Текущее время: Пт окт 02, 2026 10:18
 Заголовок сообщения: DGS-3610 и Quagga настройка OSPF
СообщениеДобавлено: Ср июл 27, 2011 17:20
Добрый день решил настроить OSPF (простейший вариант), ранее не пробывал настраивать. Линк компа воткнут в gi 0/20. Пинги до компа идут. На нем настроена quagga.
Настройки 3610 следующие
Версия прошивки
    DGS-3610#sh ver
    System description : DGS-3610-26G Gigabit Ethernet Switch
    System start time : 2011-07-19 10:21:58
    System uptime : 8:5:28:35
    System hardware version : A1.0
    System software version : v10.4(3) Release(117920)
    System BOOT version : 10.3 Release(94612)
    System CTRL version : 10.3 Release(94612)
    Device information:
    Device-1
    Hardware version : A1.0
    Software version : v10.4(3) Release(117920)
Вот интерфейсы
interface VLAN 1
 no ip proxy-arp
 ip address 172.28.100.160 255.255.255.0
interface VLAN 100
 no ip proxy-arp
interface VLAN 888
 no ip proxy-arp
 ip address 10.0.0.1 255.255.255.0
Вот вырезка router ospf 777
router ospf 777
 router-id 172.28.100.154
 log-adj-changes detail
 network 10.0.0.0 0.0.0.255 area 1
 network 172.28.100.0 0.0.0.255 area 1
Вот вывод
    DGS-3610#sh ip ospf
    Routing Process "ospf 777" with ID 172.28.100.154
    Process uptime is 13 minutes
    Process bound to VRF default
    Memory Overflow is enabled.
    Router is not in overflow state now.
    Conforms to RFC2328, and RFC1583Compatibility flag is enabled
    Supports only single TOS(TOS0) routes
    Supports opaque LSA
    Enable two-way-maintain
    Initial SPF schedule delay 1000 msecs
    Minimum hold time between two consecutive SPFs 5000 msecs
    Maximum wait time between two consecutive SPFs 10000 msecs
    Initial LSA throttle delay 0 msecs
    Minimum hold time for LSA throttle 5000 msecs
    Maximum wait time for LSA throttle 5000 msecs
    Lsa Transmit Pacing timer 40 msecs, 10 LS-Upd
    Minimum LSA arrival 1000 msecs
    Pacing lsa-group: 240 secs
    Number of incomming current DD exchange neighbors 0/5
    Number of outgoing current DD exchange neighbors 0/5
    Number of external LSA 0. Checksum 0x000000
    Number of opaque AS LSA 0. Checksum 0x000000
    Number of non-default external LSA 0
    External LSA database is unlimited.
    Number of LSA originated 1
    Number of LSA received 0
    Log Neighbor Adjency Changes : Enabled detail
    Graceful-restart disabled
    Graceful-restart helper support enabled
    Number of areas attached to this router: 1: 1 normal 0 stub 0 nssa
    Area 1
    Number of interfaces in this area is 1(2)
    Number of fully adjacent neighbors in this area is 0
    Number of fully adjacent virtual neighbors through this area is 0
    Area has no authentication
    SPF algorithm last executed 00:11:37.550 ago
    SPF algorithm executed 2 times
    Number of LSA 1. Checksum 0x00385b
DGS-3610#sh ip ospf neighbor и пустота
    DGS-3610#sh ip ospf route
    OSPF process 777:
    Codes: C - connected, D - Discard, O - OSPF, IA - OSPF inter area
    N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
    E1 - OSPF external type 1, E2 - OSPF external type 2
    C 172.28.100.0/24 [1] is directly connected, VLAN 1, Area 0.0.0.1
Вот конфиг компа
router ospf
ospf router-id 172.28.100.12
network 172.28.100.0/24 area 0.0.0.1
Подскажите в чем неправ?
 Заголовок сообщения: Re: DGS-3610 и Quagga настройка OSPF
СообщениеДобавлено: Ср июл 27, 2011 17:32
тип сети не забывайте указывать на интерфейсах (с обеих сторон) и все у вас получится...
ip ospf network broadcast или какой вам надо?
ну и сети хоть какие-то затяните для анонсов...
СообщениеДобавлено: Чт июл 28, 2011 18:57
Удалось заработало!
СообщениеДобавлено: Вт сен 20, 2011 09:18
Добрый день! Максим хотел бы посоветоваться с Вами. Значит запустил OSPF между DGS3610 и DGS3627G а также на прочих узлах L3. На стеке 3627G создана сетка для свитчей в отдельном управляющем влане и видится на ядре 3610 в area 1. Все прекрасно работает.
Хочу сервера FreeBSD которые подключены в 3610 включить в процесс OSPF.
Вопросы следующие 1)Как лучше создать отдельную в router ospf 1111 area 0 и туда добавить все сети которые есть на 3610 к примеру
interface VLAN 1
 no ip proxy-arp
 ip address 172.28.0.1 255.255.255.0
 ip address 172.28.15.1 255.255.255.0 secondary
 ip address 172.28.1.1 255.255.255.0 secondary
 ip address 172.28.2.1 255.255.255.0 secondary
Ну и прочие вланы с интерфейсами.
А на FreeBSD также создать процесс OSPF и включить туда интерфейс сетевой карты. Должно работать по идее. Разные area вроде хороши для удобства применения правил acl на area.
2) Может не допонял но для того чтобы сосед из одного дома в одной сети бежал не большой петлей (через ядро) к соседу в соседнем доме а они все пролетают через узлы распределения L3 и далее все сводится в итоге на ядро. Надо чтобы эти сети которые есть на ядре виделись на узлах распределения (DGS-3324 и т.п.) я так понимаю? Тогда L3 перенаправит пакет малой петлей (не через ядро).
3) Будут ли видется сети на узлах L3 которые допустим будут в area0? Какие доп. настройки необходимы?
Извиняюсь за возможно глупые вопросы просто спросить не у кого. Спасибо если ответите по пунктам и порекомендуете оптимальный вариант!
СообщениеДобавлено: Вт сен 20, 2011 10:18
Приветствую.
Для начала хочется сказать, что число secondary интерфейсов более 2х на svi это - bad design
1) Подсеть заьтягивается просто 1 командой:
network 172.28.X.0 0.0.0.255 area Y
Только почему вам надо все затягивать в area 0 обязательно.
Разные зоны хороши тем, что можно контролировать анонсы изначально без всяких acl, существуют разные типы area, почитайе теорию.
Всякие дистрибьют листы и фильтры, это уже так называемый route-leaking для тонкой настройки
2) Не совсем понял вопросы про петли, но могу сказать одно если L2 терминитурется на L3 логику, то петель быть не должно
3) Все зависит от типа area обычно area 0 видит все маршруты...
Опишите свою задачу простыми словами, что у вас есть текущая физика и логика лучше со схемой... и что вы хотите получить в итоге... и тогда я и другие люди с форума смогут вам помочь.
СообщениеДобавлено: Вт сен 20, 2011 10:33
1)Не спорю когда пришел это уже было. Как раз занимаюсь переводом домов на вланы и на DHCP. Пока у юзеров статические настройки эти сети убить немогу. Получается 1 дом 1 влан + своя подсеть. Кстати для DHCP использую Микротик RB (1000) на каждый влан запущен свой DHCP сервер. Не в тему но можно ли такое сделать на 3610? Сколько юзеров может потянуть железка?
2) Про петли имел ввиду несколько иное - вот схема DES-3526№1-DGS3324SR-DES-3526№2. DGS-3324SR подключен в 3610. Так вот я допустим сижу на DES-3526№1 обращаюсь к компьютеру подключенному к DES-3526№2. Трафик я так понимаю бежит сейчас так DES-3526№1 затем DGS3324SR затем 3610 затем опять на DGS3324SR и потом DES-3526№2. А хотелось бы DES-3526№1-DGS3324SR и сразу DES-3526№2. На DGS3324SR настроен OSPF. Будет ли так работать?
СообщениеДобавлено: Вт сен 20, 2011 10:50
1) DHCP сервер сделать можно, но на мой взгляд не нужно.... DHCP сервер должен оставаться сервером...3610 это не сервер с мощным CPU, сколько потянет не скажу...
2) Вы мне логику включений скажите, в каких VLAN кто находится, какие коммутаторы являются шлюзами для клиентов, о которых вы говорите...
СообщениеДобавлено: Вт сен 20, 2011 11:16
Есть сегмент все комутаторы в управляющем влане. Это 3526 включенные в DGS-3324 который в свою очередь включен в 3610, где для абонентов шлюзом является 3610 а абоненты пока в дефолтном влане. Да и управляемое оборудование стоит на доступе пока не везде - меняем. Может и нет смысла затеваться пока на вланы и сети все не разделю?
СообщениеДобавлено: Вт сен 20, 2011 11:25
Так у Вас DGS-3324 как L2 или как L3? Приведите ПОЛНУЮ топологию, с указанием адресов и чего и как хотите настроить. Без этого невозможно дать хоть сколько-нибудь внятный ответ.
СообщениеДобавлено: Вт сен 20, 2011 12:04
На DGS-3324 есть vlan 910 - управление узлами сеть 172.16.16.0/27. Vlan 900 сеть 172.16.20.0/23 для управления доступом, и включен OSPF. 3324 является шлюзом для доступа. (172.16.20.1). На 3610
    DGS-3610(config)#sh ip ospf route
    OSPF process 1111:
    C 172.16.16.0/27 [1] is directly connected, VLAN 910, Area 0.0.0.1
    O 172.16.20.0/23 [2] via 172.16.16.2, VLAN 910, Area 0.0.0.1
OSPF позволяет видеть в офисной сети комутаторы которые стоят на доступе. Если я добавляю сети которые статикой прописаны на 3610
Вот пример
DGS-3610(config)#router ospf 1111
DGS-3610(config-router)#network 172.28.1.1 0.0.0.255 area 0
то на любом L3 появляется сеть
    DGS-3627G:admin#show iproute
    Command: show iproute
    Routing Table
    IP Address/Netmask Gateway Interface Cost Protocol
    0.0.0.0/0 172.16.16.1 System 1 Default
    172.16.16.0/27 0.0.0.0 System 1 Local
    172.16.20.0/23 0.0.0.0 For_Access 1 Local
    172.28.1.0/24 172.16.16.1 System 2 OSPF
    172.28.100.0/24 172.16.16.1 System 2 OSPF
    Total Entries : 5
Сетка 172.28.1.0/24 абонентская. На серверах FreeBSD это имеет смысл, так как прописывать на каждом все сети это не рационально. Так как шлюзом является 3610 для сети 172.28.1.0/24 у пользователей статикой прибиты настройки то я понимаю что в любом случае весь трафик будет проходить через 3610. Смысл затеи описывал ниже чтобы скажем соседи подключенные к 1-му агрегационному узлу находясь в одной подсети трафик шел не через 3610 который является шлюзом для них а непосредственно так DES-3526№1-DGS-3324-DES-3526 №2. Понятно что если шлюзом для них будет DGS-3324 то так оно и будет работать. Просто в нынешнем варианте хотел оптимизировать загрузку каналов по трафику в плане маршрутизации. Чтобы трафик шел по наикратчайшему маршруту.
Практическая польза уже есть с серверами - не надо руками ничего прописывать. В двух словах на практике что-нибудь дадут появившиеся сети на агрегации в плане поиска оптимального маршрута? Полагаю что нет.
СообщениеДобавлено: Вт сен 20, 2011 13:01
Где IP адреса? Извините, но текста много, а информацию из него извлечь крайне сложно.
Если Вы хотите чтобы трафик шёл через 3324, то он должен работать как L3 и он должен быть шлюзом для пользователей.
В чём Ваш вопрос? Вы можете организовать сеть так, как Вам удобно.
Сейчас этот форум просматривают: Google [Bot] и гости: 29
