Текущее время: Пт окт 02, 2026 18:45
 Заголовок сообщения: DGS-3420-28TC не работает snmp
СообщениеДобавлено: Чт апр 19, 2012 09:58
Свич DGS-3420-28TC, Boot PROM Version Build 1.00.006, Firmware Version Build 1.00.B032.
При команде snmpwalk -v2c -c public 192.168.0.1 snmp не отвечает: Timeout: No Response from 192.168.0.1
Конфиг:
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab031c7ee563c200
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
disable community_encryption
В логах D-Linka ничего не пишет. Однако если использовать несуществующее community, то пишет в логах:
SNMP request received from 192.168.0.2 with invalid community string!
 Заголовок сообщения: Re: DGS-3420-28TC не работает snmp
СообщениеДобавлено: Чт апр 19, 2012 10:05
enable snmp
СообщениеДобавлено: Чт апр 19, 2012 10:07
Artem Kolpakov писал(а):
enable snmp
Если бы было так просто :)
Сделано сразу же было, но не заработало.
Последний раз редактировалось vensder Чт апр 19, 2012 10:13, всего редактировалось 1 раз.
СообщениеДобавлено: Чт апр 19, 2012 10:12
enable snmp
Вот другой кусок конфига:
# MANAGEMENT
create trusted_host network x.y.z.0/24 snmp telnet ssh http https ping
enable snmp traps
enable snmp authenticate_traps
enable snmp linkchange_traps
enable snmp
config snmp linkchange_traps ports 1-28 enable
Не работает
СообщениеДобавлено: Чт апр 19, 2012 10:15
К тому же, как я указал в первом посте, если использовать несуществующее комьюнити, то d-link в логах это замечает:
snmpwalk -v2c -c bublic 192.168.0.1
Лог Dlinka:
160 2012-04-19 11:14:02 INFO(6) SNMP request received from x.y.z.f with invalid community string!
Последний раз редактировалось vensder Чт апр 19, 2012 11:07, всего редактировалось 1 раз.
СообщениеДобавлено: Чт апр 19, 2012 10:21
И еще: с фирмварью v1.00.023 также не работает
СообщениеДобавлено: Чт апр 19, 2012 13:29
На стенде все отрабатывает корректно.
Пришлите мне свой конфиг полностью и укажите в какой порт подключен хост с которого выполяете snmpwalk, я посмотрю
СообщениеДобавлено: Чт апр 19, 2012 13:49
snmpwalk делаем с порта MGMT - может, в этом проблема?
На какой e-mail выслать конфиг?
СообщениеДобавлено: Чт апр 19, 2012 13:54
у меня считывание через MGMT порт также проходит исправно.
Учтите, что хост тогда должен быть в подсети интерфейса коммутатора. Интерфейс MGMT не маршрутизируется
Почта - в моем профиле
СообщениеДобавлено: Чт апр 19, 2012 13:59
Похоже, дело в этом :)
Сейчас попробуем исправить, по результату отпишусь
СообщениеДобавлено: Чт апр 19, 2012 14:21
Большое спасибо за помощь - действительно, с любого другого порта, отличного от MGMT, работает. Мы из другой подсети snmpwalk делаем
СообщениеДобавлено: Чт апр 19, 2012 14:24
Пожалуйста
