Текущее время: Чт окт 01, 2026 03:11
 Заголовок сообщения: DES-3200 и mac_based_access_control
СообщениеДобавлено: Сб дек 03, 2011 06:57
Есть стенд, состоящий:
1. свитч DES-3200-10
Boot PROM Version : Build 1.00.B004
Firmware Version : Build 1.52.B009
# VLAN
disable asymmetric_vlan
enable pvid auto_assign
config vlan default delete 1-10
config vlan default advertisement enable
config vlan default add tagged 10
config vlan default add forbidden 1-8
create vlan VLAN2 tag 2
config vlan VLAN2 add tagged 10
config vlan VLAN2 add untagged 1-2
create vlan VLAN999 tag 999
config vlan VLAN999 add tagged 10
create vlan VLAN1287 tag 1287
config vlan VLAN1287 add tagged 10
config vlan VLAN1287 add untagged 1
disable qinq
disable gvrp
config qinq ports 1-10 role nni outer_tpid 0x88A8 trust_cvid disable vlan_translation disable
config gvrp 1 state disable ingress_checking enable acceptable_frame admit_all pvid 1287
config gvrp 2 state disable ingress_checking enable acceptable_frame admit_all pvid 2
config gvrp 3-10 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# MBA
enable mac_based_access_control
disable authorization attributes
config mac_based_access_control authorization attributes radius enable
config mac_based_access_control authorization attributes local enable
config mac_based_access_control trap state enable
config mac_based_access_control log state enable
create mac_based_access_control guest_vlan VLAN999
config mac_based_access_control guest_vlan ports 1
config mac_based_access_control ports 1-2 state enable
config mac_based_access_control ports 3-10 state disable
config mac_based_access_control ports 1-10 mode host_based
config mac_based_access_control method radius
config mac_based_access_control auth_failover enable
config mac_based_access_control password pass
config mac_based_access_control max_users no_limit
create mac_based_access_control_local mac 00-13-77-5B-CA-62 vlanid 2
config mac_based_access_control ports 1-2 aging_time 1
config mac_based_access_control ports 1-2 max_users no_limit
2. Сервер FreeRadius, на котором заведена единственная учетка и в radreply есть запись
0013775BCA62 Tunnel-Private-Group-ID = 2
при подключении ноута в 1й порт сервер возвращает ответ
Sending Access-Accept of id 142 to 10.255.1.1 port 8021
Tunnel-Private-Group-Id:0 = "2"
Tunnel-Medium-Type:0 = IEEE-802
Tunnel-Type:0 = VLAN
3. В 10й порт DES3200-10 воткнута сеть, в которой есть что попинговать во 2м и в 1287м влане.
Если я убираю нетегированный 1й порт из 2го и 1287го влана, то при аутентификации свитч пишет
Port MAC Address Auth State VID Priority Aging Time/
Hold Time
1 00-13-77-5B-CA-62 Authenticated 1 - 55
причем, не важно, какой влан назначается ему через радиус. Будь то 2й или 1287.
Если добавить 1й порт во 2й влан и автоматом к нему приклеится pvid 2, то все нормально работает (на первый звгляд).
Hold Time
1 00-13-77-5B-CA-62 Authenticated 2 - 44
Добавляем 1й нетегированный порт в 1287 и автоматом к нему приклеится pvid 1287, то получается такая непонятная штука
1 00-13-77-5B-CA-62 Authenticated 1287 - 51
Т.е. можно, конечно засовывать неуатентичные МАСи в гостевой влан, но применять mac_based_access_control для того, чтобы еще и выбирать для правильных МАСов еще и влан через радиус или локальную базу mac_based_access_control_local НЕВОЗМОЖНО.
Попутно выяснял работает ли mac_based_vlan в случае назначения нетегированного порта в два влана. ТОЖЕ НЕ РАБОТАЕТ!
Скажите, это баг или фича такая? Та же самая схема на DGS-3200 работает на отлично. Там даже не надо назначать нетегированные порты ни в какой влан, свитч сам их назначает, согласно атрибутам аутентификации. К тому же в запросе на Радиус там есть еще и параметр NAS-Port, чего на DES3200 нет.
И второй вопрос, который вытекает из первого:
будет ли это исправлено или это на данной серии не возможно и не стоит ждать?
 Заголовок сообщения: Re: DES-3200 и mac_based_access_control
СообщениеДобавлено: Вт дек 06, 2011 10:32
Уточните, пожалуйста, какую задачу Вы хотите решить: как я понимаю проблема в том, что коммутатор не позволяет назначить через RADIUS VLAN ID для клиента?
СообщениеДобавлено: Вт дек 06, 2011 11:32
Задача такая.
Есть на коммутаторе несколько вланов плюс один гостевой.
Надо, чтобы коммутатор при аутентификации пользователя по МАСу получал от радиуса номер ВЛАНА, в который надо этот МАС засунуть. Радиус атрибуты отдает (см. мой пост выше), но свитч может отработать по этим атрибутам только тогда, когда на порту прописан PVID того влана в который надо втолкать МАС. Соответственно, если на порту есть, допустим, три МАС 1й - надо во влан2, 2й - надо во влан 1287, а о третьем вообще Радиус не знает. Получается картина, что если на порту в данный момент стоит PVID 2, то 1й МАС будет работать нормально, 2й попадет все равно во 2й влан, а третий, как и положено, окажется в гостевом влане.
Подытоживая, надо, чтобы свитч назначал МАСи во вланы согласно атрибутам радиуса, а не согласно PVID на порту.
В описании к DES3200 такой функционал заявлен, но не работает.
Кстати, еще и mac_based_vlan не работает нормально. Невозможно МАС, прописанный в таблице mac_based_vlan с назначенным валном засунуть в этот назначенный влан.
DGS3200 и DES3528 с такой задачей справляются нормально.
СообщениеДобавлено: Вт дек 06, 2011 11:46
Попробуйте выполнить команду: enable authorization attributes
СообщениеДобавлено: Вт дек 06, 2011 15:35
Спасибо огромное.
Работает вроде...
Видел эту команду, но сбило с толку то, что после нее идет включение атрибутов для радиуса и локальной базы.
Еще раз спасибо.
СообщениеДобавлено: Вт дек 06, 2011 15:44
Не за что. Рад слышать, что задача решена!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 85
