Текущее время: Чт авг 06, 2026 19:35
Начать новую тему Ответить на тему  [ Сообщений: 33 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: RIP
СообщениеДобавлено: Ср фев 25, 2004 10:31
Есть 2 DES-3326S в сети с софтовыми роутерами. На обоих Firmware: Build 4.01-B27. Используется RIP2 Broadcast (да, не Multicast, но так сложилось). Проблема с назначением метрики.
Конфиг первого:
Command: show vlan
VID             : 1          VLAN Name     : default
VLAN TYPE       : static     Advertisement : Enabled
Member ports    : 6-26
Static ports    : 6-26
Current Untagged ports : 6-26
Static Untagged ports  : 6-26
Forbidden ports :
VID             : 4089       VLAN Name     : 10.5
Member ports    : 5
Static ports    : 5
Current Untagged ports : 5
Static Untagged ports  : 5
Forbidden ports :
VID             : 4090       VLAN Name     : 10.4
Member ports    : 4
Static ports    : 4
Current Untagged ports : 4
Static Untagged ports  : 4
Forbidden ports :
VID             : 4091       VLAN Name     : 10.111
Member ports    : 3
Static ports    : 3
Current Untagged ports : 3
Static Untagged ports  : 3
Forbidden ports :
VID             : 4092       VLAN Name     : 10.11
Member ports    : 2
Static ports    : 2
Current Untagged ports : 2
Static Untagged ports  : 2
Forbidden ports :
VID             : 4093       VLAN Name     : 10.1
Member ports    : 1
Static ports    : 1
Current Untagged ports : 1
Static Untagged ports  : 1
Forbidden ports :
Total Entries : 6
Command: show ipif
IP Interface Settings
Interface Name : 10.1_IF
IP Address     : 10.1.0.1        (MANUAL)
Secondary      : False
Subnet Mask    : 255.255.0.0
VLAN Name      : 10.1
Admin. State   : Enabled
Link Status    : Link UP
Member Ports   : 1
Interface Name : 10.4_IF
IP Address     : 10.4.0.2        (MANUAL)
Secondary      : False
VLAN Name      : 10.4
Member Ports   : 4
Interface Name : 10.5_IF
IP Address     : 10.5.0.1        (MANUAL)
Secondary      : False
VLAN Name      : 10.5
Member Ports   : 5
Interface Name : 10.11_IF
IP Address     : 10.11.0.1       (MANUAL)
Secondary      : False
VLAN Name      : 10.11
Member Ports   : 2
Command: show ipif
Secondary      : False
VLAN Name      : 10.1
Member Ports   : 1
Secondary      : False
VLAN Name      : 10.4
Member Ports   : 4
Secondary      : False
VLAN Name      : 10.5
Member Ports   : 5
Secondary      : False
VLAN Name      : 10.11
Member Ports   : 2
Interface Name : 10.111_IF
IP Address     : 10.111.0.1      (MANUAL)
Secondary      : False
VLAN Name      : 10.111
Member Ports   : 3
Interface Name : System
IP Address     : 192.168.0.175   (MANUAL)
Secondary      : False
Subnet Mask    : 255.255.255.0
VLAN Name      : default
Link Status    : Link DOWN
Member Ports   : 6-26
Total Entries : 6
Command: show rip
RIP Global State : Enabled
RIP Interface Settings
Interface      IP Address/Netmask  TX Mode   RX Mode   Authen-   State
                                                       tication
10.1_IF        10.1.0.1/16         V1 Comp.  V1 or V2  Disabled  Enabled
10.4_IF        10.4.0.2/16         V1 Comp.  V1 or V2  Disabled  Enabled
10.5_IF        10.5.0.1/16         V1 Comp.  V1 or V2  Disabled  Enabled
10.11_IF       10.11.0.1/16        V1 Comp.  V1 or V2  Disabled  Enabled
10.111_IF      10.111.0.1/16       V1 Comp.  V1 or V2  Disabled  Enabled
System         192.168.0.175/24    V1 Comp.  V1 or V2  Disabled  Enabled
Total Entries : 6
Конфиг второго:
Command: show vlan
Member ports    :
Static ports    :
Forbidden ports :
VID             : 4001       VLAN Name     : 10.0
Member ports    : 1
Static ports    : 1
Forbidden ports :
VID             : 4002       VLAN Name     : 10.2
Member ports    : 2
Static ports    : 2
Forbidden ports :
VID             : 4003       VLAN Name     : 10.3
Member ports    : 3
Static ports    : 3
Forbidden ports :
VID             : 4004       VLAN Name     : 10.4
Member ports    : 4
Static ports    : 4
Forbidden ports :
Total Entries : 5
Command: show ipif
Interface Name : 10.0_IF
IP Address     : 10.0.254.254    (MANUAL)
Secondary      : False
VLAN Name      : 10.0
Member Ports   : 1
Interface Name : 10.2_IF
IP Address     : 10.2.254.254    (MANUAL)
Secondary      : False
VLAN Name      : 10.2
Member Ports   : 2
Interface Name : 10.3_IF
IP Address     : 10.3.254.254    (MANUAL)
Secondary      : False
VLAN Name      : 10.3
Member Ports   : 3
IP Address     : 10.4.254.254    (MANUAL)
Secondary      : False
VLAN Name      : 10.4
Member Ports   : 4
IP Address     : 192.168.0.176   (MANUAL)
Secondary      : False
VLAN Name      : default
Member Ports   :
Total Entries : 5
Command: show rip
                                                       tication
10.0_IF        10.0.254.254/16     V1 Comp.  V1 or V2  Disabled  Enabled
10.2_IF        10.2.254.254/16     V1 Comp.  V1 or V2  Disabled  Enabled
10.3_IF        10.3.254.254/16     V1 Comp.  V1 or V2  Disabled  Enabled
10.4_IF        10.4.254.254/16     V1 Comp.  V1 or V2  Disabled  Enabled
System         192.168.0.176/24    V1 Comp.  V1 or V2  Disabled  Disabled
Total Entries : 5
Интерфейсы 10.4.0.2 и 10.4.254.254 в одной подсети.
В сетях 10.0.0.0/16 и 10.5.0.0/16 (10.5.0.100) есть софтовые роутеры ведущие в другие подсети.
Вот что собственно получается из этого
На первом:
Command: show iproute
Routing Table
IP Address/Netmask  Gateway          Interface     Hops      Protocol
0.0.0.0             10.4.254.254     10.4_IF       2         Default
10.0.0.0/16         10.4.254.254     10.4_IF       1         RIP
10.1.0.0/16         0.0.0.0          10.1_IF       1         Local
10.2.0.0/16         10.4.254.254     10.4_IF       1         RIP
10.3.0.0/16         10.4.254.254     10.4_IF       1         RIP
10.4.0.0/16         0.0.0.0          10.4_IF       1         Local
10.5.0.0/16         0.0.0.0          10.5_IF       1         Local
10.7.0.0/16         10.5.0.100       10.5_IF       1         RIP
10.8.0.0/16         10.4.254.254     10.4_IF       1         RIP
10.9.0.0/16         10.5.0.100       10.5_IF       1         RIP
10.11.0.0/16        0.0.0.0          10.11_IF      1         Local
10.12.0.0/16        10.5.0.100       10.5_IF       2         RIP
10.13.0.0/16        10.5.0.100       10.5_IF       2         RIP
10.14.0.0/16        10.5.0.100       10.5_IF       2         RIP
10.17.0.0/16        10.5.0.100       10.5_IF       3         RIP
10.18.0.0/16        10.5.0.100       10.5_IF       3         RIP
10.19.0.0/16        10.5.0.100       10.5_IF       3         RIP
10.111.0.0/16       0.0.0.0          10.111_IF     1         Local
195.68.241.70/32    10.5.0.100       10.5_IF       7         RIP
Total Entries : 19
На втором:
Routing Table
0.0.0.0             10.0.0.1         10.0_IF       2         Default
10.0.0.0/16         0.0.0.0          10.0_IF       1         Local
10.1.0.0/16         10.4.0.2         10.4_IF       1         RIP
10.2.0.0/16         0.0.0.0          10.2_IF       1         Local
10.3.0.0/16         0.0.0.0          10.3_IF       1         Local
10.5.0.0/16         10.4.0.2         10.4_IF       1         RIP
10.7.0.0/16         10.4.0.2         10.4_IF       1         RIP
10.8.0.0/16         10.0.0.2         10.0_IF       1         RIP
10.9.0.0/16         10.4.0.2         10.4_IF       1         RIP
10.11.0.0/16        10.4.0.2         10.4_IF       1         RIP
10.12.0.0/16        10.4.0.2         10.4_IF       2         RIP
10.13.0.0/16        10.4.0.2         10.4_IF       2         RIP
10.14.0.0/16        10.4.0.2         10.4_IF       2         RIP
10.17.0.0/16        10.4.0.2         10.4_IF       3         RIP
10.18.0.0/16        10.4.0.2         10.4_IF       3         RIP
10.19.0.0/16        10.4.0.2         10.4_IF       3         RIP
10.111.0.0/16       10.4.0.2         10.4_IF       1         RIP
195.68.241.70/32    10.4.0.2         10.4_IF       7         RIP
Total Entries : 19
Т.е. он не прибавляет 1 к полученной метрике от другово маршрутизатора. Что сделано не так? :?
Сеть, достижимая не прямо, а через один шлюз, имеет метрику 1, а должна иметь метрику 2. Как результат неверно выстраивается роутинг. Default маршрутам вручную прописана метрика 2.
СообщениеДобавлено: Сб фев 28, 2004 09:57
Может глупый вопрос и я что-то непонял в этом? Так скажите. Пойду еще чтонить почитаю.
СообщениеДобавлено: Пн мар 01, 2004 07:26
А если на TX mode сделать все на V2?
СообщениеДобавлено: Пн мар 01, 2004 08:58
Непомогает. На обоих свичах выставлял только TX_mode в v2_only и TX вместе с RX. Ситуация аналогична. Ничего неменяется. Даже включал и выключал RIP. Еще идеи есть?
СообщениеДобавлено: Пн мар 01, 2004 11:08
Редистрибьюция в RIP с какой метрикой настроена?
СообщениеДобавлено: Пн мар 01, 2004 11:50
Редистрибьюция в RIP откуда? Она возможно из OSPF и Static. OSPF не используется. Статических записей маршрутизации нет, за исключением default.
В Route Redistribution Settings ничего недобавлялось. Там пусто.
Route redistribution allows routers on the network − that are running different routing protocols − to exchange
routing information. Или в нашем случае тоже что-то необходимо?
СообщениеДобавлено: Пн мар 01, 2004 11:52
Из Local.
СообщениеДобавлено: Пн мар 01, 2004 12:02
Веб интерфейс.
Route Redistribution Settings - New
Source Protocol - LOCAL
Destination Protocol - RIP
Поля Type и Metric недоступны.
Жмем Apply. Результат - Source Protocol (LOCAL) and Destination Protocol (RIP) is Invalid.
СообщениеДобавлено: Пн мар 01, 2004 12:03
DU писал(а):
Веб интерфейс.
поле metric доступно.
СообщениеДобавлено: Пн мар 01, 2004 12:08
У меня поле Metric недоступно.
Попробовал в консоли.
Command: create route redistribute dst
Next possible completions:
ospf rip
Destination - Local отсутствует. :?:
СообщениеДобавлено: Пн мар 01, 2004 12:11
ospf rip
local - src, а не destination.
DES-3326S:4#create route redistribute dst rip src local metric 1
СообщениеДобавлено: Пн мар 01, 2004 12:26
Сорри уже торможу. Кстати, если зайти через Веб, то отображается правильно, но нажимаем Edit и всеравно поле Metric недоступно и там пусто.
Проделал на обоих. Выждал для порядка минут 5-7 чтобы обновилось. Ничего неизменилось :(
Продолжу эксперименты вечером. Убегаю.
СообщениеДобавлено: Пн мар 01, 2004 17:07
Там пусто, но оно доступно.
СообщениеДобавлено: Пн мар 01, 2004 19:18
Можете неверить, но у меня оно недоступно при раскладе Local и RIP.
Проблема не в том, что он передает с неправильной метрикой свои локальные маршруты, а в том что он не прибавляет 1 к метрике полученных маршрутов от других маршрутизаторов по RIPу. И отсюда следует что соседние с ним маршрутизаторы получают маршруты с заведомо неверной матрикой.
У меня сейчас есть ситуация, когда в таблице маршрутизации свича стоит метрика 1 на сеть, которая находится на софтовом маршрутизаторе, стоящем за еще одним таким свичем. А должна быть 3.
Никто не пользуется RIP или только у меня такие проблемы?
СообщениеДобавлено: Чт мар 04, 2004 08:56
DLinkовцы. У вас такое наблюдается?
Мануал мне не дал ответа на вопрос.
Может мне выслать вам полные конфиги чтобы вы проверили это?
