Текущее время: Вт ноя 10, 2026 11:44
Начать новую тему Ответить на тему  [ Сообщений: 38 ]  На страницу 1, 2, 3  След.
СообщениеДобавлено: Вс дек 11, 2011 07:25
Список изменений по сравнению с 1.34WW, build 08 Beta:
V 1.35WW, build 02, 2011/09/15, by MattC
1. UBICOM Based : Ubicom SDK 7.6.1 build 0185, 2011/08/10
2. Checksum: 0x0433B478
Problems Resolved:
1. Base on v1.35WWb01beta release occicial version
V 1.35WW, build 01Beta, 2011/09/07, by MattC
2. Checksum: 0x0432C659
Problems Resolved:
1. Set Access Control rule more than 1, and then change LAN ip, Access Control rule can't edit and remove.
V 1.35WW, build 01, 2011/08/23, by MattC
2. Checksum: 0x043370CF
Problems Resolved:
1. Add Realtek patch fix auto negotiation for Singapore issue
V 1.34WW, build 15 Beta, 2011/01/21, by MattC
1. UBICOM Based : Ubicom SDK 7.6.1 build 0183, 2010/12/10
2. Checksum: 0x043349B8
Problems Resolved:
1. Fix PPTP/L2TP dont support FQDN in DHCP relay environment.
V 1.34WW, build 14 Beta, 2011/01/11, by MattC
2. Checksum: 0x04337CAD
Problems Resolved:
1. Fix PPTP/L2TP dont support FQDN.
V 1.34WW, build 13 Beta, 2011/01/06, by MattC
2. Checksum: 0x04347847
Problems Resolved:
V 1.34WW, build 12 Beta, 2010/12/21, by MattC
2. Checksum: 0x0433EB8B
Problems Resolved:
1. Fix "CHAP only"/Always => PAP only/"On demand" or "Manual" will reboot when 3G Mode.
Step1. "Auto"/Always browser some website.
Step2. Change to "PAP only"/Always browser some website.
Setp3. Change to "CHAP only"/Always browser some website.
Setp4. Change to "PAP only"/"On demand" or "Manual" save and reboot.
Result : Router will reboot Continuously.
V 1.34WW, build 11 Beta, 2010/12/20, by MattC
2. Checksum: 0x0432AEF6
Problems Resolved:
1. Fix use http://www.speedtest.net test will reboot when 3G mode.
V 1.34WW, build 10 Beta, 2010/12/15, by MattC
2. Checksum: 0x0432E77F
Problems Resolved:
1. Fix DWM-152/156 A3 connection slow down and hard to access Internet website issue
Steps to Reproduce:
1. After DWM-152 A3 connected to Internet, make sure Internet access without problem (via LAN PC)
2. From LAN PC ping 8.8.8.8 ЎVt (check ping lost)
3. From LAN PC browser Internet website (Example, http://www.yahoo.com.tw)
Result: You could find Ў§PING LOSTЎЁ and Ў§HARD to browser Internet website)
V 1.34WW, build 09 Beta, 2010/12/13, by MattC
2. Checksum: 0x04357B7C
Problems Resolved:
1. Fix v1.34wwb08beta with DWM-152/156 A3 connection issue
Скачать можно здесь http://global.dlink.com.sg/site_support ... _FW135.zip
На DIR655 rev.A3 встала и работает без проблем.
DSL-2540U
DIR-655 A3
СообщениеДобавлено: Ср дек 14, 2011 15:47
Ощущение, что повысилась скорость pppoe приблизительно с 40 до 50 мбит/с. Быстрее производится рестарт маршрутизатора.
СообщениеДобавлено: Пн дек 19, 2011 11:02
Установил на На DIR655 rev.A5, трое суток работает, обрывов нет, всё стабильно.
А почему её нет на оффициальном FTP?
СообщениеДобавлено: Вт дек 20, 2011 21:06
Ситуация с резкой скорости на этой прошивке лучше не стала:(
СообщениеДобавлено: Ср дек 21, 2011 12:23
Скорее, странно, что её пока нет на нашем ftp - 135WWB02 по списку изменений имеет статус релиза для rev.A.
Кстати, интересно, будет ли поддержка IPv6 для ревизий A или это только для rev.B?
DSL-2540U
DIR-655 A3
СообщениеДобавлено: Вт янв 10, 2012 18:56
На DIR655 rev.A4, больше полумесяца uptime, ни единого обрыва, всё стабильно.
На российском FTP, прошка так и не появилась, странно.
СообщениеДобавлено: Ср янв 11, 2012 02:37
Почему уважаемые сотрудники D-Link как г-на в рот набрали по поводу такой долгожданной прошивки для rev.Ax? Даже одноименную тему закрыли! Многоуважаемые дистрибуторы, разве добросовестные покупатели DIR655 хотя бы через два года после покупки этого чудесного устройства не заслужили того, чтобы оно работало как вами было обещано - стабильно... а то заколебало по пять раз на дню кнопку на пилоте теребить. Займитесь своей работой, наконец. На какие ревизии можно ставить DIR655A4_FW135WWB02... эта прошивка оптимизирована для России... московским провайдерам она отвечает или нет? Выйдете, наконец, из сумрака...
СообщениеДобавлено: Чт янв 12, 2012 15:20
Те, кто поставил данную прошивку - подскажите пожалуйста: в ней есть режим подключения Russia PPTP?
СообщениеДобавлено: Чт янв 12, 2012 20:51
СообщениеДобавлено: Пт янв 13, 2012 10:19
iMe, спасибо большое!
СообщениеДобавлено: Вт янв 17, 2012 08:51
Однако больше года прошло... Ченжлоги не радуют, хотя сама прошивка (ее появление) - вещь ОТЛИЧНАЯ. Вот бы еще 249 DHCP опцию прикрутили - и вообще в ажуре бы все было.
СообщениеДобавлено: Вт янв 17, 2012 18:20
Установил на DIR-655 rev.A2, двое суток работает, всё стабильно и даже IPTV на STB нормально идет
СообщениеДобавлено: Ср янв 18, 2012 12:16
Эо, а что там с ченжлогами, где подвохи смотреть?
СообщениеДобавлено: Ср янв 18, 2012 12:25
Не радуют в смысле исправлений - для нас там ничего нет. Т.е. по функционалу она и 134бета08 одинаковы. И по набору недоделок тоже. Однако. Выход этой прошивки меня сподвиг на возобновление переписки с Д-линк, и, случилось чудо. :)
(ВНИМАНИЕ! ПРОШИВКА ЯВЛЯЕТСЯ ЭКСПЕРИМЕНТАЛЬНОЙ!!! АВТОР СООБЩЕНИЯ НЕ НЕСЕТ ОТВЕТСТВЕННОСТИ ЗА ПОРЧУ ОБОРУДОВАНИЯ!!!)
D-link Russia писал(а):
К сожалению, прошивки пишем не мы, их пишут на Тайване, по моему
вчерашнему запросу прошивку с поддержкой 249 опции мне только что
предоставили, разработчик оставляет за собой право как вносить новый
функционал, так и снимать устройство с производства.
Прошивка с поддержкой DHCP 249 Option.
СообщениеДобавлено: Ср янв 18, 2012 13:31
Это да, но в плане стабильности - небо и земля. Двадцать с лишним дней без единого обрыва.
249-ая - это передача маршрута на подсеть?
Сейчас этот форум просматривают: Google [Bot] и гости: 26
