Текущее время: Пт сен 25, 2026 23:44
 Заголовок сообщения: des-3200-xx и acl
СообщениеДобавлено: Ср авг 03, 2011 08:32
На новой прошивке Build 1.52.B004 не работают ACL.
1 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
2 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
3 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
4 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
5 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
6 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
7 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
8 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
9 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
10 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
11 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
12 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
13 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
14 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
15 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
16 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
17 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
18 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
19 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
20 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
21 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
22 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
23 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
24 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
25 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
26 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
27 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
28 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
29 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
30 ERROR ADD RULE: Received badValue(3) error-status at error-index 2.
Как можно решить эту проблему? Возможно нужен другой конфиг?
 Заголовок сообщения: Re: des-3200-xx и acl
СообщениеДобавлено: Ср авг 03, 2011 09:50
Приведите правила, которые вызывают такие ошибки
