Текущее время: Вс сен 20, 2026 19:30
 Заголовок сообщения: Aggregateport LACP DGS-3610-26G == DGS-3100-24TG
СообщениеДобавлено: Вс апр 15, 2012 23:17
Подскажите, пожалуйста, по каким причинам не поднимается линк по протоколу LACP?
По STATIC объединение линков проходит и работаетю
DGS-3610-26G#
DOIS-CORE(config-if-AggregatePort 1)#show lacp su
System Id:4096, f07d.68f0.6ae0
Flags: S - Device is requesting Slow LACPDUs F - Device is requesting Fast LACPDUs.
A - Device is in active mode. P - Device is in passive mode.
Aggregate port 1:
Local information:
LACP port Oper Port Port
Port Flags State Priority Key Number State
Gi0/1 SA susp 4096 0x1 0x1 0x45
Gi0/2 SA susp 4096 0x1 0x2 0x45
Partner information:
Port Flags Priority Dev ID Key Number State
Gi0/1 SP 0 0000.0000.0000 0x0 0x0 0x0
Gi0/2 SP 0 0000.0000.0000 0x0 0x0 0x0
(DGS-3100-24TG, LACP ID 61440, Trunking mode LACP)
DOIS-CORE(config-if-AggregatePort 1)#show interfaces aggregateport 1
Index(dec):25 (hex):19
AggregatePort 1 is DOWN , line protocol is DOWN
Hardware is Aggregate Link AggregatePort
Interface address is: no ip address
MTU 1500 bytes, BW 1000000 Kbit
Encapsulation protocol is Bridge, loopback not set
Keepalive interval is 10 sec , set
Carrier delay is 2 sec
Rxload is 1/255, Txload is 1/255
Switchport attributes:
interface's description:""
admin medium-type is Fiber, oper medium-type is Fiber
lastchange time:28 Day: 1 Hour:18 Minute:25 Second
Priority is 0
admin duplex mode is AUTO, oper duplex is Unknown
admin speed is AUTO, oper speed is Unknown
flow receive control admin status is OFF, flow send control admin status is OFF
flow receive control oper status is Unknown, flow send control oper status is Unknown
Storm Control: Broadcast is OFF, Multicast is OFF, Unicast is OFF
Port-type: access
Vlan id: 1
Aggregate Port Informations:
Aggregate Number: 1
Refs: 2
Members: (count=2)
DOIS-CORE(config-if-AggregatePort 1)#show interfaces gigabitEthernet 0/1
Index(dec):1 (hex):1
GigabitEthernet 0/1 is UP, line protocol is UP
Hardware is Broadcom 5464 GigabitEthernet
Description: Port1FromAP1G1LACP
ARP type: ARPA, ARP Timeout: 3600 seconds
interface's description:"Port1FromAP1G1LACP "
lastchange time:28 Day: 1 Hour:21 Minute: 2 Second
Priority is 0
admin duplex mode is AUTO, oper duplex is Full
admin speed is AUTO, oper speed is 1000M
flow receive control admin status is ON, flow send control admin status is ON
flow receive control oper status is ON, flow send control oper status is ON
Port-type: access
Vlan id: 1
5 minutes input rate 633787 bits/sec, 80 packets/sec
5 minutes output rate 56 bits/sec, 0 packets/sec
454861 packets input, 200103182 bytes, 0 no buffer, 0 dropped
Received 42350 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 abort
44667 packets output, 9796980 bytes, 0 underruns , 917 dropped
0 output errors, 0 collisions, 0 interface resets
 Заголовок сообщения: Re: Aggregateport LACP DGS-3610-26G == DGS-3100-24TG
СообщениеДобавлено: Пн апр 16, 2012 08:21
C какой стороны установлен active режим lacp?
СообщениеДобавлено: Пн апр 16, 2012 10:53
1. Коммутатор DGS-3100 настраивался через веб LACP для портов 21 и 22 с port-priority 61440 (далее настройки проверялись через CLI). Каким образом для этого коммутатора задать "mode active | passive" мне найти не удалось.
2. Коммутатор DGS-3610 настраивался естественно через CLI.
# lacp system-priority 4096
# interface range gi 0/1-2
# shutdown
# lacp port-priority 4096
# port-group 1 mode active
# end
# interface aggr 1
# no shutdown
СообщениеДобавлено: Пн апр 16, 2012 11:14
Установите на DGS-3100 актуальную версию прошивки и смотрите PVID на агрегированных портах. На DGS-3610 оставляйте active режим, на DGS-3100 он не настраивается. И включите порты на DGS-3610.
СообщениеДобавлено: Пн апр 16, 2012 18:33
Спасибо! Моя текущая прошивка чуть старше, чем выложенная на форуме 3.60.44.
Device Information
Device Type DGS-3100-24TG ST
Firmware Version 3.60.28 Subnet Mask 255.255.255.0
Hardware Version a2
Serial Number F3Q32A6000042(unit 1)
System Time 16/04/2012
System Up Time 50 days 8 hours 58 mins 58 seconds
Boot version 1.0.1.05
СообщениеДобавлено: Вт апр 17, 2012 08:26
Отпишитесь о результатах
СообщениеДобавлено: Вт апр 17, 2012 13:34
Безусловно, по итогам сделаю мини-отчёт...
Вчера была обновлена прошивка на 3100, на 3610 подняты интерфейсы до добавления в port-group 1. На 3100 на момент поднятия aggregateport 1 DGS-3610 отслежена сборка в "CH 1" двух сконфигурированных портов . В целом ситуация остаётся пока прежней, видимо, теперь нужно с PVID разобраться.
СообщениеДобавлено: Пт апр 20, 2012 00:16
Агрегация LACP не работала из-за того, что на интерфейсе "aggregateport 1" был включен flowcontrol
на портах, включённых в "port-group 1" (aggregateport 1)
Когда выключил flowcontrol, LACP заработал.
Aggregate port 1:
Local information:
Gi0/1 SA bndl 4096 0x1 0x1 0x3d
Gi0/2 SA bndl 4096 0x1 0x2 0x3d
Gi0/1 SA 61440 1cbd.b9db.eb2a 0x12d 0x16 0x3d
Gi0/2 SA 61440 1cbd.b9db.eb2a 0x12d 0x15 0x3d
СообщениеДобавлено: Пт апр 20, 2012 08:14
Спасибо за отчет.
Рад слышать, что все заработало.
