Текущее время: Чт окт 01, 2026 11:20
 Заголовок сообщения: Подскажите, есть в моём DES7210 VRF?
СообщениеДобавлено: Сб ноя 10, 2012 15:56
Вроде как не наблюдается, но чувство что оно должно быть, не покидает меня:
DES-7210#con ter
DES-7210(config)#route-map test
DES-7210(config-route-map)#set ?
  aggregator        BGP aggregator attribute
  as-path           Prepend string for a BGP AS-path attribute
  atomic-aggregate  BGP atomic aggregate attribute
  comm-list         Set BGP community list (for deletion)
  community         Display routes matching the communities
  dampening         Enable route-flap dampening
  extcommunity      BGP extended community attribute
  ip                IP specific information
  ipv6              IPv6 specific information
  level             Where to import route
  local-preference  BGP local preference path attribute
  metric            Metric value for destination routing protocol
  metric-type       Type of metric for destination routing protocol
  mpls-label        Set MPLS label for prefix
  next-hop          Next hop address for destination routing protocol
  origin            BGP origin code
  originator-id     BGP originator ID attribute
  tag               Tag value for destination routing protocol
  weight            BGP weight for routing table
DES-7210#sh version
System description      : DES-7210 Modular Layer 3 Chassis Ethernet Switch
System start time       : 2012-08-07 4:41:1
System uptime           : 95:12:56:14
System hardware version : A2.0
System software version : v10.4(3) Release(118208)
System BOOT version     : 10.4(3) Release(118208)
System CTRL version     : 10.4(3) Release(118208)
Module information:
  Slot-1 : 7200-24G
    Hardware version : A1.1
    Software version : v10.4(3) Release(118208)
  Slot-2 : 7200-24G
  Slot-3 : 7200-24G
  Slot-6 : 7200-24G2XG
    Hardware version : A3.0
  Slot-8 : 7200-ASE3
    Hardware version : A1.0
  Slot-M1 : 7200-CM4
    Hardware version : A2.0
  Slot-M2 : 7200-CM4
Вот, откапал в манах:
MPLS
VRF (7200-ASE3 is required)
MPLS Label Management (7200-ASE3 is required)
LDP (7200-ASE3 is required)
MPLS L3 VPN (7200-ASE3 is required)
VPWS5 (7200-ASE3 is required)
VRF-Lite (I/O module with H/W Ver. A3 is required)
ASE3 - есть.
"I/O module with H/W Ver. A3 is required" - это линейная карта?
 Заголовок сообщения: Re: Подскажите, есть в моём DES7210 VRF?
СообщениеДобавлено: Вт ноя 13, 2012 09:12
UP
Прошу прощения, просто очень нужен ответ.
СообщениеДобавлено: Вт ноя 13, 2012 13:41
Поддержка есть. Смотреть нужно командой: sh ip vrf
Более подробная информация здесь: ftp://ftp.dlink.ru/pub/Switch/DES-7200% ... 0%2010.4(3)%20Manual%20PDF(0726184145).rar
Бигаров Руслан.
СообщениеДобавлено: Ср ноя 21, 2012 13:50
Спасибо. На самом деле нужен был VRF-Lite, нету его на моей железяке. Тут Иван отвечал уже - viewtopic.php?p=553056#p553056
СообщениеДобавлено: Ср ноя 21, 2012 15:49
Не за что.
Бигаров Руслан.
Сейчас этот форум просматривают: Google [Bot] и гости: 89
