Текущее время: Вс ноя 01, 2026 10:48
 Заголовок сообщения: Re: DSL-2540U/BRU/C2 непонятная проблема.
СообщениеДобавлено: Ср мар 07, 2012 11:09
Oleg Syrbu писал(а):
Попробуйте прописать dns вручную.
Прописал, не помогает.
Проблема осталась.
knock-knock
СообщениеДобавлено: Пн мар 12, 2012 21:25
Вот, еще логи.
Опять же сессия была завершена ну и реконнект.
Mar 12 23:59:48 (none) daemon.crit pppd[296]: Clear IP addresses. Connection DOWN. 90
Mar 12 23:59:48 (none) daemon.crit pppd[296]: Clear IP addresses. PPP connection DOWN. 94
Mar 12 23:59:54 (none) daemon.notice pppd[296]: PPP: Start to connect ... 80
Mar 12 23:59:55 (none) daemon.crit pppd[296]: PPP server detected. 73
Mar 12 23:59:55 (none) daemon.crit pppd[296]: PPP session established. 77
Mar 12 23:59:57 (none) daemon.crit pppd[296]: PPP LCP UP. 64
Mar 12 23:59:58 (none) daemon.crit pppd[296]: Received valid IP address from server. Connection UP. 107
Mar 13 00:00:00 (none) daemon.crit pppd[296]: Clear IP addresses. Connection DOWN. 90
Mar 13 00:00:00 (none) daemon.crit pppd[296]: Clear IP addresses. PPP connection DOWN. 94
Mar 13 00:00:03 (none) user.debug syslog: route add default gw 92.46.31.34 2>/dev/null 92
Mar 13 00:00:07 (none) daemon.notice pppd[296]: PPP: Start to connect ... 80
Mar 13 00:00:09 (none) user.debug syslog: iptables -A FORWARD -o ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Mar 13 00:00:10 (none) user.notice igmp[685]: setsockopt IP_MSFILTER 74
Mar 13 00:00:10 (none) daemon.crit pppd[296]: PPP server detected. 73
Mar 13 00:00:11 (none) daemon.crit pppd[296]: PPP session established. 77
Mar 13 00:00:12 (none) user.notice igmp[685]: setsockopt IP_MSFILTER 74
Mar 13 00:00:13 (none) user.debug syslog: iptables -A FORWARD -i ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Mar 13 00:00:14 (none) user.debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 2>/dev/null 151
Mar 13 00:00:14 (none) user.debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 139
Mar 13 00:00:15 (none) user.debug syslog: iptables -I INPUT 1 -p tcp --dport 80 -i ppp_0_0_40_1 -j ACCEPT 111
Mar 13 00:00:16 (none) daemon.crit pppd[296]: PPP LCP UP. 64
Mar 13 00:00:18 (none) daemon.crit pppd[296]: Received valid IP address from server. Connection UP. 107
Mar 13 00:00:21 (none) user.debug syslog: kill -SIGTERM 685 65
Mar 13 00:00:23 (none) user.debug syslog: /bin/igmp ppp_0_0_40_1 & 73
Mar 13 00:00:23 (none) user.debug syslog: ifconfig ppp_0_0_40_1 mtu 1492 78
Mar 13 00:00:26 (none) user.notice igmp[1305]: igmp started! 67
Mar 13 00:00:27 (none) user.notice igmp[1305]: setsockopt - MRT_ADD_VIF 77
Mar 13 00:00:29 (none) user.debug igmp[1320]: iptables -D FORWARD -i ppp_0_0_40_1 -d 239.255.255.250 -j DROP 2>/dev/null 126
Mar 13 00:00:31 (none) user.debug igmp[1323]: iptables -t filter -I FORWARD 1 -i ppp_0_0_40_1 -d 239.255.255.250 -j ACCEPT 2>/dev/null 140
Mar 13 00:07:45 (none) user.warn dnsprobe[648]: dns query failed 72
Mar 13 00:07:47 (none) user.warn dnsprobe[648]: dns query failed 72
Mar 13 00:07:49 (none) user.warn dnsprobe[648]: dns query failed 72
Mar 13 00:07:49 (none) user.notice dnsprobe[648]: Primary DNS server Is Down... Switching To Secondary DNS server 121
На этой строке лог завершился.
Просто хочется понять, кто виноват ?
Модем, провайдер?
knock-knock
СообщениеДобавлено: Пт мар 16, 2012 17:04
После возникновения ошибки пингуются ли с ПК DNS провайдера?
СообщениеДобавлено: Пн мар 26, 2012 11:10
DNS провайдера не пингуется.
При этом вот такой лог на модеме.
Mar 26 13:59:37 (none) daemon.info pppd[321]: LCP terminated by peer 74
Mar 26 13:59:38 (none) daemon.info pppd[321]: Connect time 890.1 minutes. 79
Mar 26 13:59:38 (none) daemon.info pppd[321]: Sent 30797436 bytes, received 539142733 bytes. 98
Mar 26 13:59:42 (none) daemon.warn pppd[321]: Couldn't increase MRU to 1500 81
Mar 26 13:59:46 (none) daemon.notice pppd[321]: Connection terminated.... 79
Mar 26 13:59:53 (none) daemon.info pppd[321]: Sent PADT 61
Mar 26 13:59:57 (none) daemon.info pppd[321]: PPP session is 1227 71
Mar 26 13:59:58 (none) daemon.info pppd[321]: Using interface ppp0_0_40_1 79
Mar 26 13:59:59 (none) daemon.notice pppd[321]: Connect: ppp_0_0_40_1 <--> nas_0_0_40 91
Mar 26 13:59:59 (none) daemon.warn pppd[321]: Couldn't increase MRU to 1500 81
Mar 26 14:00:05 (none) daemon.notice pppd[321]: PAP authentication succeeded 82
Mar 26 14:00:05 (none) daemon.notice pppd[321]: peer from calling number 00:90:1A:A1:2B:29 authorized 107
Mar 26 14:00:07 (none) daemon.notice pppd[321]: local IP address 95.56.50.182 84
Mar 26 14:00:07 (none) daemon.notice pppd[321]: remote IP address 92.46.31.34 83
Mar 26 14:00:07 (none) daemon.notice pppd[321]: primary DNS address 95.56.237.24 88
Mar 26 14:00:07 (none) daemon.notice pppd[321]: secondary DNS address 212.154.163.162 91
Mar 26 14:00:11 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=95.56.45.43 DST=95.56.50.182 LEN=48 TOS=0x00 PREC=0x00 TTL=127 ID=42087 DF PROTO=TCP SPT=4982 DPT=135 WINDOW=65535 RES=0x00 SYN URGP=0 226
Mar 26 14:02:08 (none) user.warn dnsprobe[1236]: dns query failed 73
Mar 26 14:02:10 (none) user.warn dnsprobe[1236]: dns query failed 73
Mar 26 14:02:12 (none) user.warn dnsprobe[1236]: dns query failed 73
Mar 26 14:02:12 (none) user.notice dnsprobe[1236]: Primary DNS server Is Down... Switching To Secondary DNS server 122
knock-knock
СообщениеДобавлено: Пн мар 26, 2012 15:00
Если провайдерский dns недоступен, пропишите общедоступный 8.8.8.8.
СообщениеДобавлено: Пн апр 02, 2012 13:15
ИМХО, DNSы это все бред.
На моем тарифном плане сессия закрывается 2 раза в сутки, это 23-00 и 14-00, так вот.
В 23-00, восстановление сессии происходит без проблем, по простой причине, модемы не загружены запросами от клиентов, потому как в 23-00, просто никого нет в офисе.
А вот в 14-00, нагрузка на модемы совершенно другая, и они видимо её просто не выдерживают.
И я подозреваю, что это не проблема софта, а скорее всего это проблема заключена в железе.
Oleg Syrbu, Что скажете ???
knock-knock
СообщениеДобавлено: Вт апр 24, 2012 20:17
Oleg Syrbu, А что можете сказать, по этому логу ?
Apr 24 22:59:32 (none) daemon.crit pppd[292]: Clear IP addresses. Connection DOWN. 90
Apr 24 22:59:32 (none) daemon.crit pppd[292]: Clear IP addresses. PPP connection DOWN. 94
Apr 24 22:59:40 (none) daemon.notice pppd[292]: PPP: Start to connect ... 80
Apr 24 22:59:40 (none) daemon.crit pppd[292]: PPP server detected. 73
Apr 24 22:59:41 (none) daemon.crit pppd[292]: PPP session established. 77
Apr 24 22:59:48 (none) daemon.crit pppd[292]: PPP LCP UP. 64
Apr 24 22:59:49 (none) daemon.crit pppd[292]: Received valid IP address from server. Connection UP. 107
Apr 24 22:59:52 (none) user.debug syslog: route add default gw 92.46.31.34 2>/dev/null 92
Apr 24 22:59:53 (none) user.debug syslog: iptables -A FORWARD -o ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Apr 24 22:59:54 (none) user.debug syslog: iptables -A FORWARD -i ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Apr 24 22:59:54 (none) user.debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 2>/dev/null 151
Apr 24 22:59:54 (none) user.debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 139
Apr 24 22:59:55 (none) user.debug syslog: iptables -I INPUT 1 -p tcp --dport 80 -i ppp_0_0_40_1 -j ACCEPT 111
Apr 24 22:59:55 (none) user.debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_40_1 -p tcp --dport 30005 114
Apr 24 22:59:55 (none) user.debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_40_1 -p tcp --dport 30005 116
Apr 24 22:59:55 (none) user.debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_40_1 -p udp -s 192.168.5.4/29 --dport 30006 132
Apr 24 22:59:55 (none) user.debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_40_1 -p udp -s 192.168.5.4/29 --dport 30006 134
Apr 24 22:59:57 (none) user.debug syslog: ifconfig ppp_0_0_40_1 mtu 1492 78
Apr 24 23:00:01 (none) daemon.crit pppd[292]: Clear IP addresses. Connection DOWN. 90
Apr 24 23:00:01 (none) daemon.crit pppd[292]: Clear IP addresses. PPP connection DOWN. 94
Apr 24 23:00:08 (none) daemon.notice pppd[292]: PPP: Start to connect ... 80
Apr 24 23:00:11 (none) daemon.crit pppd[292]: PPP server detected. 73
Apr 24 23:00:11 (none) daemon.crit pppd[292]: PPP session established. 77
Apr 24 23:00:23 (none) daemon.notice pppd[292]: PPP: Start to connect ... 80
Apr 24 23:00:24 (none) daemon.crit pppd[292]: PPP server detected. 73
Apr 24 23:00:24 (none) daemon.crit pppd[292]: PPP session established. 77
Apr 24 23:00:31 (none) daemon.crit pppd[292]: PPP LCP UP. 64
Apr 24 23:00:32 (none) daemon.err pppd[292]: User name and password authentication failed. 97
Apr 24 23:00:33 (none) user.debug syslog: iptables -t nat -A PREROUTING -i br0 -p tcp --dport 80 -j DNAT --to 192.168.5.4 127
Apr 24 23:00:34 (none) user.debug syslog: iptables -t nat -I PREROUTING -i br0 -p udp --dport 53 -j DNAT --to 192.168.5.4 127
Apr 24 23:00:34 (none) user.debug syslog: /bin/dnsspoof 192.168.5.4 & 75
Apr 24 23:00:35 (none) daemon.notice pppd[292]: PPP: Start to connect ... 80
Apr 24 23:00:36 (none) daemon.crit pppd[292]: PPP server detected. 73
Apr 24 23:00:36 (none) daemon.crit pppd[292]: PPP session established. 77
Apr 24 23:00:37 (none) daemon.crit pppd[292]: PPP LCP UP. 64
Apr 24 23:00:50 (none) daemon.crit pppd[292]: Received valid IP address from server. Connection UP. 107
Apr 24 23:00:52 (none) user.debug syslog: route add default gw 92.46.31.34 2>/dev/null 92
Apr 24 23:00:57 (none) user.debug syslog: iptables -A FORWARD -o ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Apr 24 23:00:58 (none) user.debug syslog: iptables -A FORWARD -i ppp_0_0_40_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu 144
Apr 24 23:00:59 (none) user.debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 2>/dev/null 151
Apr 24 23:00:59 (none) user.debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_40_1 -s 192.168.5.0/255.255.255.248 -j MASQUERADE 139
Apr 24 23:01:02 (none) user.debug syslog: iptables -I INPUT 1 -p tcp --dport 80 -i ppp_0_0_40_1 -j ACCEPT 111
Apr 24 23:01:02 (none) user.debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_40_1 -p tcp --dport 30005 114
Apr 24 23:01:02 (none) user.debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_40_1 -p tcp --dport 30005 116
Apr 24 23:01:03 (none) user.debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_40_1 -p udp -s 192.168.5.4/29 --dport 30006 132
Apr 24 23:01:03 (none) user.debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_40_1 -p udp -s 192.168.5.4/29 --dport 30006 134
Apr 24 23:01:05 (none) user.debug syslog: ifconfig ppp_0_0_40_1 mtu 1492 78
Apr 24 23:01:15 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=109.110.88.5 DST=95.56.27.137 LEN=48 TOS=0x00 PREC=0x00 TTL=113 ID=54504 DF PROTO=TCP SPT=4880 DPT=5600 WINDOW=16384 RES=0x00 SYN URGP=0 228
Apr 24 23:01:17 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=89.169.47.244 DST=95.56.27.137 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=12941 DF PROTO=TCP SPT=57408 DPT=5600 WINDOW=8192 RES=0x00 SYN URGP=0 229
Apr 24 23:01:19 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=89.169.47.244 DST=95.56.27.137 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=14174 DF PROTO=TCP SPT=57408 DPT=5600 WINDOW=8192 RES=0x00 SYN URGP=0 229
Apr 24 23:01:25 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=89.169.47.244 DST=95.56.27.137 LEN=48 TOS=0x00 PREC=0x00 TTL=116 ID=16061 DF PROTO=TCP SPT=57408 DPT=5600 WINDOW=8192 RES=0x00 SYN URGP=0 229
Apr 24 23:01:29 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=176.104.92.101 DST=95.56.27.137 LEN=60 TOS=0x00 PREC=0x00 TTL=117 ID=12711 DF PROTO=TCP SPT=58633 DPT=5600 WINDOW=8192 RES=0x00 SYN URGP=0 230
Apr 24 23:04:50 (none) user.warn kernel: Wireless button pressed, check time expand to 10 seconds 103
Apr 24 23:06:08 (none) syslog.info -- MARK -- 51
Apr 24 23:11:37 (none) user.alert kernel: Intrusion -> IN=ppp_0_0_40_1 OUT= MAC= SRC=37.144.201.13 DST=95.56.27.137 LEN=52 TOS=0x04 PREC=0x00 TTL=117 ID=18826 DF PROTO=TCP SPT=65503 DPT=5600 WINDOW=8192 RES=0x00 SYN URGP=0 229
Больше всего удивила строка:
В особенности: Wireless button pressed
Как так ? Причем здесь Wireless ?
knock-knock
СообщениеДобавлено: Чт май 10, 2012 12:04
Раз уж мне никто не хочет ответить, отвечу я сам. :D
Проблема решена, установкой модемов TP-Link TD-8840T. :mrgreen:
Тему можно считать закрытой.
knock-knock
Сейчас этот форум просматривают: Baidu [Spider] и гости: 23
