Текущее время: Ср сен 30, 2026 08:03
 Заголовок сообщения: Safeguard Engine DES-3200-28F
СообщениеДобавлено: Чт сен 15, 2011 15:45
Топология:
Network — 9:DES-3200-10:10 — DES-3200-28F:25
Network — обычная офисная сеть, нет броадкаст/арп и прочих штормов.
Конфиг на свитчах сброшен в ноль.
На свитчах создан один влан, ipif System в нем. Влан на всех портах тегирован.
Прошивка — 1.52.B005.
Логи:
DES-3200-10:5#sh log
Command: show log
Index Data Time Log Text
10 2011-09-15 15:28:48 Successful login through Telnet (Username: admin, IP:
10.21.5.5)
9 2011-09-15 15:27:56 Successful login through Console (Username: Anonymous)
8 2011-09-15 14:46:59 Telnet session timed out (Username: Anonymous, IP: 10.
21.5.5)
7 2011-09-15 14:46:23 Console session timed out (Username: Anonymous)
6 2011-09-15 14:36:58 Successful login through Telnet (Username: Anonymous,
IP: 10.21.5.5)
5 2011-09-15 14:36:23 Anonymous: execute command "save all"
4 2011-09-15 14:36:20 Configuration and log saved to flash by console (Usern
ame: Anonymous)
3 2011-09-15 14:36:16 Anonymous: execute command "config safeguard_engine st
ate enable mode fuzzy utilization rising 70 falling 40
2 2011-09-15 14:36:00 Anonymous: execute command "config time 15092011 14:36
:0"
1 0000-00-00 00:09:55 Anonymous: execute command "clear log"
DES-3200-28F:5#sh log
Command: show log
20 2011-09-15 15:35:34 Successful login through Telnet (Username: Anonymous,
IP: 10.21.5.5)
19 2011-09-15 15:28:59 Safeguard Engine enters NORMAL mode
18 2011-09-15 15:28:54 Safeguard Engine enters EXHAUSTED mode
17 2011-09-15 15:28:31 Successful login through Console (Username: Anonymous)
16 2011-09-15 15:26:13 Safeguard Engine enters NORMAL mode
15 2011-09-15 15:26:08 Safeguard Engine enters EXHAUSTED mode
14 2011-09-15 15:08:48 Safeguard Engine enters NORMAL mode
13 2011-09-15 15:08:43 Safeguard Engine enters EXHAUSTED mode
12 2011-09-15 14:56:53 Safeguard Engine enters NORMAL mode
11 2011-09-15 14:56:48 Safeguard Engine enters EXHAUSTED mode
10 2011-09-15 14:45:37 Console session timed out (Username: Anonymous)
9 2011-09-15 14:37:28 Safeguard Engine enters NORMAL mode
8 2011-09-15 14:37:23 Safeguard Engine enters EXHAUSTED mode
7 2011-09-15 14:37:10 Logout through Telnet (Username: Anonymous, IP: 10.21.
5.5)
IP: 10.21.5.5)
5 2011-09-15 14:35:37 Anonymous: execute command "save all"
4 2011-09-15 14:35:34 Configuration and log saved to flash by console (Usern
ame: Anonymous)
3 2011-09-15 14:35:18 Anonymous: execute command "config safeguard_engine st
2 2011-09-15 14:35:00 Anonymous: execute command "config time 15092011 14:35
:0"
1 0000-00-00 02:12:59 Anonymous: execute command "enable command logging"
В продакшене проблема имеет гораздо более ярко выраженный характер.
Суть проблемы — Safeguard Engine только на модели DES-3200-28F срабатывает постоянно и необоснованно (беспричинно), на рядом стоящих свитчах других моделей этой же серии ничего подобного не происходит. Из логов видно, что во время, когда сработал Safeguard Engine на DES-3200-28F, на DES-3200-10 все спокойно.
О проблеме знаю давно, но тестовый стенд удалось собрать только сейчас (не было свободных DES-3200-28F).
 Заголовок сообщения: Re: Safeguard Engine DES-3200-28F
СообщениеДобавлено: Пн сен 19, 2011 11:21
Теже самые свитчи, оставленные на пару дней:
Command: show log
60 2011-09-19 11:23:53 Successful login through Telnet (Username: Anonymous,
IP: 10.21.5.5)
59 2011-09-19 10:22:17 Safeguard Engine enters NORMAL mode
58 2011-09-19 10:22:12 Safeguard Engine enters EXHAUSTED mode
57 2011-09-19 08:57:36 Safeguard Engine enters NORMAL mode
56 2011-09-19 08:57:31 Safeguard Engine enters EXHAUSTED mode
55 2011-09-19 06:51:50 Safeguard Engine enters NORMAL mode
54 2011-09-19 06:51:45 Safeguard Engine enters EXHAUSTED mode
53 2011-09-19 02:13:43 Safeguard Engine enters NORMAL mode
52 2011-09-19 02:13:38 Safeguard Engine enters EXHAUSTED mode
51 2011-09-18 22:35:10 Safeguard Engine enters NORMAL mode
50 2011-09-18 22:35:05 Safeguard Engine enters EXHAUSTED mode
49 2011-09-18 21:59:35 Safeguard Engine enters NORMAL mode
48 2011-09-18 21:59:30 Safeguard Engine enters EXHAUSTED mode
47 2011-09-18 21:51:10 Safeguard Engine enters NORMAL mode
46 2011-09-18 21:51:05 Safeguard Engine enters EXHAUSTED mode
45 2011-09-18 21:06:04 Safeguard Engine enters NORMAL mode
44 2011-09-18 21:05:59 Safeguard Engine enters EXHAUSTED mode
43 2011-09-18 13:46:05 Safeguard Engine enters NORMAL mode
42 2011-09-18 13:46:00 Safeguard Engine enters EXHAUSTED mode
41 2011-09-18 07:57:12 Safeguard Engine enters NORMAL mode
40 2011-09-18 07:57:07 Safeguard Engine enters EXHAUSTED mode
39 2011-09-17 19:59:04 Safeguard Engine enters NORMAL mode
38 2011-09-17 19:58:59 Safeguard Engine enters EXHAUSTED mode
37 2011-09-17 19:47:44 Safeguard Engine enters NORMAL mode
36 2011-09-17 19:47:39 Safeguard Engine enters EXHAUSTED mode
35 2011-09-17 19:35:49 Safeguard Engine enters NORMAL mode
Это весь лог на DES-3200-10 (!):
Command: show log
3 2011-09-19 11:25:02 Successful login through Telnet (Username: Anonymous,
IP: 10.21.5.5)
2 2011-09-16 02:12:08 Logout through Web (Username: Anonymous, IP: 10.21.5.7
1 2011-09-16 02:11:57 Configuration and log saved to flash (Username: Anonym
ous, IP: 10.21.5.7)
DES-3200-10:5#
СообщениеДобавлено: Чт сен 29, 2011 18:50
Подобное поведение является нормальными?
Нужная какая-то дополнительная информация?
СообщениеДобавлено: Пт сен 30, 2011 08:03
Опрос оборудования по snmp есть?
Приведите настройки в плане safeguard engine и укажите среднюю загрузку cpu коммутатора, сколько на нем крутится пользователей и тп.
СообщениеДобавлено: Пт сен 30, 2011 08:58
Нет. Это тестовый стенд.
cpu — 20%
пользователей — 0.
Это тестовый стенд.
Тупо цепочкой включенные друг в друга свитчи, "сброшенные в 0", с настроенным локально временем и safeguard'ом.
СообщениеДобавлено: Пт сен 30, 2011 10:41
Пришлите конфиг на почту, посмотрю на стенде
СообщениеДобавлено: Пт сен 30, 2011 11:15
Конфиги выслал.
Но там конфига нет по сути.
Весь конфиг состоит из:
reset config
config time 15092011 14:35:00
config safeguard_engine state enable mode fuzzy utilization rising 70 falling 40
Важно, чтобы свитчи были включены в какую-то сеть с каким-то трафиком.
Достаточно простого включения, без абонентов включенных через свитчи.
СообщениеДобавлено: Пт сен 30, 2011 12:12
Хорошо, я протестирую ситуацию.
СообщениеДобавлено: Пт сен 30, 2011 13:58
У вас ситуация наблюдается на всех DES-3200-28F? Или только на одном?
PS в течении полутора часов гонял трафик через стенд.
CPU Utilization :
Five Seconds -  12 %         One Minute -  18 %         Five Minutes -  20 %
И в EXHAUSTED не вывалился ни разу.
СообщениеДобавлено: Пт сен 30, 2011 14:47
На всех.
У меня проблема проявлятся, когда свитч просто включен, но на нем есть влан, в котором есть какой-то трафик.
Для воспроизведения проблемы, ничего гонять специально мне не приходится.
Думаю, свитч нужно подержать в таком состоянии подольше.
СообщениеДобавлено: Пт сен 30, 2011 16:00
В таком случае нам для воспроизведения описанной Вами ситуации нужно проиграть этот траффик на коммутатор. Вы можете нам его прислать в формате PCAP с указанием того, с какого порта он был снят?
P.S. Если трафик тегирован то метки 802.1Q в нем нужно сохранить.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 79
