Текущее время: Вт сен 29, 2026 16:04
 Заголовок сообщения: Проблема с 3627!!!
СообщениеДобавлено: Пт июн 08, 2012 12:31
64 bytes from 192.168.224.29: icmp_req=85 ttl=254 time=2.10 ms
64 bytes from 192.168.224.29: icmp_req=86 ttl=254 time=3.30 ms
64 bytes from 192.168.224.29: icmp_req=87 ttl=254 time=1.70 ms
64 bytes from 192.168.224.29: icmp_req=88 ttl=254 time=2.08 ms
64 bytes from 192.168.224.29: icmp_req=89 ttl=254 time=1.63 ms
64 bytes from 192.168.224.29: icmp_req=90 ttl=254 time=1.64 ms
64 bytes from 192.168.224.29: icmp_req=91 ttl=254 time=1.85 ms
64 bytes from 192.168.224.29: icmp_req=92 ttl=254 time=2.09 ms
64 bytes from 192.168.224.29: icmp_req=93 ttl=254 time=651 ms
64 bytes from 192.168.224.29: icmp_req=94 ttl=254 time=663 ms
64 bytes from 192.168.224.29: icmp_req=95 ttl=254 time=687 ms
64 bytes from 192.168.224.29: icmp_req=96 ttl=254 time=686 ms
64 bytes from 192.168.224.29: icmp_req=97 ttl=254 time=708 ms
64 bytes from 192.168.224.29: icmp_req=127 ttl=254 time=702 ms
64 bytes from 192.168.224.29: icmp_req=128 ttl=254 time=674 ms
64 bytes from 192.168.224.29: icmp_req=129 ttl=254 time=737 ms
64 bytes from 192.168.224.29: icmp_req=130 ttl=254 time=643 ms
64 bytes from 192.168.224.29: icmp_req=131 ttl=254 time=496 ms
64 bytes from 192.168.224.29: icmp_req=132 ttl=254 time=449 ms
64 bytes from 192.168.224.29: icmp_req=133 ttl=254 time=345 ms
64 bytes from 192.168.224.29: icmp_req=134 ttl=254 time=322 ms
64 bytes from 192.168.224.29: icmp_req=135 ttl=254 time=93.1 ms
64 bytes from 192.168.224.29: icmp_req=136 ttl=254 time=4.33 ms
64 bytes from 192.168.224.29: icmp_req=137 ttl=254 time=2.17 ms
64 bytes from 192.168.224.29: icmp_req=138 ttl=254 time=1.78 ms
64 bytes from 192.168.224.29: icmp_req=139 ttl=254 time=2.20 ms
64 bytes from 192.168.224.29: icmp_req=140 ttl=254 time=1.81 ms
с периодичностью в 2-3 минуты происходит вот такое действо. Загрузка CPU 100% продолжается секунд 30 потом опять нормально и через 2-3 минуты снова тоже самое..
 Заголовок сообщения: Re: Проблема с 3627!!!
СообщениеДобавлено: Пт июн 08, 2012 13:19
Добрый день. Пожалуйста, пришлите мне конфигурационный файл и tech_support информацию снятую во время скачков загрузки CPU.
Бигаров Руслан.
СообщениеДобавлено: Пт июн 08, 2012 14:22
выслать куда?
СообщениеДобавлено: Пт июн 08, 2012 14:24
выслал
СообщениеДобавлено: Пт июн 08, 2012 16:06
Письма не вижу. Вы ссылку на этот топик в письме указывали? На rbigarov высылали?
Бигаров Руслан.
СообщениеДобавлено: Сб июн 09, 2012 13:31
Да! выслал еще раз!
СообщениеДобавлено: Сб июн 09, 2012 16:54
аналогичную тему поднимал я, вроде можно дебаг прошивкой посмотреть загрузку пароца, интерфал ровно 3 минуты
Network, scripting, perl, SNMP. D-Link DGS-3627G, DGS-3620-28SC, DES-3200-26/A1/B1/C1, DES-3200-52/C1, DES-3526, DXS-3326GSR, DES-3028. Alcatel-Lucent OmniSwitch 6850-U24X, OmniStack 6224. Extreme X670-48x. ZTE ZXR10 5928E-FI, ZXR10 2928E, ZXR10 2952E.
СообщениеДобавлено: Сб июн 09, 2012 20:14
loopdetect включен? если включен - то как?
в логах, во время этого феерического шоу, что-нибудь появляется?
СообщениеДобавлено: Ср июн 13, 2012 05:23
нет, в логах ничего нет:( Руслан получили письмо?
СообщениеДобавлено: Ср июн 13, 2012 12:01
Так и не пришло. Пожалуйста, попробуйте с другого e-mail-а прислать.
Бигаров Руслан.
СообщениеДобавлено: Ср июн 13, 2012 14:39
переслал
СообщениеДобавлено: Пт июн 15, 2012 14:09
СообщениеДобавлено: Пн июн 18, 2012 16:29
Добрый вечер. Извиняюсь за задержку, был занят. Я ответил Вам на почту.
Бигаров Руслан.
СообщениеДобавлено: Пт авг 17, 2012 13:16
Проблема не решена. Приланная информация не помогла.
СообщениеДобавлено: Пт авг 17, 2012 13:18
аналогичная проблема началась с коммутаторами 3200 которые за 3627. Загрузка CPU в следствии чего идет потеря пакетов и впадание 3200 в полнейший ступор. через пару минут работа возобновляется и т.д
Сейчас этот форум просматривают: xocdia88mobile и гости: 90
