Текущее время: Чт сен 10, 2026 07:16
 Заголовок сообщения: DG-104SH и Cisco AS5350
СообщениеДобавлено: Вт сен 13, 2005 13:28
Возникли проблемы при дозвоне с dlink(Firmware Version 1.0B58-G) на cisco
dlink и cisco регистрируются на aquagk
при включенном fast start и установленном предпочитаемом кодеке g711a проходит дозвон, соединение рветься через 8-9 сек. код завершения на cisco 41(29).
000266249 Dialing DEST = TEL:7xxxxxxxx (using GateKeeper)
000266249                SOURCE = NAME:bo12,TEL:0301
000266249                USER_TO_USER = CID_NAME:tcid0, CID_NUM:0301 SETUP
000266249 hsmup_open_rtp_sockets: nw_open(RTP1), port=16390, call_num=3
000266249 hsmup_open_rtp_sockets: nw_open(RTCP2), call_num=3, port=16391
000266249 HSMU 3: set timer for 50000 in state hsmup_state_h225_wait_alerting
000266268 HSMU 3: cmControlStateFastStart
000266268 HSMU 3: Starting Capabilities Exchange, capabilities_send=0
000266268 HSMU 3: Sending local capabilities.
000266268 HSMU 3: Chan 0o cmEvChannelSetRTCPAddress_msg IP = xxx.xxx.xxx.xxx, Port
 = 16405
000266268 HSMU 3: Chan 0o cmEvChannelSetAddress_msg IP = xxx.xxx.xxx.xxx, Port = 1
6404
000266268 HSMU 3: Chan 0o - cmChannelStateConnected "g729AnnexA"
       local RTCP = 0, remote RTCP =16405, RTP = xxx.xxx.xxx.xxx:16404
000266268 HSMU 3: Chan 0i cmEvChannelSetRTCPAddress_msg IP = xxx.xxx.xxx.xxx, Port
 = 16411
000266268 HSMU 3: Chan 0i - cmChannelStateConnected "g729AnnexA"
       local RTCP = 0, remote RTCP =16411, RTP = 0.0.0.0:0
000266268 HSMU 3: FS Chan 0i - offering channel "g729AnnexA"
000266269 HSMU 3: FS Chan 0i: Opened RTP socket = 1, cmChannel = 16390
000266269 HSMU 3: Chan 0i: Opened RTCP socket = 2, port 16391
000266269 HSMU 3: abort timer in state hsmup_state_h225_wait_alerting
000266269 HSMU 3: set timer for 2000 in state hsmup_state_fast_start_alerting_in
fo
000266269 HSMU 3: cmControlStateTransportConnected, Control channel opened for F
ast Start call.
000266293 HSMU 3: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000266453 HSMU 3: abort timer in state hsmup_state_fast_start_alerting_info
000266453 HSMU 3: set timer for 300 in state hsmup_state_fast_start_wait_complet
e
000266453 HSMU 3: set timer for 1000 in state hsmup_state_wait_set_coding_resp
000266553 HSMU 3: timer triggered in state hsmup_state_wait_set_coding_resp
000266553 HSMU 3: abort timer in state hsmup_state_wait_set_coding_resp
000266589 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000266877 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000267130 HSMU 3: VOICE CONNECTED, coding=g729AnnexA, FAST START mode, originati
ng
000267130 HSMU 3: set timer for 30000 in state hsmup_state_voice_connected
000267362 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000267676 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000267769 HSMU 3: abort timer in state hsmup_state_voice_connected
000267771 HSMU 3: set timer for 10000 in state hsmup_state_fax_channel
000267771 HSMU 3: abort timer in state hsmup_state_fax_channel
000267772 HSMU 3: H.323 release (IF)
000267823 HSMU 3: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP1, RTC
P2)
000267823 HSMU 3: nw_close(inchan local RTCP2, RTP1)
000267823 HSMU 3: nw_close(inchan local RTCP65535, RTP65535)
000267823 HSMU 3: nw_close(outchan local RTCP65535)
при установке кодека g729, результат такой же
000359104 HSMU: Enter call_profile->capabilities
000359114 HSMU: t.38 codec found at profile 6
000359114 HSMU: Exit call_profile->capabilities.
000359114 HSMU 6: Process outgoing H.323 Fast Start call.
000359114 Dialing DEST = TEL:xxxxxxx (using GateKeeper)
000359114                SOURCE = NAME:bo12,TEL:0301
000359114                USER_TO_USER = CID_NAME:tcid0, CID_NUM:0301 SETUP
000359114 hsmup_open_rtp_sockets: nw_open(RTP1), port=16396, call_num=6
000359114 hsmup_open_rtp_sockets: nw_open(RTCP2), call_num=6, port=16397
000359114 HSMU 6: set timer for 50000 in state hsmup_state_h225_wait_alerting
000359133 HSMU 6: cmControlStateFastStart
000359133 HSMU 6: Starting Capabilities Exchange, capabilities_send=0
000359133 HSMU 6: Sending local capabilities.
000359133 HSMU 6: Chan 0o cmEvChannelSetRTCPAddress_msg IP = xxx.xxx.xxx.xxx, Port
 = 16421
000359133 HSMU 6: Chan 0o cmEvChannelSetAddress_msg IP = xxx.xxx.xxx.xxx, Port = 1
6420
000359133 HSMU 6: Chan 0o - cmChannelStateConnected "g729AnnexA"
       local RTCP = 0, remote RTCP =16421, RTP = xxx.xxx.xxx.xxx:16420
000359134 HSMU 6: Chan 0i cmEvChannelSetRTCPAddress_msg IP = xxx.xxx.xxx.xxx, Port
 = 16427
000359134 HSMU 6: Chan 0i - cmChannelStateConnected "g729AnnexA"
       local RTCP = 0, remote RTCP =16427, RTP = 0.0.0.0:0
000359134 HSMU 6: FS Chan 0i - offering channel "g729AnnexA"
000359134 HSMU 6: FS Chan 0i: Opened RTP socket = 1, cmChannel = 16396
000359134 HSMU 6: Chan 0i: Opened RTCP socket = 2, port 16397
000359134 HSMU 6: abort timer in state hsmup_state_h225_wait_alerting
000359134 HSMU 6: set timer for 2000 in state hsmup_state_fast_start_alerting_in
fo
000359134 HSMU 6: cmControlStateTransportConnected, Control channel opened for F
ast Start call.
000359158 HSMU 6: cmEvCallMasterSlaveStatus_msg: Local station is Slave
000359313 HSMU 6: abort timer in state hsmup_state_fast_start_alerting_info
000359313 HSMU 6: set timer for 300 in state hsmup_state_fast_start_wait_complet
000359314 HSMU 6: abort timer in state hsmup_state_fast_start_wait_complete
000359314 HSMU 6: set timer for 1000 in state hsmup_state_wait_set_coding_resp
000359412 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000359413 HSMU 6: timer triggered in state hsmup_state_wait_set_coding_resp
000359413 HSMU 6: abort timer in state hsmup_state_wait_set_coding_resp
000359766 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000359852 HSMU 6: VOICE CONNECTED, coding=g729AnnexA, FAST START mode, originati
ng
000359852 HSMU 6: set timer for 30000 in state hsmup_state_voice_connected
000360245 HSMU RX RTCP DATA ERROR: ?rtcp pkt type=0
000360634 HSMU 6: abort timer in state hsmup_state_voice_connected
000360636 HSMU 6: set timer for 10000 in state hsmup_state_fax_channel
000360636 HSMU 6: abort timer in state hsmup_state_fax_channel
000360636 HSMU 6: H.323 release (IF)
000360688 HSMU 6: voice rtp open=0, rtcp open=0, nw_close(voice socked RTP1, RTC
P2)
000360688 HSMU 6: nw_close(inchan local RTCP2, RTP1)
000360688 HSMU 6: nw_close(inchan local RTCP65535, RTP65535)
000360688 HSMU 6: nw_close(outchan local RTCP65535)
при отключении fast_start соединение не происходит (тишина в трубке подключенной к dlink)
на cisco включены g729_r8, g711a, g723_r53, g723_r63.
 Заголовок сообщения: Re: DG-104SH и Cisco AS5350
СообщениеДобавлено: Вт сен 13, 2005 14:52
Модератор
Модератор
 = 16405
6404
 = 16411
fo
ast Start call.
e
ng
P2)
 = 16421
6420
 = 16427
fo
ast Start call.
ng
P2)
Попробуйте http://www.dlink.ru/phorum/viewtopic.php?t=481
Виктор Колосов
СообщениеДобавлено: Пт сен 16, 2005 11:39
да это помогло решить проблему с разрывом соединения.
но есть еще одна.
Периодически шлюз зависает в момент звонка. При этом в трубке тишина, на пинги не отвечает. Помогает только отключение питания.
С чем это может быть связано?
СообщениеДобавлено: Пн сен 26, 2005 11:33
IP-PBX member
на всех tcid пропишите номера и имена
Даешь связистов без брака!
AB4790-RIPE
СообщениеДобавлено: Пн сен 26, 2005 11:36
так и сделано
