Текущее время: Ср авг 26, 2026 09:59
Начать новую тему Эта тема закрыта, Вы не можете редактировать и оставлять сообщения в ней.  [ Сообщений: 19 ]  На страницу 1, 2  След.
 Заголовок сообщения: Dir-300 B1 разрывы соединения.
СообщениеДобавлено: Чт апр 05, 2012 14:22
Имеется:
DIR-300
H/W: B1
F/W: 2.05
Тип соединения PPPoE.
Периодически пропадает инет.
Лечится перезагрузкой.
Вот что шепчут логи:
Apr 5 09:47:48 Time synchronized at 2012/04/05, 09:47:48.
Apr 5 09:47:47 Remote management is disabled.
Apr 5 09:47:47 Block WAN PING is disabled.
Apr 5 09:47:46 DMZ enabled (192.168.0.213).
Apr 5 09:47:46 VPN (L2TP) Pass-Through enabled.
Apr 5 09:47:46 VPN (IPSec) Pass-Through enabled.
Apr 5 09:47:46 VPN (PPTP) Pass-Through enabled.
Apr 5 09:47:46 Domain blocking disabled.
Apr 5 09:47:46 URL blocking disabled.
Apr 5 09:47:46 MAC filter disabled.
Apr 5 09:47:45 IPCP: secondary DNS address ххх.ххх.ххх.х.
Apr 5 09:47:45 IPCP: primary DNS address хх.ххх.хх.х.
Apr 5 09:47:45 IPCP: remote IP address ххх.ххх.ххх.х.
Apr 5 09:47:45 IPCP: local IP address ххх.ххх.ххх.ххх.
Apr 5 09:47:45 PAP authentication succeeded.
Apr 5 09:47:43 PPPoE: Received PADS for session1. (Session ID: 7e51)
Apr 5 09:47:43 PPPoE: Sending PADR for session1.
Apr 5 09:47:43 PPPoE: Received PADO for session1, from 00:23:33:de:80:1a.
Apr 5 09:47:43 PPPoE: Sending PADI for session1.
Apr 5 09:45:30 PPPoE: Sending PADI for session1.
Apr 5 09:45:25 PPPoE: Sending PADI for session1.
Apr 5 09:45:04 PPPoE: Sending PADI for session1.
Apr 5 09:44:54 PPPoE: Sending PADI for session1.
Apr 5 09:44:49 PPPoE: Sending PADI for session1.
Apr 5 09:44:29 PPPoE: Sending PADI for session1.
Apr 5 09:44:18 PPPoE: Sending PADI for session1.
Apr 5 09:44:13 PPPoE: Sending PADI for session1.
Apr 5 09:43:52 PPPoE: Sending PADI for session1.
Apr 5 09:43:42 PPPoE: Sending PADI for session1.
Apr 5 09:43:37 PPPoE: Sending PADI for session1.
Apr 5 09:43:17 PPPoE: Sending PADI for session1.
Apr 5 09:43:07 PPPoE: Sending PADI for session1.
Apr 5 09:43:02 PPPoE: Sending PADI for session1.
Apr 5 09:42:41 PPPoE: Sending PADI for session1.
Apr 5 09:42:31 PPPoE: Sending PADI for session1.
Apr 5 09:42:26 PPPoE: Sending PADI for session1.
Apr 5 09:42:06 PPPoE: Sending PADI for session1.
Apr 5 09:41:56 PPPoE: Sending PADI for session1.
Apr 5 09:41:51 PPPoE: Sending PADI for session1.
Apr 5 09:41:31 PPPoE: Sending PADI for session1.
Apr 5 09:41:21 PPPoE: Sending PADI for session1.
Apr 5 09:41:16 PPPoE: Sending PADI for session1.
Apr 5 09:40:55 PPPoE: Sending PADI for session1.
Apr 5 09:40:45 PPPoE: Sending PADI for session1.
Apr 5 09:40:40 PPPoE: Sending PADI for session1.
Apr 5 09:40:20 PPPoE: Sending PADI for session1.
Apr 5 09:40:10 PPPoE: Sending PADI for session1.
Apr 5 09:40:05 PPPoE: Sending PADI for session1.
Apr 5 09:39:45 PPPoE: Sending PADI for session1.
Apr 5 09:39:35 PPPoE: Sending PADI for session1.
Apr 5 09:28:05 PPPoE: Sending PADI for session1.
Apr 5 09:28:00 PPPoE: Sending PADI for session1.
Apr 5 09:27:40 PPPoE: Sending PADI for session1.
Apr 5 09:27:29 PPPoE: Sending PADI for session1.
Apr 5 09:27:24 PPPoE: Sending PADI for session1.
Apr 5 09:27:04 PPPoE: Sending PADI for session1.
Apr 5 09:26:54 PPPoE: Sending PADI for session1.
Apr 5 09:26:49 PPPoE: Sending PADI for session1.
Apr 5 09:26:44 PPPoE: Sending PADT for session1. (Session ID: 6a21)
Apr 5 09:26:43 PPP: Connection terminated.
Apr 5 09:26:33 PPP: No response to 14 LCP echo requests.
Apr 3 12:36:06 Time synchronized at 2012/04/03, 12:36:06.
Поведайте , прблема все таки в роутере или нет?
Какие пути пешения проблемы ?
DES-3028, DES-3526, DES-3200_28 C1/A1/B1, DES-3200_26 C1, DGS-3627G, DGS-3420-26SC A2, DGS-3420-28TC A1, DGS-3620-28SC A1-EI, DGS-3200-24 A1
 Заголовок сообщения: Re: Dir-300 B1 разрывы соединения.
СообщениеДобавлено: Пт апр 06, 2012 10:23
up
СообщениеДобавлено: Вс апр 08, 2012 10:05
аууу, кто - нибудь может все таки поможет?
СообщениеДобавлено: Пн апр 09, 2012 06:21
up
СообщениеДобавлено: Пн апр 09, 2012 09:51
А напрямую не смотрели, не замечали разрывов с такой же периодичностью?
СообщениеДобавлено: Пн апр 09, 2012 11:42
Попробуйте прошиться до версии 2.06.
http://ftp.dlink.ru/pub/Router/DIR-300_NRU/Firmware/
dir300b_v2.06_b9fe.bin
СообщениеДобавлено: Пн апр 09, 2012 12:16
hijke, кто провайдер? Не дом.ру случайно?
СообщениеДобавлено: Пн апр 09, 2012 22:17
Vadim Borisov
Напрямую все нормально.
Faraon2040
Спасибо, попробую.
Nite2
Нет.
ТТК
СообщениеДобавлено: Чт апр 19, 2012 14:48
Faraon2040
Перепрошивка не помогла , такая же ситуация. В логах тоже самое.
СообщениеДобавлено: Чт апр 19, 2012 18:45
Есть еще какие нибудь соображения?
СообщениеДобавлено: Чт апр 19, 2012 21:05
В пункте выделенным красным Изображение
Uploaded with ImageShack.us
у тебя где галочка стоит?
© Снимаю порчу с IP, благославляю Mac-адрес, полный отворот вирусов, antispyware-обереги!
© Спасибо алфавиту за любезно предоставленные буквы!
СообщениеДобавлено: Пт апр 20, 2012 08:05
Crypton
Да.Именно на том параметре она стоит.
СообщениеДобавлено: Пт апр 20, 2012 13:36
hijke писал(а):
Crypton
А PPTP или L2TP есть возможность попробовать?
СообщениеДобавлено: Пт апр 20, 2012 15:28
Теоретически можно попробовать.
Но нужен только PPPoE. Точнее его корректная работа.
СообщениеДобавлено: Пт апр 20, 2012 16:06
Ради эксперимента,попробуй)
