Текущее время: Чт окт 01, 2026 17:50
 Заголовок сообщения: G604T - непонятки с time и system log...
СообщениеДобавлено: Пн авг 15, 2005 00:01
Выставляю синхронизацию времени через инет при правильном высталеном часовом поясе, время устанавливается с расхождением в несколько часов, выставляю вручную или синхронизирую с компом, вроде все верно но...
судя по логу часы практически стоят на месте, меняются только дни, вот сегодняшний лог:
Sep 8 12:00:06> Valid Configuration Tree
Sep 8 12:00:11> Firewall NAT service started
Aug 9 12:01:00> Bridge Created: br0
Aug 9 12:01:01> Bridge Interface Added: eth0
Aug 9 12:01:01> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:03> DSL Carrier is down
Aug 9 12:01:13> Bridge Interface Added: tiwlan0
Aug 9 12:01:13> DSL Carrier is up
Aug 9 12:01:22> Connecting PPPoE socket: 00:30:88:00:80:b2 ca0b nas0 0x1000d3b8
Aug 9 12:01:22> Connect: ppp0 {--} nas0
Aug 9 12:01:22> CHAP authentication failed
Aug 9 12:01:22> Connection terminated.
Aug 9 12:01:22> Doing disconnect
Aug 9 12:01:22> Failed to Authenicate
Aug 9 12:01:23> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:23> Connecting PPPoE socket: 00:30:88:00:80:b2 5c16 nas0 0x1000d3b8
Aug 9 12:01:23> Connect: ppp0 {--} nas0
Aug 9 12:01:23> CHAP authentication failed
Aug 9 12:01:29> Connection terminated.
Aug 9 12:01:29> Doing disconnect
Aug 9 12:01:29> Failed to Authenicate
Aug 9 12:01:35> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:35> Connecting PPPoE socket: 00:30:88:00:80:b2 5d16 nas0 0x1000d3b8
Aug 9 12:01:35> Connect: ppp0 {--} nas0
Aug 9 12:01:35> CHAP authentication failed
Aug 9 12:01:41> Connection terminated.
Aug 9 12:01:41> Doing disconnect
Aug 9 12:01:41> Failed to Authenicate
Aug 9 12:01:46> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:47> Connecting PPPoE socket: 00:30:88:00:80:b2 6016 nas0 0x1000d3b8
Aug 9 12:01:47> Connect: ppp0 {--} nas0
Aug 9 12:01:47> CHAP authentication failed
Aug 9 12:01:53> Connection terminated.
Aug 9 12:01:53> Doing disconnect
Aug 9 12:01:53> Failed to Authenicate
Aug 9 12:01:58> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:59> Connecting PPPoE socket: 00:30:88:00:80:b2 2b12 nas0 0x1000d3b8
Aug 9 12:01:59> Connect: ppp0 {--} nas0
Aug 9 12:01:59> CHAP authentication failed
Aug 9 12:02:05> Connection terminated.
Aug 9 12:02:05> Doing disconnect
Aug 9 12:02:05> Failed to Authenicate
Aug 9 12:02:10> pppd 2.4.1 started by root, uid 0
Aug 9 12:02:11> Connecting PPPoE socket: 00:30:88:00:80:b2 1602 nas0 0x1000d3b8
Aug 9 12:02:11> Connect: ppp0 {--} nas0
Aug 9 12:02:11> WAN IP address 81.195.30.90
Aug 9 12:02:11> PPPoE Connect with IP Address 81.195.30.90
Aug 9 12:02:11> WAN gateway 81.195.30.1
Aug 9 12:02:11> primary DNS address 212.188.4.10
Aug 9 12:02:11> secondary DNS address 195.34.32.116
Aug 9 12:02:11> PPPoE Connection Successfully Established
Aug 9 12:02:11> PPPoE Connect with Gateway IP Address: 81.195.30.1
Aug 10 12:02:18> PPPD Successfully Launched
Aug 10 12:02:18> Connection terminated.
Aug 10 12:02:18> Doing disconnect
Aug 10 12:02:19> pppd 2.4.1 started by root, uid 0
Aug 10 12:02:19> Connecting PPPoE socket: 00:30:88:00:80:b2 a911 nas0 0x1000d3b8
Aug 10 12:02:19> Connect: ppp0 {--} nas0
Aug 10 12:02:20> PPPoE Connect with IP Address 81.195.30.90
Aug 10 12:02:20> PPPoE Connection Successfully Established
Aug 10 12:02:20> PPPoE Connect with Gateway IP Address: 81.195.30.1
Aug 10 12:02:20> WAN IP address 81.195.30.90
Aug 10 12:02:20> WAN gateway 81.195.30.1
Aug 10 12:02:20> primary DNS address 212.188.4.10
Aug 10 12:02:20> secondary DNS address 195.34.32.116
как это понимать?
 Заголовок сообщения: Re: G604T - непонятки с time и system log...
СообщениеДобавлено: Вт авг 16, 2005 11:37
Версия прошивки?
Бигаров Руслан.
СообщениеДобавлено: Вт авг 16, 2005 19:00
1) Глюк с расхождением - попробуйте другие серверы времени. Иногда помогает.
2) Это Вам так кажется, через 24 часа Стрим меняет Вам IP. Попробуйте зайти на модем вначале под неправильным паролем, далее под правильным и посмотрите время в логах. :wink: Можете проделать эту процедуру через 30 минут - 1 час - и т.д. :wink:
СообщениеДобавлено: Вт авг 16, 2005 22:56
Bigarov Ruslan писал(а):
Версия прошивки?
V1.00B02T02.RU.20041014
СообщениеДобавлено: Вт авг 16, 2005 23:03
Дык пробовал и вручную выставлять и с компом синхронизировать, пробовал все, только что вечером перезагрузил, результат:
Aug 9 12:01:02> pppd 2.4.1 started by root, uid 0
Aug 9 12:01:23> DSL Carrier is training
Aug 9 12:01:32> Connecting PPPoE socket: 00:30:88:00:80:b2 9007 nas0 0x1000d3b8
Aug 9 12:01:32> Connect: ppp0 {--} nas0
Aug 9 12:01:32> WAN IP address 81.195.30.157
Aug 9 12:01:32> WAN gateway 81.195.30.1
Aug 9 12:01:32> primary DNS address 212.188.4.10
Aug 9 12:01:32> secondary DNS address 195.34.32.116
Aug 9 12:01:32> PPPoE Connect with IP Address 81.195.30.157
Aug 9 12:01:32> PPPoE Connection Successfully Established
Aug 9 12:01:32> PPPoE Connect with Gateway IP Address: 81.195.30.1
Aug 9 12:01:33> DSL Carrier is up
Ы???
СообщениеДобавлено: Ср авг 17, 2005 12:14
Это проблема прошивки, которая будет исправлена в прошивке ADSL2+ для данного модема. Но её выход пока неизвестен.
Бигаров Руслан.
СообщениеДобавлено: Ср авг 17, 2005 14:32
Сенкс, а то уж думал что снова не повезло...
Сейчас этот форум просматривают: Google [Bot] и гости: 67
