Текущее время: Пн авг 17, 2026 19:06
 Заголовок сообщения: 3100-24-TG + %Environment-W-PS-STAT-CHNG
СообщениеДобавлено: Чт сен 22, 2011 13:18
Давно стоит в ядре как L2 3100-24-TG и вот начал недавно странно себя вести. Бросает в сислог:
Sep 22 13:57:55 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:57:57 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:57:58 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:13 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:14 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:15 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:16 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:21 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:22 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:26 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:27 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:32 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:34 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:36 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:37 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:39 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:40 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:57 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:58:58 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:58:59 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:59:00 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:59:07 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:59:08 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 13:59:28 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 13:59:29 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Sep 22 14:00:14 192.168.254.8 %Environment-W-PS-STAT-CHNG: PS# 1 status changed - not operational.
Sep 22 14:00:15 192.168.254.8 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Никакими гуглениями выяснить расшифровку не удалось. Из наблюдений было замечено:
- Загрузка (холодная) свитча длится очень долго и при этом еще странная индикация
- После загрузки не заводятся некоторые порты. Помогает их ап-даун
- Уже в нормальном полете иногда можно встретить кратковременное отключение портов, но в логах этого нет
Firmware Version 3.60.24
Hardware Version 01
Serial Number F3DR17A000097(unit 1)
Molokanov kaN5300 Ilya
 Заголовок сообщения: Re: 3100-24-TG + %Environment-W-PS-STAT-CHNG
СообщениеДобавлено: Чт сен 22, 2011 13:27
Hardware Version 01
Может попробуете обновить прошивку?
2008-2015г. компания Экстрим Интернет. Технический директор/Главный системный администратор.
2015-по н.в. компания "Подряд". Инженер сети ШПД
СообщениеДобавлено: Чт сен 22, 2011 15:10
Нет возможности экспериментировать. К этому коммутатору 6к юзеров подключены. Уже заказали циску, вопрос лишь в том, о чем говорит этот меседж.
СообщениеДобавлено: Чт сен 22, 2011 15:28
У коммутатора проблема с блоком питания, нужно отнести его в СЦ для диагностики.
СообщениеДобавлено: Чт сен 22, 2011 15:40
Да, питальник "помирает" и пока ещё кое-как пытается держать нагрузку. В ремонт...
СообщениеДобавлено: Чт сен 22, 2011 15:54
ЁМАНАХ! Этоже наша узловая точка в продакшене. Спасибо за ответ!
СообщениеДобавлено: Чт сен 22, 2011 15:57
Не за что.
СообщениеДобавлено: Чт сен 22, 2011 16:23
такаяже история с ним-же
СообщениеДобавлено: Чт сен 22, 2011 16:31
И рекомендация та же.
СообщениеДобавлено: Пт сен 23, 2011 10:31
Всё! После очередного включения (уже на стенде) коммутатор умер. Делаем заявление в сервис. Успели заменить рано утром на другой коммутатор такойже модели.
СообщениеДобавлено: Пт сен 23, 2011 10:39
Предварительного заявления для обращения в сервис не требуется. Можете обратиться напрямую в ближайший к Вам: http://dlink.ru/ru/contacts/
Сейчас этот форум просматривают: Google [Bot] и гости: 16
