Текущее время: Пт авг 21, 2026 17:28
 Заголовок сообщения: DFL-860E: IPSec l2tp и MacOS 10.6
СообщениеДобавлено: Чт июл 07, 2011 14:14
Есть поднятый и нормально работающий l2tp ipsec VPN на DFL-860E. С машинками на Windows проблем нет. А в MacOS сессия завершается со стороны MacOS.
В чем может быть проблема?
Fri Jul 1 02:31:33 2011 : L2TP connection established.
Fri Jul 1 02:31:33 2011 : using link 0
Fri Jul 1 02:31:33 2011 : Using interface ppp0
Fri Jul 1 02:31:33 2011 : Connect: ppp0 <--> socket[34:18]
Fri Jul 1 02:31:33 2011 : sent [LCP ConfReq id=0x1 <asyncmap 0x0>
<magic 0x24e380ae> <pcomp> <accomp>]
Fri Jul 1 02:31:33 2011 : rcvd [LCP ConfReq id=0x0 <mru 1356> <auth
chap MS-v2> <magic 0x1d27a67>]
Fri Jul 1 02:31:33 2011 : lcp_reqci: returning CONFACK.
Fri Jul 1 02:31:33 2011 : sent [LCP ConfAck id=0x0 <mru 1356> <auth
Fri Jul 1 02:31:33 2011 : rcvd [LCP ConfRej id=0x1 <asyncmap 0x0>
<pcomp> <accomp>]
Fri Jul 1 02:31:33 2011 : sent [LCP ConfReq id=0x2 <magic 0x24e380ae>]
Fri Jul 1 02:31:33 2011 : rcvd [LCP ConfAck id=0x2 <magic 0x24e380ae>]
Fri Jul 1 02:31:33 2011 : sent [LCP EchoReq id=0x0 magic=0x24e380ae]
Fri Jul 1 02:31:33 2011 : rcvd [CHAP Challenge id=0x18
<XXX>, name = ""]
Fri Jul 1 02:31:33 2011 : sent [CHAP Response id=0x18
<XXX>,
name = "denis_o"]
Fri Jul 1 02:31:33 2011 : rcvd [LCP EchoRep id=0x0 magic=0x1d27a67]
Fri Jul 1 02:31:33 2011 : rcvd [CHAP Success id=0x18
"S=XXX"]
Fri Jul 1 02:31:33 2011 : sent [IPCP ConfReq id=0x1 <addr 0.0.0.0>
<ms-dns1 0.0.0.0> <ms-dns3 0.0.0.0>]
Fri Jul 1 02:31:33 2011 : sent [ACSCP ConfReq id=0x1 <ms-dns1
0.0.0.1> <ms-dns1 0.0.0.1>]
Fri Jul 1 02:31:33 2011 : rcvd [CCP ConfReq id=0x0 <mppe +H +M +S +L -D -C>]
Fri Jul 1 02:31:33 2011 : Unsupported protocol 'Compression Control
Protocol' (0x80fd) received
Fri Jul 1 02:31:33 2011 : sent [LCP ProtRej id=0x3 80 fd 01 00 00 0a
12 06 01 00 00 e0]
Fri Jul 1 02:31:33 2011 : rcvd [IPCP ConfReq id=0x0 <addr 10.0.10.254>]
Fri Jul 1 02:31:33 2011 : ipcp: returning Configure-ACK
Fri Jul 1 02:31:33 2011 : sent [IPCP ConfAck id=0x0 <addr 10.0.10.254>]
Fri Jul 1 02:31:33 2011 : rcvd [IPCP ConfRej id=0x1 <ms-dns1 0.0.0.0>
<ms-dns3 0.0.0.0>]
Fri Jul 1 02:31:33 2011 : sent [IPCP ConfReq id=0x2 <addr 0.0.0.0>]
Fri Jul 1 02:31:33 2011 : rcvd [LCP ProtRej id=0x1 82 35 01 01 00 10
01 06 00 00 00 01 02 06 00 00 00 01]
Fri Jul 1 02:31:33 2011 : rcvd [LCP TermReq id=0x2]
Fri Jul 1 02:31:33 2011 : LCP terminated by peer
Fri Jul 1 02:31:33 2011 : sent [LCP TermAck id=0x2]
Fri Jul 1 02:31:33 2011 : L2TP received CDN
Fri Jul 1 02:31:33 2011 : Connection terminated.
Fri Jul 1 02:31:33 2011 : L2TP disconnecting...
Fri Jul 1 02:31:33 2011 : L2TP sent CDN
Fri Jul 1 02:31:33 2011 : L2TP sent StopCCN
Fri Jul 1 02:31:33 2011 : L2TP disconnected
 Заголовок сообщения: Re: DFL-860E: IPSec l2tp и MacOS 10.6
СообщениеДобавлено: Пт июл 08, 2011 05:43
Покажите логи DFL
Хотите считать с него трафик?
Сейчас этот форум просматривают: Google [Bot] и гости: 44
