Текущее время: Сб окт 31, 2026 11:23
Начать новую тему Ответить на тему  [ Сообщений: 22 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Сб окт 23, 2010 08:24
Date/Time Facility Severity Message
Jan 1 00:00:19 user info kernel: device eth0 entered promiscuous mode
Jan 1 00:00:19 user info kernel: br0: port 1(eth0) entering learning state
Jan 1 00:00:19 user info kernel: br0: topology change detected, propagating
Jan 1 00:00:19 user info kernel: br0: port 1(eth0) entering forwarding state
Jan 1 00:00:19 user info kernel: device nas_0_0_33 entered promiscuous mode
Jan 1 00:00:19 user info kernel: br0: port 2(nas_0_0_33) entering learning state
Jan 1 00:00:19 user info kernel: br0: port 2(nas_0_0_33) entering forwarding state
Jan 1 00:00:19 user crit kernel: ADSL G.992 started
Jan 1 00:00:19 user debug syslog: brctl addbr pppbr
Jan 1 00:00:20 user debug syslog: pppd keepalive 0 0 -c 0.0.33.1 -i nas_0_0_33 -u "d168310-1@tmb.ru" -p ********* -f 0 -m 001ae21d3978/fe58 &
Jan 1 00:00:22 daemon notice pppd[250]: pppd 2.4.1 started by admin, uid 0
Jan 1 00:00:22 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:29 user crit kernel: ADSL G.992 message exchange
Jan 1 00:00:30 user crit kernel: ADSL link down
Jan 1 00:00:31 user crit kernel: ADSL G.994 training
Jan 1 00:00:44 user crit kernel: ADSL G.992 started
Jan 1 00:00:48 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:00:55 user crit kernel: ADSL link down
Jan 1 00:00:56 user crit kernel: ADSL G.994 training
Jan 1 00:01:05 user crit kernel: ADSL G.992 started
Jan 1 00:01:09 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:01:16 user crit kernel: ADSL G.992 message exchange
Jan 1 00:01:17 user crit kernel: ADSL link up, interleaved, us=1020, ds=22157
Jan 1 00:01:17 user warn kernel: ATM Soft SAR: ATM link connected.
Jan 1 00:01:18 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:01:19 daemon notice pppd[250]: PPP: Start to connect ...
Jan 1 00:01:20 daemon crit pppd[250]: PPP server detected.
Jan 1 00:01:20 daemon crit pppd[250]: PPP session established.
Jan 1 00:01:20 daemon crit pppd[250]: PPP LCP UP.
Jan 1 00:01:20 daemon crit pppd[250]: Received valid IP address from server. Connection UP.
Jan 1 00:01:21 user debug syslog: route add default gw 78.132.128.81 2>/dev/null
Jan 1 00:01:21 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:01:21 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:01:21 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:01:22 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:01:22 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:01:22 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:01:22 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:01:22 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2 2>/dev/null
Jan 1 00:01:22 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2
Jan 1 00:01:22 user debug syslog: /bin/dnsprobe &
Jan 1 00:01:22 user notice dnsprobe[772]: dnsprobe started!
Jan 1 00:01:23 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:01:23 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:01:24 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:01:24 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:01:26 user debug syslog: ifconfig ppp_0_0_33_1 mtu 1492
Jan 1 00:01:29 daemon err user: tr69c: Unable to retrieve attributes in scratch PAD
Jan 1 00:01:29 daemon err user: Stored Parameter Attribute data is corrupt or missing
Jan 1 00:04:02 user crit kernel: ADSL link down
Jan 1 00:04:04 user crit kernel: ADSL G.994 training
Jan 1 00:04:06 daemon crit pppd[250]: Clear IP addresses. Connection DOWN.
Jan 1 00:04:06 daemon crit pppd[250]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:04:13 user crit kernel: ADSL G.992 started
Jan 1 00:04:17 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:04:24 user crit kernel: ADSL G.992 message exchange
Jan 1 00:04:25 user crit kernel: ADSL link down
Jan 1 00:04:26 user crit kernel: ADSL G.994 training
Jan 1 00:04:35 user crit kernel: ADSL G.992 started
Jan 1 00:04:39 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:04:45 user crit kernel: ADSL G.992 message exchange
Jan 1 00:04:46 user crit kernel: ADSL link up, interleaved, us=1020, ds=22732
Jan 1 00:04:47 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:04:49 daemon notice pppd[250]: PPP: Start to connect ...
Jan 1 00:04:52 daemon crit pppd[250]: PPP server detected.
Jan 1 00:04:52 daemon crit pppd[250]: PPP session established.
Jan 1 00:04:52 daemon crit pppd[250]: PPP LCP UP.
Jan 1 00:04:53 daemon crit pppd[250]: Received valid IP address from server. Connection UP.
Jan 1 00:04:53 user debug syslog: route add default gw 78.132.128.81 2>/dev/null
Jan 1 00:04:53 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:04:54 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:04:54 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:04:54 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:04:54 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:04:54 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:04:54 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:04:54 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2 2>/dev/null
Jan 1 00:04:54 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2
Jan 1 00:04:56 user alert kernel: Intrusion -> IN=ppp_0_0_33_1 OUT= MAC= SRC=109.165.2.149 DST=78.132.159.169 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=51532 DF PROTO=TCP SPT=2091 DPT=38989 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:04:57 user alert kernel: Intrusion -> IN=ppp_0_0_33_1 OUT= MAC= SRC=109.165.2.149 DST=78.132.159.169 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=51701 DF PROTO=TCP SPT=2091 DPT=38989 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:04:57 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:04:57 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:04:57 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:04:57 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:04:59 user debug syslog: ifconfig ppp_0_0_33_1 mtu 1492
Jan 1 00:05:40 user alert kernel: Intrusion -> IN=ppp_0_0_33_1 OUT= MAC= SRC=109.165.2.149 DST=78.132.159.169 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=60227 DF PROTO=TCP SPT=2454 DPT=38989 WINDOW=65535 RES=0x00 SYN URGP=0
Jan 1 00:05:58 user crit kernel: ADSL link down
Jan 1 00:06:00 daemon crit pppd[250]: Clear IP addresses. Connection DOWN.
Jan 1 00:06:00 daemon crit pppd[250]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:06:13 user crit kernel: ADSL G.994 training
Jan 1 00:06:22 user crit kernel: ADSL G.992 started
Jan 1 00:06:26 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:06:33 user crit kernel: ADSL link down
Jan 1 00:06:35 user crit kernel: ADSL G.994 training
Jan 1 00:06:54 user crit kernel: ADSL G.992 started
Jan 1 00:06:55 user crit kernel: ADSL link down
Jan 1 00:06:56 user crit kernel: ADSL G.994 training
Jan 1 00:07:05 user crit kernel: ADSL G.992 started
Jan 1 00:07:06 user crit kernel: ADSL link down
Jan 1 00:07:08 user crit kernel: ADSL G.994 training
Jan 1 00:07:17 user crit kernel: ADSL G.992 started
Jan 1 00:07:18 user crit kernel: ADSL link down
Jan 1 00:07:24 user crit kernel: ADSL G.994 training
Jan 1 00:07:33 user crit kernel: ADSL G.992 started
Jan 1 00:07:37 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:07:43 user crit kernel: ADSL G.992 message exchange
Jan 1 00:07:44 user crit kernel: ADSL link up, interleaved, us=1020, ds=22233
Jan 1 00:07:45 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:07:47 daemon notice pppd[250]: PPP: Start to connect ...
Jan 1 00:07:49 daemon crit pppd[250]: PPP server detected.
Jan 1 00:07:49 daemon crit pppd[250]: PPP session established.
Jan 1 00:07:49 daemon crit pppd[250]: PPP LCP UP.
Jan 1 00:07:49 daemon crit pppd[250]: Received valid IP address from server. Connection UP.
Jan 1 00:07:50 user debug syslog: route add default gw 78.132.128.81 2>/dev/null
Jan 1 00:07:50 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:07:50 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:07:51 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:07:51 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:07:51 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:07:51 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:07:52 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:07:52 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2 2>/dev/null
Jan 1 00:07:52 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2
Jan 1 00:07:54 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:07:54 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:07:54 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:07:54 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:07:56 user debug syslog: ifconfig ppp_0_0_33_1 mtu 1492
Jan 1 00:09:29 user crit kernel: ADSL link down
Jan 1 00:09:30 user crit kernel: ADSL G.994 training
Jan 1 00:09:31 daemon crit pppd[250]: Clear IP addresses. Connection DOWN.
Jan 1 00:09:31 daemon crit pppd[250]: Clear IP addresses. PPP connection DOWN.
Jan 1 00:09:40 user crit kernel: ADSL G.992 started
Jan 1 00:09:43 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:09:50 user crit kernel: ADSL G.992 message exchange
Jan 1 00:09:51 user crit kernel: ADSL link down
Jan 1 00:09:52 user crit kernel: ADSL G.994 training
Jan 1 00:10:01 user crit kernel: ADSL G.992 started
Jan 1 00:10:05 user crit kernel: ADSL G.992 channel analysis
Jan 1 00:10:11 user crit kernel: ADSL G.992 message exchange
Jan 1 00:10:12 user crit kernel: ADSL link up, interleaved, us=1020, ds=20854
Jan 1 00:10:14 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107
Jan 1 00:10:16 daemon notice pppd[250]: PPP: Start to connect ...
Jan 1 00:10:17 daemon crit pppd[250]: PPP server detected.
Jan 1 00:10:17 daemon crit pppd[250]: PPP session established.
Jan 1 00:10:17 daemon crit pppd[250]: PPP LCP UP.
Jan 1 00:10:17 daemon crit pppd[250]: Received valid IP address from server. Connection UP.
Jan 1 00:10:18 user debug syslog: route add default gw 78.132.128.81 2>/dev/null
Jan 1 00:10:18 user debug syslog: iptables -A FORWARD -o ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:10:19 user debug syslog: iptables -A FORWARD -i ppp_0_0_33_1 -p tcp --tcp-flags SYN,RST SYN -j TCPMSS --clamp-mss-to-pmtu
Jan 1 00:10:19 user debug syslog: echo > /proc/net/ip_conntrack
Jan 1 00:10:19 user debug syslog: echo "1000" > /proc/sys/net/ipv4/ip_conntrack_max
Jan 1 00:10:19 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 128.9.0.107 2>/dev/null
Jan 1 00:10:20 user debug syslog: iptables -t nat -D POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE 2>/dev/null
Jan 1 00:10:20 user debug syslog: iptables -t nat -A POSTROUTING -o ppp_0_0_33_1 -s 192.168.1.0/255.255.255.0 -j MASQUERADE
Jan 1 00:10:20 user debug syslog: iptables -t nat -D PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2 2>/dev/null
Jan 1 00:10:20 user debug syslog: iptables -t nat -A PREROUTING -i br0 -d 192.168.1.1 -p udp --dport 53 -j DNAT --to 213.135.128.2
Jan 1 00:10:21 user alert kernel: Intrusion -> IN=ppp_0_0_33_1 OUT= MAC= SRC=78.54.136.29 DST=78.132.179.133 LEN=48 TOS=0x00 PREC=0x00 TTL=115 ID=2030 DF PROTO=TCP SPT=53078 DPT=51000 WINDOW=8192 RES=0x00 SYN URGP=0
Jan 1 00:10:21 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:10:21 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p tcp --dport 30005
Jan 1 00:10:22 user debug syslog: iptables -I INPUT 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:10:22 user debug syslog: iptables -I FORWARD 1 -j ACCEPT -i ppp_0_0_33_1 -p udp -s 192.168.1.1/24 --dport 30006
Jan 1 00:10:23 user debug syslog: ifconfig ppp_0_0_33_1 mtu 1492
СообщениеДобавлено: Вт окт 26, 2010 10:52
Fahrenheit68 писал(а):
Сколько можно ждать?
3 день жду ответа!
Был в отпуске - ответил Вам по почте.
 Заголовок сообщения: Re: помогите
СообщениеДобавлено: Вт июл 12, 2011 18:13
Добры день!Я забыла пароль для доступа к web-интерфейсу. Как можно его восстановить?
модем: DSL-2600U
СообщениеДобавлено: Ср июл 13, 2011 09:30
Отключите питание модема, зажмите RESET и включите питание. Продолжайте удерживать RESET 5 сек.
После этого настройки вернутся к заводским.
СообщениеДобавлено: Вт июл 19, 2011 01:10
:!: Ответьте пожалуйста мне в ЛС, у меня такая же проблема (D3 RU_1.50). Я так и не понял, что нужно сделать, читая ответы.
СообщениеДобавлено: Вт июл 19, 2011 01:11
а по поводу RESET не помогает =\
СообщениеДобавлено: Вт июл 19, 2011 09:03
В этой ветке в кучу свалили вопросы по дсл-2500, дир-100, DSL-2600U, Вас какой вопрос интересует?
См. п. 5, 6 viewtopic.php?f=3&t=133062
DSL-2500U, DVG-1402S, DVG-G1402S, DIR-100, DIR-300, DIR-615, DWL-2100AP, DCS-2121, DAP-1360, Zyxel Keenetic, Siemens Gigaset C470IP - все работает отлично. ;)
