Текущее время: Пт июн 26, 2026 13:41
 Заголовок сообщения: Проблемы с настройкой Freeradius и D-Link
СообщениеДобавлено: Вт ноя 06, 2012 11:16
Подскажите пожалуйста, использую вот это описание при настройке Freeradius и D-Link 3828. При добавлении строк в файл users Freeradius, сервер выдает ошибку:
Starting - reading configuration files ...
reread_config: reading radiusd.conf
Config: including file: /etc/raddb/clients.conf
Config: including file: /etc/raddb/snmp.conf
Config: including file: /etc/raddb/eap.conf
Config: including file: /etc/raddb/sql.conf
Config: including file: /etc/raddb/sqlippool.conf
main: prefix = "/usr"
main: localstatedir = "/var"
main: logdir = "/var/log/radius"
main: libdir = "/usr/lib"
main: radacctdir = "/var/log/radius/radacct"
main: hostname_lookups = no
main: snmp = no
main: max_request_time = 30
main: cleanup_delay = 5
main: max_requests = 1024
main: delete_blocked_requests = 0
main: port = 0
main: allow_core_dumps = no
main: log_stripped_names = no
main: log_file = "/var/log/radius/radius.log"
main: log_auth = yes
main: log_auth_badpass = yes
main: log_auth_goodpass = no
main: pidfile = "/var/run/radiusd/radiusd.pid"
main: user = "radiusd"
main: group = "radiusd"
main: usercollide = no
main: lower_user = "no"
main: lower_pass = "no"
main: nospace_user = "no"
main: nospace_pass = "no"
main: checkrad = "/usr/sbin/checkrad"
main: proxy_requests = no
security: max_attributes = 200
security: reject_delay = 1
security: status_server = no
main: debug_level = 0
read_config_files: reading dictionary
read_config_files: reading naslist
Using deprecated naslist file. Support for this will go away soon.
read_config_files: reading clients
read_config_files: reading realms
radiusd: entering modules setup
Module: Library search path is /usr/lib
Module: Loaded exec
exec: wait = yes
exec: program = "(null)"
exec: input_pairs = "request"
exec: output_pairs = "(null)"
exec: packet_type = "(null)"
rlm_exec: Wait=yes but no output defined. Did you mean output=none?
Module: Instantiated exec (exec)
Module: Loaded expr
Module: Instantiated expr (expr)
Module: Loaded PAP
pap: encryption_scheme = "crypt"
Module: Instantiated pap (pap)
Module: Loaded CHAP
Module: Instantiated chap (chap)
Module: Loaded MS-CHAP
mschap: use_mppe = yes
mschap: require_encryption = no
mschap: require_strong = no
mschap: with_ntdomain_hack = no
mschap: passwd = "(null)"
mschap: ntlm_auth = "(null)"
Module: Instantiated mschap (mschap)
Module: Loaded System
unix: cache = no
unix: passwd = "(null)"
unix: shadow = "/etc/shadow"
unix: group = "(null)"
unix: radwtmp = "/var/log/radius/radwtmp"
unix: usegroup = no
unix: cache_reload = 600
Module: Instantiated unix (unix)
Module: Loaded eap
eap: default_eap_type = "md5"
eap: timer_expire = 60
eap: ignore_unknown_eap_types = no
eap: cisco_accounting_username_bug = no
rlm_eap: Loaded and initialized type md5
rlm_eap: Loaded and initialized type leap
gtc: challenge = "Password: "
gtc: auth_type = "PAP"
rlm_eap: Loaded and initialized type gtc
mschapv2: with_ntdomain_hack = no
rlm_eap: Loaded and initialized type mschapv2
Module: Instantiated eap (eap)
Module: Loaded preprocess
preprocess: huntgroups = "/etc/raddb/huntgroups"
preprocess: hints = "/etc/raddb/hints"
preprocess: with_ascend_hack = no
preprocess: ascend_channels_per_line = 23
preprocess: with_ntdomain_hack = no
preprocess: with_specialix_jetstream_hack = no
preprocess: with_cisco_vsa_hack = no
preprocess: with_alvarion_vsa_hack = no
Module: Instantiated preprocess (preprocess)
Module: Loaded realm
realm: format = "suffix"
realm: delimiter = "@"
realm: ignore_default = no
realm: ignore_null = no
Module: Instantiated realm (suffix)
Module: Loaded SQL
sql: driver = "rlm_sql_mysql"
sql: server = "localhost"
sql: port = ""
sql: login = "freeradius"
sql: password = "123"
sql: radius_db = "freeradius"
sql: nas_table = "nas"
sql: sqltrace = yes
sql: sqltracefile = "/var/log/radius/sqltrace.sql"
sql: readclients = yes
sql: deletestalesessions = yes
sql: num_sql_socks = 5
sql: sql_user_name = "%{User-Name}"
sql: default_user_profile = ""
sql: query_on_not_found = no
sql: authorize_check_query = "SELECT id, UserName, Attribute, Value, op FROM radcheck WHERE Username = BINARY '%{SQL-User-Name}' ORDER BY id"
sql: authorize_reply_query = "SELECT id, UserName, Attribute, Value, op FROM radreply WHERE Username = BINARY '%{SQL-User-Name}' ORDER BY id"
sql: authorize_group_check_query = ""
sql: authorize_group_reply_query = ""
sql: accounting_onoff_query = ""
sql: accounting_update_query = ""
sql: accounting_update_query_alt = ""
sql: accounting_start_query = ""
sql: accounting_start_query_alt = ""
sql: accounting_stop_query = ""
sql: accounting_stop_query_alt = ""
sql: group_membership_query = ""
sql: connect_failure_retry_delay = 60
sql: simul_count_query = ""
sql: simul_verify_query = ""
sql: postauth_query = ""
sql: safe-characters = "@abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789.-_: /"
rlm_sql (sql): Driver rlm_sql_mysql (module rlm_sql_mysql) loaded and linked
rlm_sql (sql): Attempting to connect to freeradius@localhost:/freeradius
rlm_sql (sql): starting 0
rlm_sql (sql): Attempting to connect rlm_sql_mysql #0
rlm_sql_mysql: Starting connect to MySQL server for #0
rlm_sql (sql): Connected new DB handle, #0
rlm_sql (sql): starting 1
rlm_sql (sql): Attempting to connect rlm_sql_mysql #1
rlm_sql_mysql: Starting connect to MySQL server for #1
rlm_sql (sql): Connected new DB handle, #1
rlm_sql (sql): starting 2
rlm_sql (sql): Attempting to connect rlm_sql_mysql #2
rlm_sql_mysql: Starting connect to MySQL server for #2
rlm_sql (sql): Connected new DB handle, #2
rlm_sql (sql): starting 3
rlm_sql (sql): Attempting to connect rlm_sql_mysql #3
rlm_sql_mysql: Starting connect to MySQL server for #3
rlm_sql (sql): Connected new DB handle, #3
rlm_sql (sql): starting 4
rlm_sql (sql): Attempting to connect rlm_sql_mysql #4
rlm_sql_mysql: Starting connect to MySQL server for #4
rlm_sql (sql): Connected new DB handle, #4
rlm_sql (sql): - generate_sql_clients
rlm_sql (sql): Query: SELECT * FROM nas
rlm_sql (sql): Reserving sql socket id: 4
rlm_sql_mysql: query: SELECT * FROM nas
rlm_sql (sql): Released sql socket id: 4
Module: Instantiated sql (sql)
Module: Loaded Acct-Unique-Session-Id
acct_unique: key = "User-Name, Acct-Session-Id, NAS-IP-Address, Client-IP-Address, NAS-Port"
Module: Instantiated acct_unique (acct_unique)
Module: Loaded files
files: usersfile = "/etc/raddb/users"
files: acctusersfile = "/etc/raddb/acct_users"
files: preproxy_usersfile = "/etc/raddb/preproxy_users"
files: compat = "no"
/etc/raddb/users[219]: Parse error (check) for entry user: Unknown attribute "Cleartext-Password"
Errors reading /etc/raddb/users
radiusd.conf[1059]: files: Module instantiation failed.
radiusd.conf[1967] Unknown module "files".
radiusd.conf[1946] Failed to parse preacct section.
Что я не так делаю? Заранее спасибо.
СообщениеДобавлено: Вт ноя 06, 2012 11:35
Разобрался с модулями
СообщениеДобавлено: Пт ноя 09, 2012 15:19
Подскажите пожалуйста, вышеуказанное описание дано для freeradius, не использующего базу данных Mysql, как связать с коммутатором D-Link DES-3828 freeradius, который использует БД Mysql.
Что такое "ключ" в разделе "Authentic RADIUS Server" и где он указан в конфигурации freeradius.
СообщениеДобавлено: Пн ноя 12, 2012 04:43
В новом freeradius нет папки raddb, там папка freeradius: etc/freeradius/users, etc/freeradius/clients и т.д. вродь так.
http://dmitrykhn.homedns.org/wp/2009/04 ... nterfaces/
http://www.hilik.org.ua/freeradius/
СообщениеДобавлено: Пн ноя 12, 2012 09:13
Как раз работал со второй ссылкой, но по ней радиус не поднять. freeradius не понимает атрибут Service-Type. Но моим с радиусом все хорошо - он работает. Проблема теперь прописать пользователей (рабочие станции) на фирме, чтобы они могли получить доступ в сеть
СообщениеДобавлено: Ср ноя 21, 2012 09:50
Есть проблема с freeradius 2.1.7. Локально аутентификация проходит на ура - вот дебаг сервера:
rad_recv: Access-Request packet from host 192.168.136.88 port 34182, id=240, len        gth=60
        User-Name = "testuser"
        User-Password = "testuser"
        NAS-IP-Address = 192.168.136.88
        NAS-Port = 1812
+- entering group authorize {...}
++[preprocess] returns ok
[auth_log]      expand: /var/log/radius/radacct/%{Client-IP-Address}/auth-detail        -%Y%m%d -> /var/log/radius/radacct/192.168.136.88/auth-detail-20121121
[auth_log] /var/log/radius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d expan        ds to /var/log/radius/radacct/192.168.136.88/auth-detail-20121121
[auth_log]      expand: %t -> Wed Nov 21 08:22:52 2012
++[auth_log] returns ok
++[chap] returns noop
++[mschap] returns noop
[suffix] No '@' in User-Name = "testuser", looking up realm NULL
[suffix] No such realm "NULL"
++[suffix] returns noop
[eap] No EAP-Message, not doing EAP
++[eap] returns noop
++[unix] returns notfound
++[files] returns noop
[sql]   expand: %{User-Name} -> testuser
[sql] sql_set_user escaped user --> 'testuser'
[sql]   expand: SELECT id, username, attribute, value, op           FROM radchec        k           WHERE username = '%{SQL-User-Name}'           ORDER BY id -> SELECT        id, username, attribute, value, op           FROM radcheck           WHERE usern        ame = 'testuser'           ORDER BY id
rlm_sql_mysql: query:  SELECT id, username, attribute, value, op           FROM        radcheck           WHERE username = 'testuser'           ORDER BY id
[sql] User found in radcheck table
[sql]   expand: SELECT id, username, attribute, value, op           FROM radrepl        y           WHERE username = '%{SQL-User-Name}'           ORDER BY id -> SELECT        id, username, attribute, value, op           FROM radreply           WHERE usern        ame = 'testuser'           ORDER BY id
rlm_sql_mysql: query:  SELECT id, username, attribute, value, op           FROM        radreply           WHERE username = 'testuser'           ORDER BY id
[sql]   expand: SELECT groupname           FROM radusergroup           WHERE use        rname = '%{SQL-User-Name}'           ORDER BY priority -> SELECT groupname        FROM radusergroup           WHERE username = 'testuser'           ORDER BY        priority
rlm_sql_mysql: query:  SELECT groupname           FROM radusergroup           WH        ERE username = 'testuser'           ORDER BY priority
++[sql] returns ok
rlm_checkval: Could not find item named Calling-Station-Id in request
rlm_checkval: Could not find attribute named Calling-Station-Id in check pairs
++[checkval] returns notfound
++[expiration] returns noop
++[logintime] returns noop
++[pap] returns updated
Found Auth-Type = PAP
!!!    Replacing User-Password in config items with Cleartext-Password.     !!!
!!! Please update your configuration so that the "known good"               !!!
!!! clear text password is in Cleartext-Password, and not in User-Password. !!!
+- entering group PAP {...}
[pap] login attempt with password "testuser"
[pap] Using clear text password "testuser"
[pap] User authenticated successfully
++[pap] returns ok
        expand: goodpass -> goodpass
Login OK: [testuser/testuser] (from client server.zi port 1812) goodpass
+- entering group post-auth {...}
[sql]   expand: %{User-Password} -> testuser
[sql]   expand: INSERT INTO radpostauth                           (username, pas        s, reply, authdate)                           VALUES (        '%{User-Name}',                           '%{%{User-Password}:-%{Chap-Password}        }',                           '%{reply:Packet-Type}', '%S') -> INSERT INTO radpo        stauth                           (username, pass, reply, authdate)        VALUES (                           'testuser',        'testuser',                           'Access-Accept', '2012-11-21 08:22:5        2')
[sql]   expand: /var/log/radius/sqltrace.sql -> /var/log/radius/sqltrace.sql
rlm_sql (sql) in sql_postauth: query is INSERT INTO radpostauth        (username, pass, reply, authdate)                           VALUES (        'testuser',                           'testuser',        'Access-Accept', '2012-11-21 08:22:52')
rlm_sql (sql): Reserving sql socket id: 3
rlm_sql_mysql: query:  INSERT INTO radpostauth                           (userna        me, pass, reply, authdate)                           VALUES (        'testuser',                           'testuser',        'Access-Accept', '2012-11-21 08:22:52')
rlm_sql (sql): Released sql socket id: 3
++[sql] returns ok
[sql_log] Processing sql_log_postauth
[sql_log]       expand: %{User-Name} -> testuser
[sql_log]       expand: %{%{User-Name}:-DEFAULT} -> testuser
[sql_log] sql_set_user escaped user --> 'testuser'
[sql_log] WARNING: Deprecated conditional expansion ":-".  See "man unlang" for        details
[sql_log]       expand: INSERT INTO radpostauth                          (userna        me, pass, reply, authdate) VALUES                        ('%{User-Name}', '%{Use        r-Password:-Chap-Password}',             '%{reply:Packet-Type}', '%S'); -> INSER        T INTO radpostauth                       (username, pass, reply, authdate) VALUE        S                        ('testuser', 'testuser',                'Access-Accept'        , '2012-11-21 08:22:52');
[sql_log]       expand: /var/log/radius/radacct/sql-relay -> /var/log/radius/rad        acct/sql-relay
++[sql_log] returns ok
++[exec] returns noop
Sending Access-Accept of id 240 to 192.168.136.88 port 34182
Finished request 0.
Going to the next request
Waking up in 4.9 seconds.
Cleaning up request 0 ID 240 with timestamp +1901
Ready to process requests.
При удаленной аутентификации с ОС Windows XP SP3 аутентификация не проходит. Вот листинг дебага:
rad_recv: Access-Request packet from host 192.168.136.210 port 8021, id=8, length=228
        Framed-MTU = 1466
        NAS-IP-Address = 192.168.136.210
        NAS-Identifier = "D-Link"
        Service-Type = Framed-User
        NAS-Port = 1
        NAS-Port-Type = Ethernet
        NAS-Port-Id = "ether1_1"
        Called-Station-Id = "00-19-5b-f3-c5-00"
        Calling-Station-Id = "00-22-64-5c-df-23"
        Connect-Info = "CONNECT Ethernet 100Mbps Full duplex"
        State = 0x89f05b348ff842993489b5a8dae508e8
        EAP-Message = 0x0208002419001703010019afe8aa68babf480f3d53edc9dd1d569187cadb734a4e6f1ad6
        Message-Authenticator = 0xd23082ac9e4aace39609be655d8fd2cf
[auth_log]      expand: /var/log/radius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d -> /var/log/radius/radacct/192.168.136.210/auth-detail-20121121
[auth_log] /var/log/radius/radacct/%{Client-IP-Address}/auth-detail-%Y%m%d expands to /var/log/radius/radacct/192.168.136.210/auth-detail-20121121
[auth_log]      expand: %t -> Wed Nov 21 08:29:54 2012
[eap] EAP packet type response id 8 length 36
[eap] Continuing tunnel setup.
++[eap] returns ok
rlm_sql (sql): Reserving sql socket id: 2
[sql]   expand: SELECT id, username, attribute, value, op           FROM radcheck           WHERE username = '%{SQL-User-Name}'           ORDER BY id -> SELECT id, username, attribute, value, op           FROM radcheck           WHERE username = 'testuser'           ORDER BY id
[sql]   expand: SELECT id, username, attribute, value, op           FROM radreply           WHERE username = '%{SQL-User-Name}'           ORDER BY id -> SELECT id, username, attribute, value, op           FROM radreply           WHERE username = 'testuser'           ORDER BY id
[sql]   expand: SELECT groupname           FROM radusergroup           WHERE username = '%{SQL-User-Name}'           ORDER BY priority -> SELECT groupname           FROM radusergroup           WHERE username = 'testuser'           ORDER BY priority
rlm_sql_mysql: query:  SELECT groupname           FROM radusergroup           WHERE username = 'testuser'           ORDER BY priority
rlm_sql (sql): Released sql socket id: 2
++[sql] returns ok
rlm_checkval: Item Name: Calling-Station-Id, Value: 00-22-64-5c-df-23
[pap] Found existing Auth-Type, not changing it.
++[pap] returns noop
Found Auth-Type = EAP
+- entering group authenticate {...}
[eap] Request found, released from the list
[eap] EAP/peap
[eap] processing type peap
[peap] processing EAP-TLS
[peap] eaptls_verify returned 7
[peap] Done initial handshake
[peap] eaptls_process returned 7
[peap] EAPTLS_OK
[peap] Session established.  Decoding tunneled attributes.
[peap] Identity - testuser
[peap] Got tunneled request
        EAP-Message = 0x0208000d017465737475736572
server  {
  PEAP: Got tunneled identity of testuser
  PEAP: Setting default EAP type for tunneled EAP session.
  PEAP: Setting User-Name to testuser
Sending tunneled request
        FreeRADIUS-Proxied-To = 127.0.0.1
server inner-tunnel {
++[control] returns noop
[eap] Request is supposed to be proxied to Realm LOCAL.  Not doing EAP.
WARNING: You set Proxy-To-Realm = LOCAL, but the realm does not exist!  Cancelling invalid proxy request.
No authenticate method (Auth-Type) configuration found for the request: Rejecting the user
Failed to authenticate the user.
        expand: badpass -> badpass
Login incorrect: [testuser/<no User-Password attribute>] (from client private-network-1 port 0 via TLS tunnel) badpass
} # server inner-tunnel
[peap] Got tunneled reply code 3
[peap] Got tunneled reply RADIUS code 3
[peap] Tunneled authentication was rejected.
[peap] FAILURE
++[eap] returns handled
Sending Access-Challenge of id 8 to 192.168.136.210 port 8021
        EAP-Message = 0x010900261900170301001b8904fe6150cd0920fcf22c03a085a10f27a7494caadac8489f1aad
        Message-Authenticator = 0x00000000000000000000000000000000
        State = 0x89f05b348ef942993489b5a8dae508e8
Finished request 7.
Waking up in 4.3 seconds.
rad_recv: Access-Request packet from host 192.168.136.210 port 8021, id=9, length=230
        Framed-MTU = 1466
        NAS-Port = 1
        EAP-Message = 0x020900261900170301001be5b97196746ab67115fb829ab6985105f8e76f8cc65d0c5facd4eb
        Message-Authenticator = 0xc999f7c7ce50aad5fb1b9b27e67159b9
[eap] EAP packet type response id 9 length 38
++[eap] returns ok
rlm_sql (sql): Reserving sql socket id: 1
rlm_sql (sql): Released sql socket id: 1
++[sql] returns ok
[eap] EAP/peap
[peap] EAPTLS_OK
[peap] Received EAP-TLV response.
[peap]  Had sent TLV failure.  User was rejected earlier in this session.
[eap] Handler failed in EAP/peap
[eap] Failed in EAP select
++[eap] returns invalid
Login incorrect: [testuser/<via Auth-Type = EAP>] (from client private-network-1 port 1 cli 00-22-64-5c-df-23) badpass
Using Post-Auth-Type Reject
+- entering group REJECT {...}
[attr_filter.access_reject]     expand: %{User-Name} -> testuser
 attr_filter: Matched entry DEFAULT at line 11
++[attr_filter.access_reject] returns updated
Delaying reject of request 8 for 1 seconds
Waking up in 0.9 seconds.
Sending delayed reject for request 8
Sending Access-Reject of id 9 to 192.168.136.210 port 8021
        EAP-Message = 0x04090004
Waking up in 3.3 seconds.
Cleaning up request 0 ID 1 with timestamp +41
Cleaning up request 1 ID 2 with timestamp +41
Waking up in 0.4 seconds.
Cleaning up request 2 ID 3 with timestamp +41
Cleaning up request 3 ID 4 with timestamp +41
Cleaning up request 4 ID 5 with timestamp +41
Cleaning up request 5 ID 6 with timestamp +41
Waking up in 0.1 seconds.
Cleaning up request 6 ID 7 with timestamp +41
Cleaning up request 7 ID 8 with timestamp +41
Waking up in 1.0 seconds.
Cleaning up request 8 ID 9 with timestamp +41
Клиентом служит D-Link Des-3828. С freeradius столкнулся впервые. Подскажите куда копать?
СообщениеДобавлено: Вт дек 04, 2012 11:50
Подскажите - как инициировать log-in и log-out пользователей Windows XP? В качестве NAS используется D-Link Des-3828.
Постоянно приходится передергивать сетевой кабель, чтобы снова войти в сеть при неудачной авторизации.
