Текущее время: Вт ноя 10, 2026 14:47
 Заголовок сообщения: DGS-3120-24 multicast
СообщениеДобавлено: Ср дек 14, 2011 13:12
Здравствуйте. Проблема с мультикастом на железке.
При таком конфиге работает:
#                    DGS-3120-24SC Gigabit Ethernet Switch
#                                Configuration
#                          Firmware: Build 2.00.B018
#           Copyright(C) 2011 D-Link Corporation. All rights reserved.
# IGMP_MULTICAST_VLAN
config igmp_snooping multicast_vlan forward_unmatched disable
# MLD_MULTICAST_VLAN
config mld_snooping multicast_vlan forward_unmatched disable
# VLAN
enable pvid auto_assign
config vlan default delete 1:1-1:24
config vlan default add untagged 1:1,1:3,1:5,1:7,1:9,1:11-1:24
config vlan default advertisement enable
create vlan 230 tag 230
config vlan 230 add tagged 1:24
config vlan 230 add untagged 1:2 advertisement disable
create vlan 294 tag 294
config vlan 294 add tagged 1:24
config vlan 294 add untagged 1:8 advertisement disable
create vlan 295 tag 295
config vlan 295 add tagged 1:24
config vlan 295 add untagged 1:10 advertisement disable
create vlan 2620 tag 2620
config vlan 2620 add tagged 1:24
config vlan 2620 add untagged 1:6 advertisement disable
create vlan 2626 tag 2626
config vlan 2626 add tagged 1:24
config vlan 2626 add untagged 1:4 advertisement disable
# STP
 config stp version rstp
 config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu disable hellotime 2 nni_bpdu_addr dot1d
 config stp priority 32768 instance_id 0
 config stp ports 1:1-1:24 externalCost auto  edge false p2p auto state enable restricted_role false restricted_tcn false
 config stp mst_ports 1:1-1:24 instance_id 0 internalCost auto priority 128
config stp ports 1:1-1:24 fbpdu disable
 config stp mst_config_id name 5C:D9:98:CA:10:43 revision_level 0
 config stp trap new_root enable
 config stp trap topo_change  enable
 disable stp
# MULTICAST_FILTER
# MCFILTER
# IGMP_SNOOPING
config igmp_snooping data_driven_learning max_learned_entry 128
config igmp_snooping vlan_name default fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name default query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version2
config igmp_snooping data_driven_learning vlan_name default state enable aged_out disable expiry_time 260
config igmp_snooping vlan_name 230 fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name 230 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 230 state enable aged_out disable expiry_time 260
config igmp_snooping vlan_name 294 fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name 294 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 294 state enable aged_out disable expiry_time 260
config igmp_snooping vlan_name 295 fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name 295 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 295 state enable aged_out disable expiry_time 260
config igmp_snooping vlan_name 2620 fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name 2620 query_interval 125 max_response_time  10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 2620 state enable aged_out disable expiry_time 260
config igmp_snooping vlan_name 2626 fast_leave disable  proxy_reporting state enable source_ip 0.0.0.0 state enable
config igmp_snooping querier vlan_name 2626 query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 2
config igmp_snooping data_driven_learning vlan_name 2626 state enable aged_out disable expiry_time 260
делаешь
enable igmp_snooping
перестает работать. В чем может быть проблема?
 Заголовок сообщения: Re: DGS-3120-24 multicast
СообщениеДобавлено: Ср дек 14, 2011 13:38
Приведите схему подключения и укажите откуда идёт мультикаст и где находятся клиенты.
СообщениеДобавлено: Ср дек 14, 2011 14:00
Cisco отдает Multicast через PIM > DGS-3120 uplink 24 > порты 1-23 DES-3200-28 > Абонент. Данный свитч агрегат на 6 домов (виланы 1, 230, 294, 295, 2620, 2626). Управление вынесено в отдельный вилан.
СообщениеДобавлено: Ср дек 14, 2011 14:20
Включите fast_leave, а также приведите конфиг DES-3200.
После включения igmp_snooping вы пробовали на клиентах попереключать каналы?
СообщениеДобавлено: Ср дек 14, 2011 14:41
На DES-3200 все нормально с конфигами, типовой используется на всей сети проблем нет, только за 3120. После включения igmp_snooping каналы пробовали переключать, ничего не работает. Включил fast_leave, затем enable igmp_snooping - мультикаст не перстал ходить. Как влияет включения fast_leave на передачу мультикаста?
СообщениеДобавлено: Ср дек 14, 2011 14:52
UPD. Подождал до timeout подписки в группах, мультикаст пропал. Сделал disable igmp_snooping ТВ заработало.
СообщениеДобавлено: Ср дек 14, 2011 15:43
Какая версия IGMP используется на Cisco? Пробовали вторую?
СообщениеДобавлено: Чт дек 15, 2011 01:46
На cisco вторая. Вторую пробовали, ситуация не меняется.
СообщениеДобавлено: Пн дек 19, 2011 16:36
2maddog
При включенном снупинге в абонентском влане попробуй
config igmp_snooping vlan <имя_VLAN> report_suppression disable
или, что то же самое,
config igmp_snooping vlanid <номер_VLAN> report_suppression disable
2D-Link:
Если не секрет - с какой целью в DGS-3120 добавили эту рогатку включенной по дефолту?
WBR, Serhio
СообщениеДобавлено: Пн дек 19, 2011 16:58
Serhio писал(а):
2maddog
Только нынче оно называется не report_suppression, а proxy_reporting.
Сейчас этот форум просматривают: Ivan Karbovskii и гости: 24
cron
