Текущее время: Пн сен 14, 2026 16:32
Начать новую тему Ответить на тему  [ Сообщений: 54 ]  На страницу Пред.  1, 2, 3, 4  След.
 Заголовок сообщения: Re: DVG-7111S и аналоговая линия
СообщениеДобавлено: Пн сен 24, 2012 12:22
установить Default call route в PSTN - достаточно?
СообщениеДобавлено: Пн сен 24, 2012 12:24
Да.
СообщениеДобавлено: Пн сен 24, 2012 16:24
Установил PSTN default, получил:
    16:45:11 *** SLMON start to log ***
    16:45:21 [001509] Receive Cmd=1100, ParaLen=5, Para=[Login]
    16:45:21 [001509] Login RU_1.00 == Ver(1.02.38.56.2876 2010/05/21 14:06:11) PId(281.DLink.RU.DecodeProf.DhcpOpt195.l2tp.DualAccess.NoPrefix.drtp) Drv(0.10.55.1
    16:45:21 ) Hw(TSO) == 0.6.8
    16:52:11 [005608] 0: Fxs Pickup
    16:52:11 [005608] 0: ==4:GetDtmf
    16:52:33 [005825] 0: DTMF Timeout #1
    16:52:33 [005825] 0: End Input Default Route [2]
    16:52:33 [005825] 0: Line DialNum_New [8903742хххх]
    16:52:33 [005825] 0: Local Calling Fxo [8903742хххх]
    16:52:33 [005825] 0: ==7:Inviting
    16:52:33 [005825] 0: Get Local Fxo Line 1
    16:52:33 [005825] 1: TrunkPrefix=, Dest=8903742хххх, Dialno=8903742хххх
    16:52:33 [005825] 1: FxoHookOff
    16:52:33 [005825] 1: InputGain(6)
    16:52:33 [005825] 1: ==18:TrunkDialOut
    16:52:34 [005836] 1: DialOut(8903742хххх)=0
    16:52:49 [005987] 0: FilterDtmf(0)=0
    16:52:49 [005987] 0: Change RTP to 192.168.1.240:9002, pt=0
    16:52:49 [005987] 0: RtpApiTalk[1,1], Peer=192.168.1.240:9002, PT=0, FC=4, NewOOB=0
    16:52:49 [005987] 1: FilterDtmf(0)=0
    16:52:49 [005987] 1: RtpApiTalk[1,1], Peer=192.168.1.240:9000, PT=0, FC=4, NewOOB=0
    16:52:49 [005987] 1: Substatus=3
    16:52:58 [006077] 1: Fxo Still No RingTone, Talk
    16:52:58 [006077] 1: Fxo DialOut OK
    16:52:58 [006077] 1: Local Talk at ToAnswer
    16:52:58 [006077] 1: RtpApiTalk[1,1], Peer=192.168.1.240:9000, PT=0, FC=4, NewOOB=0
    16:52:58 [006077] 0: Local Talk at RingBack
    16:52:58 [006077] 0: RtpApiTalk[1,1], Peer=192.168.1.240:9002, PT=0, FC=4, NewOOB=0
    16:52:58 [006077] 1: ==14:Talking
    16:52:58 [006077] 0: ==14:Talking
    16:53:35 [006443] 0: Fxs Hangup
    16:53:35 [006443] 0: Bye at Talking
    16:53:35 [006443] 0: ==3:Idle
    16:53:35 [006443] 0: SetFax(1)=0
    16:53:35 [006443] 0: SetModem(0)=-1
    16:53:35 [006443] 1: ==15:PlayBusyTone
    16:53:35 [006444] 1: Start Btc Learning
    16:53:36 [006459] 1: Btc Learning Exception No Change
    16:53:36 [006459] 1: FxoHookOn
    16:53:36 [006459] 1: ==3:Idle
    16:53:36 [006459] 1: InputGain(6)
    16:53:36 [006459] 1: SetFax(1)=0
    16:53:36 [006459] 1: SetModem(0)=-1
исходящие - набирается номер, никуда не попадает
входящие - идут гудки ничего не звонит
вернулся на исходную и все совсем сломалось. ни входящих ни исходящих..., только внутренняя связь, пытаюсь восстановить входящие :(
СообщениеДобавлено: Пн сен 24, 2012 16:36
попробовал туда циферки всякие повставлять, как теперь очистить не знаю, ругается, что должно быть что-нибудь обязательно вписано
PSTN Control
Trunk Dial Out Verify :
Trunk Dial Out Replace :
Trunk Dial Out Deny :
СообщениеДобавлено: Пн сен 24, 2012 16:54
ну вот, все сломалось, восстановил все значения в изначальный вид (когда работали входящие), и ни входящих, ни исходящих нет теперь. при попытке дозвониться на шлюз, идут гудки, телефон не звонит, slmon не реагирует.
значения восстановил все, за исключением PSTN Control - они не опустошаются (изначально были пустые поля)
СообщениеДобавлено: Пн сен 24, 2012 17:38
УРА!!! Все заработало "чудесным" образом, после пееробжатия кабеля телефонной линии :oops:
Огромное спасибо за поддержку и терпение :)
P.S. PSTN Control стоят значения 8-8-0
СообщениеДобавлено: Вт сен 25, 2012 11:41
Обнаружилась еще одна проблемка, разговоры периодически прерываются. Мне кажется, это связано с не очень хорошим качеством линии...
Можно ли где нибудь в настройках указать, чтобы шлюз не прерывал соединение, если я сам не положу трубку, даже если на другом конце положили?
СообщениеДобавлено: Вт сен 25, 2012 15:18
Нет, но можно настроить определение сигнала занято.
СообщениеДобавлено: Вт сен 25, 2012 15:44
В CPT / Cadence ?
вот сейчас пытаюсь записать сигнал занято... почему то, когда кладешь аналоговую трубку, сигнала нет, просто щелк и разговор прерывается. а когда трубка занята, сигнал есть, но 3СХ умеет записывать только те разговоры, которые начались.
СообщениеДобавлено: Чт сен 27, 2012 13:43
Лог прервавшегося разговора, может тут что нить видно?
    14:31:36 [737734] 1: Fxo Ringing
    14:31:36 [737734] 1: CallerId=
    14:31:36 [737734] 1: ==17:WaitAnswerDeviceOk
    14:31:37 [737734] 1: HotLineEnabled with [131]
    14:31:37 [737734] 1: End Input Default Route [0]
    14:31:37 [737734] 1: Local Calling Fxs [131]
    14:31:37 [737734] 1: ==7:Inviting
    14:31:37 [737734] 0: Local Called By Line 1
    14:31:37 [737734] 0: ==12:Alerting
    14:31:37 [737734] 1: ==8:RingBack
    14:31:37 [737735] 1: RingTime(103) First Stop
    14:31:41 [737774] 1: RingTime(512) Second Ring
    14:31:46 [737829] 0: Fxs Pickup
    14:31:46 [737829] 0: Local Talk at ToAnswer
    14:31:46 [737829] 0: RtpApiTalk[1,1], Peer=192.168.1.240:9002, PT=0, FC=4, NewOOB=0
    14:31:46 [737829] 1: Local Talk at RingBack
    14:31:46 [737829] 1: FxoHookOff
    14:31:46 [737829] 1: InputGain(9)
    14:31:46 [737829] 1: RtpApiTalk[0,0], Peer=192.168.1.240:9000, PT=0, FC=4, NewOOB=0
    14:31:46 [737829] 0: ==14:Talking
    14:31:46 [737829] 1: ==14:Talking
    14:31:46 [737829] 1: SetTalkMode[1,1]
    14:32:13 [738099] 0: 131=REGISTER
    14:32:13 [738101] 0: 131=REGISTER_AUTHN
    14:32:13 [738103] 1: 10007=REGISTER
    14:32:13 [738104] 0: 131=REGISTERED
    14:32:14 [738106] 1: 10007=REGISTER_AUTHN
    14:32:14 [738107] 1: 10007=REGISTERED
    14:32:46 [738429] 0: Fxs Hangup
    14:32:46 [738429] 0: Bye at Talking
    14:32:46 [738429] 0: ==3:Idle
    14:32:46 [738429] 0: SetFax(1)=0
    14:32:46 [738429] 0: SetModem(0)=-1
    14:32:46 [738429] 1: ==15:PlayBusyTone
    14:32:47 [738440] 1: Fxo Detected BTC(0)
    14:32:47 [738440] 1: FxoHookOn
    14:32:47 [738440] 1: ==3:Idle
    14:32:47 [738440] 1: InputGain(6)
    14:32:47 [738440] 1: SetFax(1)=0
    14:32:47 [738440] 1: SetModem(0)=-1
СообщениеДобавлено: Чт сен 27, 2012 13:59
Еще один обрыв разговора:
    14:53:27 [750840] 1: Fxo Ringing
    14:53:27 [750840] 1: CallerId=
    14:53:27 [750840] 1: ==17:WaitAnswerDeviceOk
    14:53:27 [750840] 1: HotLineEnabled with [131]
    14:53:27 [750840] 1: End Input Default Route [0]
    14:53:27 [750840] 1: Local Calling Fxs [131]
    14:53:27 [750840] 1: ==7:Inviting
    14:53:27 [750840] 0: Local Called By Line 1
    14:53:27 [750841] 0: ==12:Alerting
    14:53:27 [750841] 1: ==8:RingBack
    14:53:27 [750841] 1: RingTime(103) First Stop
    14:53:31 [750881] 1: RingTime(513) Second Ring
    14:53:37 [750934] 0: Fxs Pickup
    14:53:37 [750934] 0: Local Talk at ToAnswer
    14:53:37 [750934] 0: RtpApiTalk[1,1], Peer=192.168.1.240:9002, PT=0, FC=4, NewOOB=0
    14:53:37 [750934] 1: Local Talk at RingBack
    14:53:37 [750934] 1: FxoHookOff
    14:53:37 [750934] 1: InputGain(9)
    14:53:37 [750934] 1: RtpApiTalk[0,0], Peer=192.168.1.240:9000, PT=0, FC=4, NewOOB=0
    14:53:37 [750934] 0: ==14:Talking
    14:53:37 [750934] 1: ==14:Talking
    14:53:37 [750935] 1: SetTalkMode[1,1]
    14:57:10 [753070] 1: Fxo Detected BTC(9)
    14:57:10 [753070] 1: Bye at Talking
    14:57:10 [753071] 1: ==15:PlayBusyTone
    14:57:11 [753071] 0: ==15:PlayBusyTone
    14:57:11 [753071] 1: FxoHookOn
    14:57:11 [753071] 1: ==3:Idle
    14:57:11 [753071] 1: InputGain(6)
    14:57:11 [753071] 1: SetFax(1)=0
    14:57:11 [753071] 1: SetModem(0)=-1
    14:57:15 [753116] 0: Fxs Hangup
    14:57:15 [753116] 0: ==3:Idle
    14:57:15 [753116] 0: SetFax(1)=0
    14:57:15 [753116] 0: SetModem(0)=-1
СообщениеДобавлено: Чт сен 27, 2012 14:31
Нет ли где нибудь развернутого мануала по железке?
Чтоб описывался каждый пункт, всех разделов настроек, например:
пункт PSTN Answer Detection : отвечает за то-то, при выборе параметра ххх, происходит то-то, а при выборе yyy, работает так-то
если есть, дайте пожалуйста ссылочку, возможно изучив девайс более детально, не будет возникать вопросов по настройке :)
P.S. проблема с обрывами связи актуальна до сих пор :(
СообщениеДобавлено: Чт сен 27, 2012 14:45
Обновление проблем:
В течении разговора отчетливо слышны (обоим сторонам разговора) громкие неприятные щелчки, чем то схожие с импульсным набором, только одиночные с разным интервалом.
СообщениеДобавлено: Чт сен 27, 2012 16:32
Ввыложите лог.
СообщениеДобавлено: Чт сен 27, 2012 16:34
Логи (2шт.) двумя постами выше.
По поводу мануала, что ответите?
