Текущее время: Чт окт 01, 2026 12:47
 Заголовок сообщения: DES-3200-28F: link up без link down
СообщениеДобавлено: Вт авг 30, 2011 10:10
Описываю проблему:
Информация по свечке:
DES-3200-28F:5#sh sw
Command: show switch
Device Type        : DES-3200-28F Fast Ethernet Switch
MAC Address        : 00-26-5A-97-E4-80
IP Address         : xxxxxxxxxxxxxx
VLAN Name          : default
Subnet Mask        : xxxxxxxxxxxxxx
Default Gateway    : xxxxxxxxxxxxxx
Boot PROM Version  : Build 1.00.B003
Firmware Version   : Build 1.50.B002
Hardware Version   : A1
Serial Number      : PVCA1A1000116
Странные записи в логе:
DES-3200-28F:5#sh log
Command: show log
Index Data       Time     Log Text
11421 2011-08-30 10:01:35 Successful login through Telnet (Username: admin, IP:
                          192.168.1.247)
11420 2011-08-30 09:52:45 Port 24 link up, 100Mbps  FULL duplex
11419 2011-08-30 09:52:43 Port 24 link up, 100Mbps  FULL duplex
11418 2011-08-30 09:52:28 Port 24 link up, 100Mbps  FULL duplex
11417 2011-08-30 09:52:24 Port 24 link up, 100Mbps  FULL duplex
11416 2011-08-30 09:47:19 Port 24 link up, 100Mbps  FULL duplex
11415 2011-08-30 09:47:18 Port 24 link up, 100Mbps  FULL duplex
11414 2011-08-30 09:47:16 Port 24 link up, 100Mbps  FULL duplex
11413 2011-08-30 09:47:13 Port 24 link up, 100Mbps  FULL duplex
11412 2011-08-30 09:14:44 Port 24 link up, 100Mbps  FULL duplex
11411 2011-08-30 09:14:41 Port 24 link up, 100Mbps  FULL duplex
11410 2011-08-30 09:14:29 Port 24 link up, 100Mbps  FULL duplex
11409 2011-08-30 09:14:26 Port 24 link up, 100Mbps  FULL duplex
11408 2011-08-30 09:14:16 Port 24 link up, 100Mbps  FULL duplex
11407 2011-08-30 09:14:15 Port 24 link up, 100Mbps  FULL duplex
11406 2011-08-30 09:13:45 Port 24 link up, 100Mbps  FULL duplex
11405 2011-08-30 09:13:44 Port 24 link up, 100Mbps  FULL duplex
11404 2011-08-30 09:13:38 Port 24 link up, 100Mbps  FULL duplex
11403 2011-08-30 09:13:37 Port 24 link up, 100Mbps  FULL duplex
11402 2011-08-30 09:06:03 Port 24 link up, 100Mbps  FULL duplex
11401 2011-08-30 09:01:51 Port 24 link up, 100Mbps  FULL duplex
11400 2011-08-30 09:01:46 Port 24 link up, 100Mbps  FULL duplex
11399 2011-08-30 09:01:43 Port 24 link up, 100Mbps  FULL duplex
11398 2011-08-30 09:01:31 Port 24 link up, 100Mbps  FULL duplex
11397 2011-08-30 09:00:54 Port 24 link down
11396 2011-08-30 08:58:07 Port 24 link up, 100Mbps  FULL duplex
11395 2011-08-30 08:58:04 Port 24 link up, 100Mbps  FULL duplex
11394 2011-08-30 08:57:48 Port 24 link up, 100Mbps  FULL duplex
11393 2011-08-30 08:57:47 Port 24 link up, 100Mbps  FULL duplex
11392 2011-08-30 08:55:23 Port 24 link up, 100Mbps  FULL duplex
11391 2011-08-30 08:55:10 Port 24 link down
11390 2011-08-30 08:55:07 Port 24 link up, 100Mbps  FULL duplex
11389 2011-08-30 08:54:56 Port 24 link up, 100Mbps  FULL duplex
11388 2011-08-30 08:54:54 Port 24 link up, 100Mbps  FULL duplex
11387 2011-08-30 08:54:51 Port 24 link down
11386 2011-08-30 08:54:50 Port 24 link up, 100Mbps  FULL duplex
11385 2011-08-30 08:53:50 Port 24 link down
11384 2011-08-30 08:53:46 Port 24 link up, 100Mbps  FULL duplex
11383 2011-08-30 08:53:45 Port 24 link up, 100Mbps  FULL duplex
11382 2011-08-30 08:52:10 Port 24 link up, 100Mbps  FULL duplex
11381 2011-08-30 08:52:09 Port 24 link up, 100Mbps  FULL duplex
11380 2011-08-30 08:52:02 Port 24 link up, 100Mbps  FULL duplex
11379 2011-08-30 08:52:01 Port 24 link up, 100Mbps  FULL duplex
11378 2011-08-30 08:52:00 Port 24 link up, 100Mbps  FULL duplex
11377 2011-08-30 07:43:19 Port 24 link up, 100Mbps  FULL duplex
11376 2011-08-30 07:43:17 Port 24 link up, 100Mbps  FULL duplex
11375 2011-08-30 07:43:08 Port 24 link up, 100Mbps  FULL duplex
11374 2011-08-30 07:43:07 Port 24 link up, 100Mbps  FULL duplex
11373 2011-08-30 07:43:03 Port 24 link up, 100Mbps  FULL duplex
11372 2011-08-30 07:43:02 Port 24 link up, 100Mbps  FULL duplex
11371 2011-08-30 07:43:01 Port 24 link up, 100Mbps  FULL duplex
11370 2011-08-30 07:42:52 Port 24 link up, 100Mbps  FULL duplex
11369 2011-08-30 07:42:50 Port 24 link up, 100Mbps  FULL duplex
11368 2011-08-30 07:42:47 Port 24 link up, 100Mbps  FULL duplex
11367 2011-08-30 07:42:41 Port 24 link up, 100Mbps  FULL duplex
11366 2011-08-30 07:42:37 Port 24 link up, 100Mbps  FULL duplex
11365 2011-08-30 07:42:35 Port 24 link up, 100Mbps  FULL duplex
11364 2011-08-30 07:42:27 Port 24 link up, 100Mbps  FULL duplex
11363 2011-08-30 07:42:20 Port 24 link down
11362 2011-08-30 07:42:19 Port 24 link up, 100Mbps  FULL duplex
11361 2011-08-30 07:31:00 Port 24 link down
11360 2011-08-30 07:30:59 Port 24 link up, 100Mbps  FULL duplex
11359 2011-08-30 07:22:22 Port 24 link up, 100Mbps  FULL duplex
Вопрос: чем обусловлено такое поведение свечки?
DES-1228/ME, DES-3028, DES-3200-XX, DES-3526, DES-3528, DGS-3100-24TG, DGS-3120-24SC, DGS-3627G, DGS-3620-28SC
 Заголовок сообщения: Re: DES-3200-28F: link up без link down
СообщениеДобавлено: Вт авг 30, 2011 10:25
Проверьте трансивер и оптику
СообщениеДобавлено: Вт авг 30, 2011 16:09
Спасибо за ответ. Еще один вопрос на эту же тему: может ли такое возникнуть в случае, если протяженность оптической линии больше, чем та, на которую рассчитан модуль? А то у нас временами случаются досадные казусы, когда на 4.5-км магистраль ставят 3-км модули.
СообщениеДобавлено: Вт авг 30, 2011 16:11
Да, может. На 4,5км пролетах необходимо использовать модули, расчитанные на линию до 10км.
СообщениеДобавлено: Вт авг 30, 2011 16:43
Большое спасибо )
СообщениеДобавлено: Ср авг 31, 2011 08:01
Пожалуйста
Сейчас этот форум просматривают: Google [Bot] и гости: 98
