Текущее время: Вт ноя 10, 2026 13:35
СообщениеДобавлено: Пт май 04, 2012 09:02
Какова природа появления таких записей в логах:
5935 2012/05/04 08:29:06 Topology changed (Instance:0, port:26)
5934 2012/05/04 08:28:50 Topology changed (Instance:0, port:26)
5933 2012/05/04 08:28:44 Topology changed (Instance:0, port:26)
5932 2012/05/04 08:28:33 Topology changed (Instance:0, port:26)
5931 2012/05/04 08:28:04 Topology changed (Instance:0, port:26)
5930 2012/05/04 08:27:34 Topology changed (Instance:0, port:26)
5929 2012/05/04 08:27:19 Topology changed (Instance:0, port:26)
5928 2012/05/04 08:27:08 Topology changed (Instance:0, port:26)
5927 2012/05/04 08:26:16 Topology changed (Instance:0, port:26)
5926 2012/05/04 08:26:10 Topology changed (Instance:0, port:26)
5925 2012/05/04 08:26:04 Topology changed (Instance:0, port:26)
5924 2012/05/04 08:25:39 Topology changed (Instance:0, port:26)
5923 2012/05/04 08:24:36 Topology changed (Instance:0, port:26)
5922 2012/05/04 08:23:53 Topology changed (Instance:0, port:26)
5921 2012/05/04 08:23:26 Topology changed (Instance:0, port:26)
5920 2012/05/04 08:22:04 Topology changed (Instance:0, port:26)
5919 2012/05/04 08:21:15 Topology changed (Instance:0, port:26)
5918 2012/05/04 08:20:58 Topology changed (Instance:0, port:26)
5917 2012/05/04 08:16:47 Topology changed (Instance:0, port:26)
Какая топология меняется?
Обычно перестройка STP в логах отображается вот так:
4926 2012/04/10 09:51:47 CIST New Root bridge selected (Instance:0, MAC:00-1C-F0-9D-6D-D4, Priority:32768)
4925 2012/04/10 09:51:47 Topology changed (Instance:0, port:26)
Настройки STP по букварю:
config stp version mstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable
config stp priority 32768 instance_id 0
config stp mst_config_id name icube revision_level 13
config stp trap new_root enable topo_change enable
config stp ports 25-26 state enable
config stp ports 1-24 state disable
enable stp
config stp ports 1-24 externalCost auto hellotime 2 edge true p2p auto
config stp ports 1-24 fbpdu disable
config stp ports 1-24 restricted_role true
config stp ports 1-24 restricted_tcn true
config stp mst_ports 1-26 instance_id 0 internalCost auto priority 128
config stp ports 25-26 externalCost auto hellotime 2 edge false p2p auto
config stp ports 25-26 fbpdu enable
config stp ports 25-26 restricted_role false
config stp ports 25-26 restricted_tcn false
СообщениеДобавлено: Пт май 04, 2012 09:24
Та, в которой находится ваш коммутатор. Где-то генерируется tcn и от этого идут сообщения о смене топологии. Где - это скорее вопрос к вам.
Прошивка последняя?
СообщениеДобавлено: Пт май 04, 2012 09:32
Прошивка 6.20.b09. Может эти tsn приходят с других колец магистральника?
СообщениеДобавлено: Пт май 04, 2012 09:40
Вероятнее всего так и есть.
