Текущее время: Сб авг 22, 2026 04:15
 Заголовок сообщения: DES-1210-28/B2 Не работает ISM vlan
СообщениеДобавлено: Пт ноя 23, 2012 14:48
Не работает ТВ, на старой прошивке (DES-1210-28-B2-6-00-B057) все работало, но switch перезагружался самопроизвольно каждые несколько минут.
Вот конфиг:
# DES-1210-28/ME Fast Ethernet Switch Configuration
# Firmware: Build 6.01.B014
# Copyright(C) 2010 D-Link Corporation. All rights reserved.
# Vlan
disable asymmetric_vlan
create vlan default
config vlan vlanid 1 add untagged 26
config vlan vlanid 1 advertisement disable
create vlan 3 tag 3
config vlan vlanid 3 add tagged 26
config vlan vlanid 3 add untagged 1-24
config vlan vlanid 3 advertisement disable
create vlan 450 tag 450
config vlan vlanid 450 add tagged 1-26
config vlan vlanid 450 advertisement enable
config multicast filter 1 filter
config multicast filter 2 filter
config multicast filter 3 filter
config multicast filter 4 filter
config multicast filter 5 filter
config multicast filter 6 filter
config multicast filter 7 filter
config multicast filter 8 filter
config multicast filter 9 filter
config multicast filter 10 filter
config multicast filter 11 filter
config multicast filter 12 filter
config multicast filter 13 filter
config multicast filter 14 filter
config multicast filter 15 filter
config multicast filter 16 filter
config multicast filter 17 filter
config multicast filter 18 filter
config multicast filter 19 filter
config multicast filter 20 filter
config multicast filter 21 filter
config multicast filter 22 filter
config multicast filter 23 filter
config multicast filter 24 filter
config multicast filter 25 forward
config multicast filter 26 forward
config multicast filter 27 forward
config multicast filter 28 forward
enable management vlan
config management vlan default
# IP
config ipif System ipaddress 192.168.100.40/255.255.255.0 gateway 192.168.100.1
# ISM vlan
enable multicast_vlan
create multicast_vlan 8 8
config multicast_vlan 8 add member_port 1-24
config multicast_vlan 8 add source_port 26
config multicast_vlan 8 state enable
config multicast_vlan 8 replace_source_ip 172.16.100.40
# IGMP snooping
enable igmp_snooping
config igmp_snooping all router_timeout 125
config igmp_snooping all host_timeout 260
config igmp_snooping all leave_timer 1
config igmp_snooping querier vlanid 1 state disable robustness_variable 2
config igmp_snooping querier vlanid 1 state disable query_interval 125
config igmp_snooping querier vlanid 1 state disable max_response_time 10
config igmp_snooping data_driven_learning max_learned_entry 256
config igmp_snooping vlan_name default state disable fast_leave disable
config igmp_snooping data_driven_learning vlan_name default state disable
config igmp_snooping querier vlan_name default state disable querier_version IGMPv2 last_member_query_interval 1
config igmp_snooping vlan_name 3 state enable fast_leave disable
config igmp_snooping data_driven_learning vlan_name 3 state disable
config igmp_snooping querier vlan_name 3 state disable querier_version IGMPv2 last_member_query_interval 1
config igmp_snooping vlan_name 8 state enable fast_leave disable
config igmp_snooping data_driven_learning vlan_name 8 state disable
config igmp_snooping querier vlan_name 8 state disable querier_version IGMPv2 last_member_query_interval 1
config igmp_snooping vlan_name 450 state enable fast_leave disable
config igmp_snooping data_driven_learning vlan_name 450 state disable
config igmp_snooping querier vlan_name 450 state disable querier_version IGMPv2 last_member_query_interval 1
Пользователи работают в 3-м vlan-е, мультикаст в данный момент им недоступен.
Помогите, что ту можно предпринять.
Заранее благодарны!
 Заголовок сообщения: Re: DES-1210-28/B2 Не работает ISM vlan
СообщениеДобавлено: Пт ноя 23, 2012 15:07
Здравствуйте, у нас аналогичная проблема. в последних прошивках стабильность гораздо выше, но также не работает ISM vlan, конфиг аналогичный.
СообщениеДобавлено: Пт ноя 23, 2012 16:34
В Multicast VLAN Group попробуйте прописать используемые группы. IGMP Snooping в ISM влане отдельно не нужно включать.
СообщениеДобавлено: Пт ноя 23, 2012 18:26
Какой командой это можно сделать на данной прошивке?
Раньше я это делал так:
config igmp_snooping multicast_vlan_group 8 add 239.195.0.1 - 239.195.0.254
config igmp_snooping multicast_vlan_group 8 add 239.195.1.1 - 239.195.1.254
config igmp_snooping multicast_vlan_group 8 add 239.195.5.1 - 239.195.5.254
config igmp_snooping multicast_vlan_group 8 add 239.195.6.1 - 239.195.6.254
Включение или отключение снупинга в multicast_vlan не помогает, пробовал и так и так..
СообщениеДобавлено: Пт ноя 23, 2012 18:54
Если Вы про это:
# Limited IP Multicast
create mcast_filter_profile ipv4 profile_id 1 profile_name 1
config mcast_filter_profile profile_id 1 add 239.195.0.1 239.195.0.254
config mcast_filter_profile profile_id 1 add 239.195.1.1 239.195.1.254
config mcast_filter_profile profile_id 1 add 239.195.5.1 239.195.5.254
config mcast_filter_profile profile_id 1 add 239.195.6.1 239.195.6.254
config limited_multicast_addr ports 1 ipv4 add profile_id 1
config max_mcast_group ports 1 ipv4 max_group 256
config limited_multicast_addr ports 1 ipv4 access permit
config limited_multicast_addr ports 2 ipv4 add profile_id 1
config max_mcast_group ports 2 ipv4 max_group 256
config limited_multicast_addr ports 2 ipv4 access permit
config limited_multicast_addr ports 3 ipv4 add profile_id 1
config max_mcast_group ports 3 ipv4 max_group 256
config limited_multicast_addr ports 3 ipv4 access permit
config limited_multicast_addr ports 4 ipv4 add profile_id 1
config max_mcast_group ports 4 ipv4 max_group 256
config limited_multicast_addr ports 4 ipv4 access permit
config limited_multicast_addr ports 5 ipv4 add profile_id 1
config max_mcast_group ports 5 ipv4 max_group 256
config limited_multicast_addr ports 5 ipv4 access permit
config limited_multicast_addr ports 6 ipv4 add profile_id 1
config max_mcast_group ports 6 ipv4 max_group 256
config limited_multicast_addr ports 6 ipv4 access permit
config limited_multicast_addr ports 7 ipv4 add profile_id 1
config max_mcast_group ports 7 ipv4 max_group 256
config limited_multicast_addr ports 7 ipv4 access permit
config limited_multicast_addr ports 8 ipv4 add profile_id 1
config max_mcast_group ports 8 ipv4 max_group 256
config limited_multicast_addr ports 8 ipv4 access permit
config limited_multicast_addr ports 9 ipv4 add profile_id 1
config max_mcast_group ports 9 ipv4 max_group 256
config limited_multicast_addr ports 9 ipv4 access permit
config limited_multicast_addr ports 10 ipv4 add profile_id 1
config max_mcast_group ports 10 ipv4 max_group 256
config limited_multicast_addr ports 10 ipv4 access permit
config limited_multicast_addr ports 11 ipv4 add profile_id 1
config max_mcast_group ports 11 ipv4 max_group 256
config limited_multicast_addr ports 11 ipv4 access permit
config limited_multicast_addr ports 12 ipv4 add profile_id 1
config max_mcast_group ports 12 ipv4 max_group 256
config limited_multicast_addr ports 12 ipv4 access permit
config limited_multicast_addr ports 13 ipv4 add profile_id 1
config max_mcast_group ports 13 ipv4 max_group 256
config limited_multicast_addr ports 13 ipv4 access permit
config limited_multicast_addr ports 14 ipv4 add profile_id 1
config max_mcast_group ports 14 ipv4 max_group 256
config limited_multicast_addr ports 14 ipv4 access permit
config limited_multicast_addr ports 15 ipv4 add profile_id 1
config max_mcast_group ports 15 ipv4 max_group 256
config limited_multicast_addr ports 15 ipv4 access permit
config limited_multicast_addr ports 16 ipv4 add profile_id 1
config max_mcast_group ports 16 ipv4 max_group 256
config limited_multicast_addr ports 16 ipv4 access permit
config limited_multicast_addr ports 17 ipv4 add profile_id 1
config max_mcast_group ports 17 ipv4 max_group 256
config limited_multicast_addr ports 17 ipv4 access permit
config limited_multicast_addr ports 18 ipv4 add profile_id 1
config max_mcast_group ports 18 ipv4 max_group 256
config limited_multicast_addr ports 18 ipv4 access permit
config limited_multicast_addr ports 19 ipv4 add profile_id 1
config max_mcast_group ports 19 ipv4 max_group 256
config limited_multicast_addr ports 19 ipv4 access permit
config limited_multicast_addr ports 20 ipv4 add profile_id 1
config max_mcast_group ports 20 ipv4 max_group 256
config limited_multicast_addr ports 20 ipv4 access permit
config limited_multicast_addr ports 21 ipv4 add profile_id 1
config max_mcast_group ports 21 ipv4 max_group 256
config limited_multicast_addr ports 21 ipv4 access permit
config limited_multicast_addr ports 22 ipv4 add profile_id 1
config max_mcast_group ports 22 ipv4 max_group 256
config limited_multicast_addr ports 22 ipv4 access permit
config limited_multicast_addr ports 23 ipv4 add profile_id 1
config max_mcast_group ports 23 ipv4 max_group 256
config limited_multicast_addr ports 23 ipv4 access permit
config limited_multicast_addr ports 24 ipv4 add profile_id 1
config max_mcast_group ports 24 ipv4 max_group 256
config limited_multicast_addr ports 24 ipv4 access permit
config limited_multicast_addr ports 25 ipv4 add profile_id 1
config max_mcast_group ports 25 ipv4 max_group 256
config limited_multicast_addr ports 25 ipv4 access permit
config limited_multicast_addr ports 26 ipv4 add profile_id 1
config max_mcast_group ports 26 ipv4 max_group 256
config limited_multicast_addr ports 26 ipv4 access permit
config max_mcast_group ports 27 ipv4 max_group 256
config limited_multicast_addr ports 27 ipv4 access permit
config max_mcast_group ports 28 ipv4 max_group 256
config limited_multicast_addr ports 28 ipv4 access permit
config max_mcast_group ports 1 ipv6 max_group 256
config limited_multicast_addr ports 1 ipv6 access permit
config max_mcast_group ports 2 ipv6 max_group 256
config limited_multicast_addr ports 2 ipv6 access permit
config max_mcast_group ports 3 ipv6 max_group 256
config limited_multicast_addr ports 3 ipv6 access permit
config max_mcast_group ports 4 ipv6 max_group 256
config limited_multicast_addr ports 4 ipv6 access permit
config max_mcast_group ports 5 ipv6 max_group 256
config limited_multicast_addr ports 5 ipv6 access permit
config max_mcast_group ports 6 ipv6 max_group 256
config limited_multicast_addr ports 6 ipv6 access permit
config max_mcast_group ports 7 ipv6 max_group 256
config limited_multicast_addr ports 7 ipv6 access permit
config max_mcast_group ports 8 ipv6 max_group 256
config limited_multicast_addr ports 8 ipv6 access permit
config max_mcast_group ports 9 ipv6 max_group 256
config limited_multicast_addr ports 9 ipv6 access permit
config max_mcast_group ports 10 ipv6 max_group 256
config limited_multicast_addr ports 10 ipv6 access permit
config max_mcast_group ports 11 ipv6 max_group 256
config limited_multicast_addr ports 11 ipv6 access permit
config max_mcast_group ports 12 ipv6 max_group 256
config limited_multicast_addr ports 12 ipv6 access permit
config max_mcast_group ports 13 ipv6 max_group 256
config limited_multicast_addr ports 13 ipv6 access permit
config max_mcast_group ports 14 ipv6 max_group 256
config limited_multicast_addr ports 14 ipv6 access permit
config max_mcast_group ports 15 ipv6 max_group 256
config limited_multicast_addr ports 15 ipv6 access permit
config max_mcast_group ports 16 ipv6 max_group 256
config limited_multicast_addr ports 16 ipv6 access permit
config max_mcast_group ports 17 ipv6 max_group 256
config limited_multicast_addr ports 17 ipv6 access permit
config max_mcast_group ports 18 ipv6 max_group 256
config limited_multicast_addr ports 18 ipv6 access permit
config max_mcast_group ports 19 ipv6 max_group 256
config limited_multicast_addr ports 19 ipv6 access permit
config max_mcast_group ports 20 ipv6 max_group 256
config limited_multicast_addr ports 20 ipv6 access permit
config max_mcast_group ports 21 ipv6 max_group 256
config limited_multicast_addr ports 21 ipv6 access permit
config max_mcast_group ports 22 ipv6 max_group 256
config limited_multicast_addr ports 22 ipv6 access permit
config max_mcast_group ports 23 ipv6 max_group 256
config limited_multicast_addr ports 23 ipv6 access permit
config max_mcast_group ports 24 ipv6 max_group 256
config limited_multicast_addr ports 24 ipv6 access permit
config max_mcast_group ports 25 ipv6 max_group 256
config limited_multicast_addr ports 25 ipv6 access permit
config max_mcast_group ports 26 ipv6 max_group 256
config limited_multicast_addr ports 26 ipv6 access permit
config max_mcast_group ports 27 ipv6 max_group 256
config limited_multicast_addr ports 27 ipv6 access permit
config max_mcast_group ports 28 ipv6 max_group 256
config limited_multicast_addr ports 28 ipv6 access permit
то сделал.
Результат 0.
Подскажите где еще порыться?
СообщениеДобавлено: Пн ноя 26, 2012 12:31
Вижу на стенде, я отписал в штаб-квартиру и сообщу Вам по результатам.
СообщениеДобавлено: Ср ноя 28, 2012 09:21
Фикс будет в эту пятницу, я сообщу по результатам.
СообщениеДобавлено: Пт ноя 30, 2012 13:52
Прошивка 6.01.B017 с фиксом доступна здесь: https://dl.dropbox.com/u/41324937/D-Link_Firmwares/DES-1210-28/DES-1210-28-B2-R6.rar
Пожалуйста, попробуйте и сообщите по результатам.
СообщениеДобавлено: Пт ноя 30, 2012 19:06
Перепрошили, мультикаст не заработал. У вас на стенде все ok?
СообщениеДобавлено: Пн дек 03, 2012 10:40
Да, мультикаст работает. Настройки вот такие:
config vlan default delete 1-28
config vlan default add untagged 26
create vlan 3 tag 3
config multicast filter 1-28 filter
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan 8 8
config igmp_snooping multicast_vlan 8 add member_port 1-24
config igmp_snooping multicast_vlan 8 add source_port 26
config igmp_snooping multicast_vlan 8 state enable
config igmp_snooping multicast_vlan 8 replace_source_ip 172.16.100.40
config igmp_snooping vlan_name 8 fast_leave enable
config igmp_snooping data_driven_learning vlan_name 8 aged_out enable
config igmp_snooping multicast_vlan_group 8 add ipv4_range 239.0.0.0 239.255.255.255
config router_ports vlan_name 8 add 26
config mcast_filter_profile profile_id 1 add 239.0.0.0 239.255.255.255
config limited_multicast_addr ports 1-24 ipv4 add profile_id 1
config limited_multicast_addr ports 1-24 ipv4 access permit
