Текущее время: Чт окт 01, 2026 23:16
 Заголовок сообщения: DGS-3100-24
СообщениеДобавлено: Чт май 10, 2012 14:50
Есть 3 коммутатора со старой прошивкой
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.0.04 Built 24-Oct-2007 18:51:36
Network Switch based on 88E6218 with ARM946E-S.
64MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
*** Running SW Ver. 2.00.47 Date 02-Mar-2008 Time 12:13:22 ***
HW version is 00.01.04
Base Mac address is: 00:21:91:fa:a7:8a
Dram size is : 64M bytes
Dram first block size is : 45056K bytes
Dram first PTR is : 0x1400000
Flash size is: 16M
01-Jan-2000 01:01:06 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:06 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
CPLD revision: 0.05
Slot 1 - DGS-3100-24 ST HW Rev. 0.5
-- Unit Number 3 --
Running eeprom code for 98DX249 Dev 4. Please wait...
01-Jan-2000 01:01:38 %INIT-I-InitCompleted: Initialization task is completed
-- Unit Number 3 Slave --
17-Jan-2000 07:46:30 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
Unit 3 lost connection with master
Unit rebooted: master initiated the reset
***************** SYSTEM RESET *****************
100%
100%
OK
Running from RAM...
Flash size is: 16M
CPLD revision: 0.05
-- Unit Number 3 --
01-Jan-2000 01:02:16 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
01-Jan-2000 01:03:20 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
Есть 2 коммутатора с новой прошивкой
BOOT Software Version 1.0.1.01 Built 12-Nov-2008 16:38:05
MAC Address : 00:24:01:d7:07:ad.
100%
100%
OK
Running from RAM...
*** Running SW Ver. 2.50.43 Date 30-Mar-2009 Time 23:21:36 ***
Serial Number : F3DR298000398.
HW version is: 00.00.a2
Base Mac address is: 00:24:01:d7:07:ad
Dram size is: 64M bytes
Flash size is: 16M bytes
-- Unit Number 1 --
Updating Database...
01-Jan-2000 01:01:37 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
01-Jan-2000 01:01:48 %INIT-I-InitCompleted: Initialization task is completed
-- Unit Number 1 Master Enabled --
01-Jan-2000 01:01:49 %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - opera
tional.
01-Jan-2000 01:01:49 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operati
onal.
Tapi Version: v1.3.3.1
Core Version: v1.3.3.1
01-Jan-2000 01:01:50 %SNMP-I-CDBITEMSNUM: Number of running configuration items
loaded: 1
01-Jan-2000 01:01:50 %SNMP-I-CDBITEMSNUM: Number of startup configuration items
loaded: 1
>01-Jan-2000 01:01:50 %Stack-I-STCK-CFG-CHNG: Configuration changed: chain
lcli
User Name:
При подключении новых коммутаторов, происходит постоянная перегрузка. Вопрос как мне перепрошится под одну версию?
 Заголовок сообщения: Re: DGS-3100-24
СообщениеДобавлено: Чт май 10, 2012 16:09
После включения питания коммутатора через консоль нажмите "ctrl"+"shift"+"-",затем сразу Esc.
В данное меню попасть достаточно сложно, с первого раза редко у кого получается.
Через него можно сменить номер коммутатора в стеке на "1" и затем после перезагрузки через CLI обновить BootPROM и прошивку.
СообщениеДобавлено: Пт май 11, 2012 07:23
Извините, а где взять актуальную BootPROM и прошивку.
СообщениеДобавлено: Пт май 11, 2012 07:58
Тут viewtopic.php?f=2&t=92700
СообщениеДобавлено: Пт май 11, 2012 09:05
При загрузке TFTP Download выдает ошибку Illegal software format
Пытаюсь загрузить BootPROM DGS-3100_series_A1A2_Boot_1.01.05.rfb
СообщениеДобавлено: Пт май 11, 2012 09:15
Приведите вывод с консоли.
Connection received from 10.90.90.90 on port 49154 [11/05 10:08:35.203]
Read request for file <DGS-3100_series_A1A2_Boot_1.01.05.rfb>. Mode octet [11/05 10:08:35.203]
Using local port 3154 [11/05 10:08:35.203]
Peer returns ERROR <Closed by application> -> aborting transfer [11/05 10:08:35.218]
СообщениеДобавлено: Пт май 11, 2012 09:17
Я имею ввиду что вам выводит в консоль коммутатор при вводе команд на загрузку boot prom.
Вы приложенный к прошивкам мануал читали?
СообщениеДобавлено: Пт май 11, 2012 09:19
Copy progress information:
Status: Copy Failed
Bytes transferred: 0
Error message: Illegal software format
Да читал
СообщениеДобавлено: Пт май 11, 2012 09:38
На новом коммутаторе стоит загрузчик 1.0.1.01 саму прошивку через tftpd32 он качает
А сам загрузчик нет
Незаконное программное обеспечение формата
СообщениеДобавлено: Пт май 11, 2012 10:09
Еще вопрос
Если у меня Boot version 1.0.1.01 могу установить прошивку DGS-3100-xx-3.60.44.ros
Если у меня Boot version 1.0.0.04 могу установить прошивку DGS-3100-xx-3.60.44.ros
СообщениеДобавлено: Ср май 16, 2012 10:25
Есть сегмент сети в котором используется около 5+ коммутаторов DGS-3100, несколько дней назад начались жуткие потери по пингам до этих свичей и большая задержка времени
Пакетов: отправлено = 95, получено = 61, потеряно = 34
(35% потерь)
Приблизительное время приема-передачи в мс:
Минимальное = 105мсек, Максимальное = 188 мсек, Среднее = 146 мсек
Обновил везде до 3.60.44, и бут до 1.01.05, отключили опрос по SNMP, включен трафик контроль 1-24 broadcast multicast, отключили веб управление только SSH. Не можем понять что с ними происходит работали до этого без сбоёв всё исправно было, в этом же сегменте полно DES-3200 и 3028 там всё в порядке. Если удаётся и зайти на DGS-3100 во время таких потерь загрузка цпу там
CPU utilization
Five seconds - 100% One minute - 99% Five minutes - 0%
Включили сейф гуард тоже не помогает:
Загрузка портов:
1:1 3214576 345208 0%
1:2 0 0 0%
1:3 0 0 0%
1:4 0 0 0%
1:5 0 0 0%
1:6 0 0 0%
1:7 0 0 0%
1:8 0 0 0%
1:9 10067024 16758048 1%
1:10 4647480 161888 0%
1:11 0 0 0%
1:12 3205136 0 0%
1:13 3220544 336 0%
1:14 17842440 9729504 1%
1:15 3255904 26504 0%
1:16 3215160 0 0%
1:17 0 0 0%
1:18 0 0 0%
1:19 0 0 0%
1:20 3210856 0 0%
1:21 0 0 0%
1:22 3225976 328 0%
1:23 0 0 0%
1:24 0 0 0%
DGS-3100# sh safeguard_engine
Safe Guard : Enable
Rising Threshold (20%-100%) : 70
Falling Threshold (20%-100%): 20
Status : No attack
Схема: агрегатор ZyXEL -> DES-3200-28 с вланом
VID : 41 VLAN Name : vlan41
VLAN Type : Static Advertisement : Disabled
Member Ports : 1-28
Static Ports : 1-28
Current Tagged Ports : 1-25,28
Current Untagged Ports : 26-27
Static Tagged Ports : 1-25,28
Static Untagged Ports : 26-27
Forbidden Ports :
Дальше с 27 порта (F) уходит на DGS-3100 который в свою очередь соединён с DES-3200-26 и далее опять же с ДГС уже уходит на другие ДГС-3100 и т.д. вообщем вроде как по звезде построено с элементами дерева...
Куда копать? Что это может быть?
СообщениеДобавлено: Чт май 17, 2012 07:35
Прощу прощения, используются именно DGS-3100-24TG
СообщениеДобавлено: Чт май 17, 2012 16:18
Приведите, пожалуйста, конфигурацию и лучше Telnet использовать, а не SSH, так как SSH дает большую нагрузку на CPU.
СообщениеДобавлено: Пт май 18, 2012 12:01
Конфиг
! DGS-3100-24TG Gigabit stackable L2 Managed Switch
! Configuration
! Firmware: Build 3.60.44
! Copyright(C) 2008 D-Link Corporation. All rights reserved.
! BASIC
disable telnet
create account admin admin password encrypted
! SNMP
disable snmp
create snmp community ******** view DefaultSuper read_write
! AUTHENTICATION
! NETWORK MONITORING
! LINK AGGREGATION
! PORT
config ports 1:20 state disable
config ports description 1:1 "net 41 1 switch - 41.6"
config ports description 1:2 "Chkalova 7"
config ports description 1:8 " "
config ports description 1:12 "Yuzhnaya 17"
config ports description 1:(15,19) "Mayakovskogo 14"
config ports description 1:18 "Bikovo_Polevaya 5"
config ports description 1:20 "Progress dom 42"
! VLAN
! FORWARDING TABLE
! BROADCAST STORM CONTROL
config traffic control 1:(1-24) state enable threshold 3500 storm_type multicast_broadcast
! PORT MIRRORING
! QOS
! MULTIPLE SPANNING TREE
! IGMP SNOOPING
! 802.1X
! SNTP
enable sntp
config sntp primary
config time_zone operator + hour 04 minute 00
! SSH
enable ssh
! SSL
! BASIC IP
config ipif System ipaddress *****/24 vlan default
! ROUTING TABLE
create iproute default *********
! ARP
! LACP
! PORT SECURITY
! STACK
! POE
! TRAFFIC SEGMENTATION
! ACCESS CONTROL LIST
! HISTORY
! SAFEGUARD
config safeguard_engine state enable rising 75
! DOWNLOAD
! LLDP
! MLD SNOOPING
! VOICE VLAN
config voice_vlan oui-table add 0001e3 description siemens_phone___________
config voice_vlan oui-table add 00036b description Cisco_phone_____________
config voice_vlan oui-table add 00096e description Avaya_phone_____________
config voice_vlan oui-table add 000fe2 description Huawei-3COM_phone_______
config voice_vlan oui-table add 0060b9 description nec-philips_phone_______
config voice_vlan oui-table add 00d01e description pingtel_phone___________
config voice_vlan oui-table add 00e075 description veritel_phone___________
config voice_vlan oui-table add 00e0bb description 3Com_phone______________
В течении пару дней методом отключения портов начиная с верхнего свича и ниже, выяснилось, что скорее всего это со свича ниже с 20 порта абонент чем то гадил в сеть, умышленно или нет - неизвестно, сейчас порт отключен и пока что всё нормально и пинги и цпу. Будем ждать звонка и проверять что у него там может быть... в логах ничего не пишется. Но вчера ночью проверял - с 10 раза удаётся зайти на SSH свича, далее отключаю 20 порт и пинг сразу переходит в 2мс. Если включить то сразу потери и от 100 до 300+ мс. Возможно он посылает множество UDP или еще чего-нибудь, но тогда не понятно почему на других DGS-3100-24TG которые находятся после него ниже или выше по сети наблюдалось тоже самое когда порт включен и есть линк от него + сессия в инет.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 56
