.265990 arp who-has 10.0.16.108 tell 10.0.19.188
11:31:32.281646 arp who-has 10.0.16.108 tell 10.0.9.14
в эти моменты сеть начинает "лагать"
Подскажите пожалуйста возможно ли каким нибудь образом решить данную проблему
Возможно ли разрешить arp запросы от клиентов только до шлюза и если да то как это сделать ?
 Заголовок сообщения: Re: Ограничение arp
СообщениеДобавлено: Ср дек 19, 2012 20:48
повально используйте traffic segmentation на доступе относительно аплинков
СообщениеДобавлено: Чт дек 20, 2012 12:36
Спасибо за совет
на L2 всё настроим по примеру http://www.dlink.ru/up/uploads_media/Tr ... tation.pdf
а как быть с L3 частью подскажите как правильно настроить traffic segmentation на DGS3627G
нужно ли вообще его там настраивать или arp и так не будут ходить между портами L3
СообщениеДобавлено: Чт дек 20, 2012 14:01
и 3627 тоже отсегментируйте.
Короче абонент должен видеть только свой шлюз и больше ничего.
СообщениеДобавлено: Пт дек 21, 2012 16:08
traffic_segmentation это конечно замечательно и где возможно мы его включили. Но возник следующий вопрос а как быть если в сети существуют stp кольца. В таком случае полноценно настроить traffic_segmentation не получится, а кольца полюбому нужны.
Таким образом мы вновь возвращаемся к изначальному вопросу:
Как разрешить arp запросы от клиентов только до шлюза?
СообщениеДобавлено: Пт дек 21, 2012 16:31
непонятна причина лагов (что лагает-то вообще?). вроде всё происходит так, как должно. как минимум, нестандартного поведения я не вижу
Это текст, который можно добавлять к размещаемым вами сообщениям. Длина его ограничена 255 символами.
СообщениеДобавлено: Пт дек 21, 2012 17:48
1) увеличивается время ответа L3 коммутатора на запрос arp who-has до 2 секунд
2) падает скорость при работе через данный L3 коммутатор
3) сильно увеличивается время пинга L2 коммутаторов которые подключены к данному L3
хотя в тоже время загрузка ЦП на L3 не возрастает
СообщениеДобавлено: Пт дек 21, 2012 18:01
третье явно связано со вторым, а вот с ним что происходит - загадка. L3 у 3627 аппаратный, и как пакеты, обрабатываемые CPU, могут замедлять маршрутизацию через устройство - это, наверное, господа ДЛинковцы проинформируют...
СообщениеДобавлено: Пн дек 24, 2012 21:57
Up.
Проблема все еще актуальна. При бомбардировке arp-запросами коммутатора получаем:
долгий ответ на arp, загрузка CPU особо не растет, есть подозрение что немного тормозится транзитный трафик.
СообщениеДобавлено: Вт дек 25, 2012 08:28
Простите, а какая у вас маска у сети, если, допустим, хосты 10.0.3.11 и 10.0.20.98 находятся в одной подсети? Вы удивляетесь, что у вас много броадкаста?
Что находится на 10.0.16.108?
СообщениеДобавлено: Вт дек 25, 2012 09:22
маска там /19
на 10.0.16.108 находится клиент
СообщениеДобавлено: Ср дек 26, 2012 13:40
Уважаемый Dlink подскажите как поведёт себя DGS3627 если на нём сделать ACL дропающий все arp who-has предназначенные не для него. Будет ли коммутатор обрабатывать arp запросы в полной мере (и соответственно тормозить как и раньше) или просто дропнет в ACL и даже не будет смотреть что это за пакет?
