Текущее время: Сб окт 03, 2026 00:40
 Заголовок сообщения: STP DGS3627 + DES-3200-28
СообщениеДобавлено: Пт сен 02, 2011 15:49
Я видимо что-то упускаю.... помогите.
Коммутаторы объеденные одним кабелем - транком, два влана.
На DGS-3627:
#show stp
Command: show stp
 STP Bridge Global Settings
 STP Status         : Enabled
 STP Version        : RSTP
 Max Age            : 20
 Hello Time         : 2
 Forward Delay      : 15
 Max Hops           : 20
 TX Hold Count      : 6
 Forwarding BPDU    : Enabled
 Loopback Detection : Enabled
 LBD Recover Time   : 60
 NNI BPDU Address   : dot1d
#show stp ports  21
Command: show stp ports 21
 MSTP Port Information
 Port Index     : 21   M, Hello Time: 2 /2 , Port STP : Enabled  , LBD : No
 External PathCost : Auto/20000    , Edge Port : False/No , P2P : Auto /Yes
 Port RestrictedRole : False,  Port RestrictedTCN : False
 Port Forward BPDU : Disabled
 MSTI   Designated Bridge   Internal PathCost  Prio  Status      Role
 0      4000/свой мак   20000              128   Discarding  Designated
#show stp instance
Command: show stp instance
 STP Instance Settings
 Instance Type          : CIST
 Instance Status        : Enabled
 Instance Priority      : 16384(Bridge Priority : 16384, SYS ID Ext : 0 )
 STP Instance Operational Status
 Designated Root Bridge : 16384/свой мак
 External Root Cost     : 0
 Regional Root Bridge   : 16384/свой мак
 Internal Root Cost     : 0
 Designated Bridge      : 16384/свой мак
 Root Port              : None
 Max Age                : 20
 Forward Delay          : 15
 Last Topology Change   : 1391
 Topology Changes Count : 0
На DES-3200-28:
#show stp
Command: show stp
 STP Version        : RSTP
 Max Age            : 20
 Hello Time         : 2
 Forward Delay      : 15
 Max Hops           : 20
 TX Hold Count      : 6
#show stp ports  25
Command: show stp ports 25
 Port Index     : 25    , Hello Time: 2 /2 , Port STP Enabled  ,
 Restricted role   : False,  Restricted TCN : False
 External PathCost : 1             , Edge Port : False/No , P2P : Auto /Yes
 Port Forward BPDU : Enabled
 0      8000/свой мак   20000              128   Forwarding  Designated
#show stp instance 0
Command: show stp instance 0
 Instance Priority      : 32768(Bridge Priority : 32768, sys ID ext : 0 )
 Designated Root Bridge : 32768/свой мак
 Regional Root Bridge   : 32768/свой мак
 Designated Bridge      : 32768/свой мак
 Root Port              : None
 Max Age                : 20
 Forward Delay          : 15
 Last Topology Change   : 1207
 Topology Changes Count : 1
 Заголовок сообщения: Re: STP DGS3627 + DES-3200-28
СообщениеДобавлено: Пт сен 02, 2011 16:36
Приведите, пожалуйста, версии прошивок на коммутаторах.
СообщениеДобавлено: Пт сен 02, 2011 17:11
DES-3200_1.52.B004.had
DGS36xxRun_2.84-B18.had
Эм, так понял проблема в гврп ингрейс фильтеринг....
Мог ли он повлиять?
СообщениеДобавлено: Пт сен 02, 2011 17:23
Да, именно так. Попробуйте на DES-3200 отключить ingress_checking, либо задать PVID магистральных портов равным VID существующего на них влана.
