Текущее время: Ср сен 30, 2026 23:27
 Заголовок сообщения: DGS-3610 похоже на баг
СообщениеДобавлено: Вт фев 14, 2012 07:55
Имеем
System description      : DGS-3610-26G Gigabit Ethernet Switch
System start time       : 2012-02-13 21:1:45
System uptime           : 0:11:41:22
System hardware version : A1.0
System software version : v10.4(3) Release(117920)
System BOOT version     : 10.3 Release(94612)
System CTRL version     : 10.3 Release(94612)
Device information:
  Device-1
    Hardware version : A1.0
    Software version : v10.4(3) Release(117920)
Фрагмент конфига используем PBR
track 1 rns 1
delay up 10 down 10
track 2 rns 2
delay up 10 down 10
track 3 rns 3
delay up 10 down 10
route-map For_Office deny 10
match ip address Local_network
route-map For_Office permit 20
match ip address Office1_network
set ip next-hop 172.28.200.4
route-map For_Office permit 30
match ip address Office2_network
set ip next-hop 172.28.200.5
route-map For_Office permit 40
match ip address Office3_network
set ip next-hop 172.28.200.112 1
route-map For_Office permit 50
match ip address Office_network
set ip next-hop verify-availability 172.28.200.5 5 track 1
set ip next-hop verify-availability 172.28.200.4 8 track 3
set ip next-hop verify-availability 172.28.200.112 3 track 2
route-map For_Users_in_Default deny 10
route-map For_Users_in_Default permit 20
match ip address network_0_5
set ip next-hop verify-availability 172.28.200.5 8 track 1
set ip next-hop verify-availability 172.28.200.4 5 track 3
route-map For_Users_in_Default permit 30
match ip address network_6-9_17
set ip next-hop verify-availability 172.28.200.112 8 track 2
set ip next-hop verify-availability 172.28.200.5 3 track 1
route-map For_Users_in_Default permit 40
match ip address network_10_16
ip access-list extended Local_network
10 deny ip any 172.0.0.0 0.31.255.255
20 deny ip any 37.9.64.0 0.0.63.255
30 deny ip any 77.88.0.0 0.0.63.255
40 deny ip any 84.201.128.0 0.0.63.255
50 deny ip any 87.250.224.0 0.0.31.255
60 deny ip any 93.158.128.0 0.0.63.255
70 deny ip any 95.108.128.0 0.0.127.255
80 deny ip any 100.43.64.0 0.0.31.255
90 deny ip any 130.193.32.0 0.0.31.255
100 deny ip any 141.8.128.0 0.0.63.255
110 deny ip any 178.154.128.0 0.0.127.255
120 deny ip any 199.21.96.0 0.0.3.255
130 deny ip any 199.36.240.0 0.0.3.255
140 deny ip any 213.180.192.0 0.0.31.255
160 deny ip any host 109.197.112.17
170 deny ip any host 109.197.112.26
ip access-list extended Office1_network
10 permit ip host 172.20.254.10 any
ip access-list extended Office2_network
10 permit ip host 172.20.254.9 any
ip access-list extended Office3_network
10 permit ip host 172.20.254.6 any
ip access-list extended Office_network
10 permit ip 172.20.254.0 0.0.0.255 any
ip access-list extended network_0_5
10 permit ip 172.28.0.0 0.0.0.255 any
20 permit ip 172.28.1.0 0.0.0.255 any
30 permit ip 172.28.2.0 0.0.0.255 any
40 permit ip 172.28.3.0 0.0.0.255 any
50 permit ip 172.28.4.0 0.0.0.255 any
60 permit ip 172.28.5.0 0.0.0.255 any
ip access-list extended network_10_16
10 permit ip 172.28.10.0 0.0.0.255 any
20 permit ip 172.28.11.0 0.0.0.255 any
30 permit ip 172.28.12.0 0.0.0.255 any
40 permit ip 172.28.13.0 0.0.0.255 any
50 permit ip 172.28.14.0 0.0.0.255 any
60 permit ip 172.28.16.0 0.0.0.255 any
ip access-list extended network_6-9_17
10 permit ip 172.28.6.0 0.0.0.255 any
20 permit ip 172.28.7.0 0.0.0.255 any
30 permit ip 172.28.8.0 0.0.0.255 any
40 permit ip 172.28.9.0 0.0.0.255 any
50 permit ip 172.28.17.0 0.0.0.255 any
ip rns 1
icmp-echo 172.28.200.5 source-ipaddr 172.28.200.10
frequency 4000
timeout 3000
ip rns 2
icmp-echo 172.28.200.112 source-ipaddr 172.28.200.10
frequency 4000
timeout 3000
ip rns 3
icmp-echo 172.28.200.4 source-ipaddr 172.28.200.10
frequency 4000
timeout 3000
Проблема номер 1 - когда меняешь вес у маршрута например было так
а стало
 set ip next-hop verify-availability 172.28.200.4 2 track 3
все равно пакеты проматченные бегут через прежний хоп. Чем больше цифра тем приоритетней вес маршрута. Это не работает.
Проблема номер 2 - проработав около недели такая схема, возникло следующее - у абонентов шли пинги до ядра сети но трасировка например до майла уже на первом хопе показывала * * * а не шлюз. Лечилось снятием no ip policy route-map с влан интерфейса и потом возвратом полиси на место. До этого чистил арп кэш не помогало. Помогите разобратся.
 Заголовок сообщения: Re: DGS-3610 похоже на баг
СообщениеДобавлено: Вт фев 14, 2012 11:27
1) по первому вопросу - включите глобально режим ip policy load-balance
2) во второму вопросу ничем помочь не могу, нужна диагностика....
СообщениеДобавлено: Вт фев 14, 2012 12:12
Включено было давно до PBR просто этот фрагмент не включил в спойлер. Имею то что описываю выше, бывает работает а бывает и не срабатывает если я вес маршруту меняю. Делаю затем так убиваю маршруты и заново прописываю их с нужным весом и все начинает бежать как положено.
А прошивка для ветки 10.4.3 у меня самая актуальная?
Так допустим у меня возникла проблема как сделать диагностику? Понимаю нужен полный конфиг + tech support.
P.S. Можно от вас совет быват иногда взлетает pps arp i igmp и вырастат загрузка cpu. Как с этим справится? Сеть частично фрагментирована на вланы но основная масса в дефолте. Оборудование все в управляющем влане, крупные узлы в своем управляющем интерфейсе.
Вот что сейчас
Main-DGS3610#sh cpu mboard
Type Pps Total Drop
tp-guard 0 0 0
arp 12 678123 473
dot1x 0 0 0
rldp 0 0 0
rerp 0 0 0
erps 0 0 0
bpdu 0 0 0
tunnel-bpdu 0 0 0
ipv4-icmp-local 0 0 0
lldp 0 0 0
lldp_cdp 0 0 0
cfm-pdu 0 0 0
dhcps-ipv4 0 0 0
dhcps-ipv6 0 0 0
gvrp 0 32515 0
tunnel-gvrp 0 0 0
dvmrp 0 0 0
igmp 4 506604 556
mld 0 0 0
ospf-v2 1 110588 0
pim-ipv4 0 1712 0
pim-ipv6 0 0 0
rip-ipv4 0 0 0
ripng 0 0 0
vrrp-ipv4 0 0 0
vrrp-ipv6 0 0 0
stargv 6 54219 0
stargvv6 0 0 0
unknown-ipmcv4 12 368611 0
bgp-ttl1 0 0 0
err-ttl0 0 0 0
err-ttl1 0 17418 0
ospf-v3 0 0 0
isis-es 0 0 0
isis-is 0 0 0
isis-l1is 0 0 0
isis-l2is 0 0 0
dhcpv6-client 0 0 0
dhcpv6-server 0 0 0
nd-snp-ns-na 0 0 0
nd-snp-rs 0 0 0
nd-snp-ra-redirect 0 0 0
ttl1-ipmcv6 0 0 0
error-hop-limit 0 0 0
unknown-ipmcv6 0 51893 0
dhcpv4-relay-c 0 13188 0
dhcpv4-relay-s 0 25 0
option82 0 0 0
udp-helper 0 0 0
dhcp-client 0 0 0
ip-packet-other 7 204376 0
grtd 0 0 0
reserved-multicast 1 35290 0
cisco-pvst 0 0 0
СообщениеДобавлено: Вт фев 14, 2012 15:15
1) Ситуация которую вы описываете теоретически возможна при рассинхронизации таблиц
Данное оборудование сильно нагружено? (по трафику)
При возникновении проблем... проверьте вывод команд
sh mac-table
sh ip arp
sh ip route A.B.C.D
sh ip route count
sh ip ref
sh ip ref route A.B.C.D
2) Предоставьте полный файл конфигурации
3) Чтобы что-то советовать желательно знать причину роста трафика для этого надо анализировать сеть целиком и значть как она устроена...есть ли защита и фильтрация на доступе, схема авторизация в сети и характер предоставляемых услуг...
СообщениеДобавлено: Чт мар 01, 2012 10:52
Выводы команд в момент проблемы. Помогает рестарт 3610. Сразу видим что проматченные сетки улетают на NAT с наибольшем весом как и положено при условии что трэкинг в состоянии up и переключений не было.Допустим бывает отваливается какой то сервис приходится руками менять роут мап. А потом возвращать на место как было. Но это не дело ребутаться после.
sh ip arp
ипы и маки не привожу их
Total number of ARP entries: 1624
sh ip route count
--------- route info ----------
the num of active route: 114
sh ip ref
-----------global statistic information-----------:
current routes: 115
alloc weight_nodes: 113
alloc bal_tables: 1
alloc adj_nodes: 1678
alloc res_adj: 3
**vrf statistic information**
Total Route(include FTN): 115
Reference Count: 1
sh ip ref route
IP/MASK s/res w adj_type next_hop mac interface
172.28.1.0/24 1/1 1 glean 0.0.0.0 0000.0000.0000 VLAN 1
Main-DGS3610#sh ip ref route 172.28.2.0 255.255.255.0
172.28.2.0/24 1/1 1 glean 0.0.0.0 0000.0000.0000 VLAN 1
Main-DGS3610#sh ip ref route 172.28.3.0 255.255.255.0
172.28.3.0/24 1/1 1 glean 0.0.0.0 0000.0000.0000 VLAN 1
Main-DGS3610#sh ip ref route 172.28.4.0 255.255.255.0
172.28.4.0/24 1/1 1 glean 0.0.0.0 0000.0000.0000 VLAN 1
Main-DGS3610#sh ip ref route 172.28.4.1 255.255.255.0
sh mac-address count
Main-DGS3610#sh mac-address count
Dynamic Address Count : 1271
Static Address Count : 0
Filtering Address Count: 0
Total Mac Addresses : 1271
Total Mac Address Space Available: 15113
По трафику утилизация некоторых портов не более 50 %.Остальные меньше. Cpu в основном не более 30 % Память 87 %
Конфиг вышлю вам в личку.
СообщениеДобавлено: Пт мар 02, 2012 14:12
Вот один из глюков!!! Конфиг не трогал абсолютно он у вас в личке.
С компа пингаю 172.28.31.13 не идет пинг. Трассирую 172.28.31.13 что это за фигня?? Тоже устройство из этой же подсети нормально пашет. Правила PBR не действуют на этот (влан 888)!
Дальше больше - делаю пинг с 3610 на 172.28.31.13 и все нормально начинает работать и трасировка становится вменяемой.
P.S. Пингаю из офисной сети на нее действует PBR но правила полиси написаны верно - сеть в соответствующем роут мапе 172.0.0.0 0.31.255.255 deny - это все что подпадает в этот диапозон бежит не на next-hop а бежит по стандартным правилам маршрутизации (смотрите мой конфиг).
Что это Максим?
СообщениеДобавлено: Вс мар 11, 2012 13:02
up
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 70
