Текущее время: Пн авг 24, 2026 00:51
 Заголовок сообщения: DES-3526 + IPMB есть проблема
СообщениеДобавлено: Пн май 21, 2012 13:30
DES-3526
Boot PROM Version 5.00.011
Firmware Version 6.20.B09
Hardware Version A4
Активировал функцию IPMB и время от времени абоненты жалуются что пропадает интернет а на свитчах вот такой лог:
May 19 13:18:32 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 13:17:46 192.168.80.207 INFO: Successful login through Web (Username: admin, IP: 192.168.88.145, MAC: 00-00-00-00-00-00)
May 19 13:14:44 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 13:09:57 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 13:07:20 192.168.80.207 INFO: Configuration and log saved to flash (Username: SNMPUser, IP: 192.168.80.3, MAC: 00-15-17-0E-61-59)
May 19 13:07:07 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 13:04:19 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 13:01:30 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:57:42 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:52:54 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:50:06 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:47:20 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:44:32 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:36:27 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 169.254.63.146, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:36:22 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 169.254.63.146, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:36:14 192.168.80.207 INFO: Port 1 link up, 100Mbps FULL duplex
May 19 12:36:12 192.168.80.207 INFO: Port 1 link down
May 19 12:34:35 192.168.80.207 INFO: Port 1 link up, 10Mbps FULL duplex
May 19 12:34:32 192.168.80.207 INFO: Port 1 link down
May 19 12:33:05 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
May 19 12:31:16 192.168.80.207 WARN: Unauthenticated IP-MAC address and discarded by ip mac port binding (IP: 91.234.72.104, MAC: 14-DA-E9-19-B0-BD, port: 1)
Лечится перезагрузкой свитча. И что обидное это не только один коммутатор. С DES-3200 такой проблемы нет.
#show address_binding
Command: show address_binding
ACL_mode : Enabled
Trap/Log : Enabled
DHCP_Snoop : Enabled
ARP Inspection : Disabled
Command: show address_binding dhcp_snoop
config address_binding ip_mac ports 1,9 allow_zeroip enable
enable address_binding trap_log
config address_binding dhcp_snoop max_entry ports 1,9 limit 1
config address_binding dhcp_snoop max_entry ports 2-8,10-26 limit 5
Сервер DHCP выдает ip-адрес на 2 минуты.(сделано чтобы быстрее освобождать адреса, тех клиентов кто выключил комп).
В чем может быть пролмела?
Есть только миг между прошлым и будущим, именно он называется - ping.
 Заголовок сообщения: Re: DES-3526 + IPMB есть проблема
СообщениеДобавлено: Чт май 24, 2012 10:16
ip и MAC адрес правильные?
СообщениеДобавлено: Пн июн 04, 2012 15:01
вот в том то и дело что связка правильная. т.е. клиент получил адрес по dhcp если зайти на коммутатор то эта связка будет в IP-MAC Binding Blocked Table я жму на крестик удалить из блок-таблицы, но запись появляется снова, на одном коммутаторе было сразу несколько записей. Перезагрузил свитч - все заработало как надо.
вот еще заметил последний такой глюк был когда биллинг поменял клиенту влан. порта up-down ничего не исправили. только перезагрузка свитча.
СообщениеДобавлено: Пн июн 04, 2012 15:31
Опишите подробнее как биллинг это делает. Клиент был включен?
