Текущее время: Вс окт 25, 2026 05:12
 Заголовок сообщения: Не запускается DAS-3248 rev B1
СообщениеДобавлено: Чт окт 04, 2012 10:35
Начала подвисать периодически DAS-3248.
Монтажники приезжают - горит индикатор ERROR.
Несколько раз после перезагрузки работала нормально до следующего подвисания, сейчас вообще не стартует - ERROR сразу после включения.
Прошивку после первых зависаний обновил на 2.47r60.
В консоли при включении вижу:
                         DSLAM Bootloader
 Bootloader Release : R2.2n_4M Date: Nov 17 2009
 Initializing IPDSLAM Memories............. Success
 Press F1 to enter Interactive Mode, 'Enter' to skip .... 5 seconds left
 Press i to force upgrade image, 'Enter' to skip .... 5 seconds left
 Transfering Control to BootTftp binary
 Flash Present In System.......
 MANUF skip tftping
 All the files are in Flash, No TFTP required
 Mxu shall come up in normal mode
 All the files have been successfully received.....
 Active copy of Ctrl Plane Bin was found in flash
 Unzipping the Control Plane......................................................................................................................................................................................................................................................................................................
 Transferring Control to Ctrl Plane Binary...
 Free Memory available in SDRAM-A is 0x95bf8
 System coming up in normal mode...
 Locking Control Plane Text Start: 0x4923000 End: 0x4f80aa8
 FlashPresent = 1
 u8ColumbiaIdSel = 18
 u32FlashSize = 4194304
 total memory Free in SDRAM A = 613368
 Allocatiing System Memory fom SDRAM-E
 total memory Free in SDRAM E = 196608
 total memory Free in SDRAM D = 0
 total memory Free in SDRAM B = 316468
 Flash scanning in progress
 CdbNvm:- Configuration Size is 1939248
 CdbNvm:- NVM CFG1 size 262032
CdbNvm:- Device not Opened before Ioctl
CdbNVM:- next boot mode is 0xfe
 The uncompress location for data plane is 0x400b000
 Cin:- DataPlane present in NVRAM
 Cin- Uncompressing Dataplane
 Uncompressing "DP.bin.gz" (384665->840232) ...... Done
 Locking Text Area DP Text Start: 0x4818000 CP Text End : 0x4f80aa8
 CfgInit: System Coming up from Last Configuration
Uncompress:- UnZipLen: 112629, ZipLen: 9859
 Initializing DataPlane
 DataPlane Initialized successfully
Uncompress:- UnZipLen: 112629, ZipLen: 9859The DSL binary file to be opened is dsl_10_330000003C00000D.bin.gz
The DSL bin size is 266376
Loading The system.....
Loading system over.....
Initializing system.....
Аналогичным образом зависает DAS-3224 rev B1, только с той разницей, что 3248 несколько лет работала, а 3224 лежала на полке.
Что делать? Клиенты рвут на части уже.
 Заголовок сообщения: Re: Не запускается DAS-3248 rev B1
СообщениеДобавлено: Чт окт 04, 2012 11:59
Я так понял, что после:
"Loading The system.....
Initializing system....."
DSLAM "повисает " ?
DSLAМ обязательно должен "доходить" в загрузке до приглашения ввода логина - пароля.
Если же этого не происходит, то это аппаратные проблемы устройства.
Необходим осмотр ( диагностика) и ремонт в сервис-центре D-link.
Cписок офисов, где у вас могут принять в ремонт DSLAM тут:
http://www.dlink.ru/ru/contacts/
Диагностика бесплатная
Но ремонт, если DSLAM не на гарантии ( более 2 лет с даты производства ( а рев B у же точно будет не на гарантии)), будет платным.
С уважением, Гакало Алексей
