Текущее время: Вт ноя 10, 2026 15:53
Начать новую тему Ответить на тему  [ Сообщений: 19 ]  На страницу Пред.  1, 2
 Заголовок сообщения: Re: dfl 210 - отваливается интернет
СообщениеДобавлено: Ср дек 21, 2011 05:22
В syslog receiver'е на вкладке Message Exceptions добавьте исключения (exclude) 6 CONN, 7 IP_PROTO, 60 RULE
Хотите считать с него трафик?
СообщениеДобавлено: Ср дек 21, 2011 10:47
<133>[2011-12-21 11:30:34] FW: SYSTEM: prio=2 id=03201000 rev=1 event=shutdown action=shutdown shutdown=NORMAL time=10 reason="Reboot requested from WebUI by admin (192.168.1.33)." 192.168.1.1 21/12 11:31:00.527
<133>[2011-12-21 11:31:43] FW: SYSTEM: prio=2 id=03202000 rev=2 event=startup_normal corever=2.27.03.25-14787 build="Nov 9 2010" uptime=0 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:30:34: Reboot requested from WebUI 192.168.1.1 21/12 11:32:07.742
<133>[2011-12-21 11:31:48] FW: SYSTEM: prio=2 id=03202001 rev=2 event=startup_echo delay=5 corever=2.27.03.25-14787 build="Nov 9 2010" uptime=5 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:30:34: Reboot requested from 192.168.1.1 21/12 11:32:12.742
<133>[2011-12-21 11:31:58] FW: SYSTEM: prio=2 id=03202001 rev=2 event=startup_echo delay=15 corever=2.27.03.25-14787 build="Nov 9 2010" uptime=15 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:30:34: Reboot requested fro 192.168.1.1 21/12 11:32:22.762
<132>[2011-12-21 11:32:20] FW: PPP: prio=3 id=02500101 rev=1 event=authentication_failed action=ppp_terminated tunnel_type=PPPoE user=vxxxxxx 192.168.1.1 21/12 11:32:44.912
<133>[2011-12-21 11:34:08] FW: SYSTEM: prio=2 id=03201000 rev=1 event=shutdown action=shutdown shutdown=RECONFIGURE time=2 reason="New IP (88.xxx.xxx.xxx) acquired by PPP interface "wan"" 192.168.1.1 21/12 11:34:33.521
<133>[2011-12-21 11:34:08] FW: PPPOE: prio=2 id=02600001 rev=1 event=pppoe_tunnel_up iface=wan pppoeserver=7c-20-64-84-74-b0 auth=CHAP ifaceip=88.xxx.xxx.xxx downtime=145 192.168.1.1 21/12 11:34:33.521
<133>[2011-12-21 11:34:10] FW: SYSTEM: prio=2 id=03202500 rev=1 event=shutdown action=shutdown shutdown=RECONFIGURE 192.168.1.1 21/12 11:34:35.775
<133>[2011-12-21 11:34:12] FW: SYSTEM: prio=2 id=03202000 rev=2 event=startup_normal corever=2.27.03.25-14787 build="Nov 9 2010" uptime=147 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:34:08: New IP (88.xxx.xxx.xxx) acqui 192.168.1.1 21/12 11:34:37.166
<133>[2011-12-21 11:34:17] FW: SYSTEM: prio=2 id=03202001 rev=2 event=startup_echo delay=5 corever=2.27.03.25-14787 build="Nov 9 2010" uptime=152 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:34:08: New IP (88.xxx.xxx.xxx) 192.168.1.1 21/12 11:34:42.166
<132>[2011-12-21 11:34:20] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=8 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=212.xxx.xxx.xxx connsrcport=50905 conndestif=lan conndestip=88 192.168.1.1 21/12 11:34:45.463
<132>[2011-12-21 11:34:21] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=8 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=81.xxx.xxx.xxx connsrcport=59855 conndestif=lan conndestip=88.xxx.xxx.xxx 192.168.1.1 21/12 11:34:46.728
<132>[2011-12-21 11:34:23] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=8 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=212.xxx.xxx.xxx connsrcport=54505 conndestif=lan conndestip=88 192.168.1.1 21/12 11:34:48.447
<133>[2011-12-21 11:34:27] FW: SYSTEM: prio=2 id=03202001 rev=2 event=startup_echo delay=15 corever=2.27.03.25-14787 build="Nov 9 2010" uptime=162 cfgfile="core.cfg" localcfgver=9 remotecfgver=0 previous_shutdown="2011-12-21 11:34:08: New IP (88.xxx.xxx.xxx 192.168.1.1 21/12 11:34:52.166
<132>[2011-12-21 11:34:28] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=8 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=213.xxx.xxx.xxx connsrcport=14096 conndestif=lan conndestip=88. 192.168.1.1 21/12 11:34:52.994
<132>[2011-12-21 11:34:28] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=2 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=81.xxx.xxx.xxx connsrcport=59711 conndestif=lan conndestip=88.xxx.xxx.xxx 192.168.1.1 21/12 11:34:53.338
<132>[2011-12-21 11:34:28] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=2 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=85.xxx.xxx.xxx connsrcport=4461 conndestif=lan conndestip=88.xxx.xxx.xxx 192.168.1.1 21/12 11:34:53.791
<132>[2011-12-21 11:34:30] FW: TCP_OPT: prio=3 id=03400019 rev=1 event=mismatching_tcp_window_scale action=adjust old=8 new=not_used effective=not_used connipproto=TCP connrecvif=wan connsrcip=213.xxx.xxx.xxx connsrcport=63237 conndestif=lan conndestip=88.8 192.168.1.1 21/12 11:34:55.228
<133>[2011-12-21 11:35:30] FW: SESMGR: prio=2 id=04900001 rev=1 event=sesmgr_session_created action=none user=admin database=AdminUsers ip=192.168.1.33 type=HTTPS 192.168.1.1 21/12 11:35:55.158
<133>[2011-12-21 11:35:30] FW: SYSTEM: prio=2 id=03203000 rev=1 event=admin_login authsystem=HTTPS username=admin access_level=administrator userdb=AdminUsers server_ip=192.168.1.1 server_port=443 client_ip=192.168.1.33 client_port=53296 192.168.1.1 21/12 11:35:55.160
<133>[2011-12-21 11:37:26] FW: PPPOE: prio=2 id=02600002 rev=1 event=pppoe_tunnel_closed iface=wan pppoeserver=7c-20-64-84-74-b0 uptime=195 192.168.1.1 21/12 11:37:51.488
СообщениеДобавлено: Ср дек 21, 2011 21:23
Уточняйте у провайдера, почему РРРоЕ сервер 7c-20-64-84-74-b0 вас выбивает
СообщениеДобавлено: Ср дек 28, 2011 09:14
Поставил, валявшийся долгое время dir 100 - пашет уже почти 2-е суток без обрывов. Но мне надо ipsec, поэтому помогите понять что происходит с dfl 210?
