Текущее время: Сб ноя 07, 2026 04:19
СообщениеДобавлено: Вт апр 24, 2012 10:05
DGS3612G
Boot PROM Version : Build 1.10-B09
Firmware Version  : Build 2.81.B03
Пытаюсь залить конфиг согласно инструкции:
snmpset -v2c -c XXXXXX $SWITCH 1.3.6.1.4.1.171.12.1.2.18.1.1.3.3 a $PC 1.3.6.1.4.1.171.12.1.2.18.1.1.5.3 s test.cfg 1.3.6.1.4.1.171.12.1.2.18.1.1.7.3 s STARTUP.CFG 1.3.6.1.4.1.171.12.1.2.18.1.1.14.3 i 1 1.3.6.1.4.1.171.12.1.2.18.1.1.8.3 i 3 1.3.6.1.4.1.171.12.1.2.18.1.1.12.3 i 3
В итоге получаю ошибку:
Error in packet.
Reason: commitFailed
Failed object: SNMPv2-SMI::enterprises.171.12.1.2.18.1.1.12.3
Содержание файла с конфигом:
#                      DGS-3612G Gigabit Ethernet Switch
#                                Configuration
#                           Firmware: Build 2.81.B03
#           Copyright(C) 2010 D-Link Corporation. All rights reserved.
delete access_profile 14
create access_profile profile_id 14 ip source_ip_mask 255.255.255.255
delete access_profile 13
create access_profile profile_id 13 ip source_ip_mask 255.255.255.255
delete access_profile 12
create access_profile profile_id 12 ip source_ip_mask 255.255.255.255
delete access_profile 11
create access_profile profile_id 11 ip source_ip_mask 255.255.255.255
delete access_profile 10
create access_profile profile_id 10 ip source_ip_mask 255.255.255.255
delete access_profile 9
create access_profile profile_id 9 ip source_ip_mask 255.255.255.255
delete access_profile 8
create access_profile profile_id 8 ip source_ip_mask 255.255.255.255
delete access_profile 7
create access_profile profile_id 7 ip source_ip_mask 255.255.255.255
delete access_profile 6
create access_profile profile_id 6 ip source_ip_mask 255.255.255.255
delete access_profile 5
create access_profile profile_id 5 ip source_ip_mask 255.255.255.255
delete access_profile profile_id 1
delete access_profile profile_id 2
create access_profile profile_id 1 ip destination_ip_mask 255.255.255.255
create access_profile profile_id 2 ip destination_ip_mask 255.255.255.255
#             End of configuration file for DGS-3612G
Что не так?
СообщениеДобавлено: Вт апр 24, 2012 11:26
Этот же конфиг заливается успешно командой cli:
download cfg_fromTFTP $PC src_file test.cfg increment
СообщениеДобавлено: Вт апр 24, 2012 11:31
Уважаемые сотрудники Dlink. Вы вообще сами проверяете, что советуете своим пользователям??
Вы мне прислалил команду, по которой надо заливать конфиг, но команда эта не работает. Я потратил 3 часа времени, разбираясь в чем проблема...А оказывается то команда неверная, а делать надо так:
snmpset -v2c -c XXXX $SWITCH 1.3.6.1.4.1.171.12.1.2.18.1.1.3.3 a $PC 1.3.6.1.4.1.171.12.1.2.18.1.1.5.3 s test.cfg 1.3.6.1.4.1.171.12.1.2.18.1.1.14.3 i 1 1.3.6.1.4.1.171.12.1.2.18.1.1.8.3 i 3 1.3.6.1.4.1.171.12.1.2.18.1.1.12.3 i 3
Найдите отличие от команды, которую посоветовали Вы:
СообщениеДобавлено: Вт апр 24, 2012 11:53
К сожалению, мы не располагаем документацией под каждую версию прошивки, так как в MIB'ах периодически происходят изменения и усовершенствования. Последнюю версию MIB можно найти здесь: ftp://ftp.dlink.ru/pub/Switch/DGS-3600%20Series/SNMP/DGS-3600_series_FW_2.80.B31_MIB.zip
А документацию мы подправим, спасибо за Ваше замечание.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 36
