Текущее время: Вт сен 01, 2026 11:33
 Заголовок сообщения: DIR-320 не работает PPPoE
СообщениеДобавлено: Чт май 12, 2011 10:23
Не работает PPPoE на роутере DLink DIR-320 H/W Ver. A2. Ввожу правильные настройки, соединение устанавливается, загорается синий значок Internet Online но интернет так и не работает, ничего интернетовского не пингуется. При этом на стационарном компьютере с Windows все работает. Версия прошивки DIR-320A1_FW121WWb03.bin. Искал решение проблемы ранее, но ничего похожего не нашел. В чем может быть проблема?
Вот лог с роутера:
"May 12 10:14:00  ","Access Control disabled."
"May 12 10:14:00  ","Remote management is disabled."
"May 12 10:14:00  ","Block WAN PING is disabled."
"May 12 10:14:00  ","DMZ disabled."
"May 12 10:14:00  ","VPN (RTSP) Pass-Through disabled."
"May 12 10:14:00  ","VPN (L2TP) Pass-Through enabled."
"May 12 10:14:00  ","VPN (IPSec) Pass-Through enabled."
"May 12 10:14:00  ","VPN (PPTP) Pass-Through enabled."
"May 12 10:14:00  ","Domain blocking disabled."
"May 12 10:14:00  ","URL blocking enabled (Deny)."
"May 12 10:13:59  ","MAC filter enabled (Allow)."
"May 12 10:13:52  ","Access Control disabled."
"May 12 10:13:52  ","DMZ disabled."
"May 12 10:13:52  ","VPN (RTSP) Pass-Through disabled."
"May 12 10:13:52  ","VPN (L2TP) Pass-Through enabled."
"May 12 10:13:52  ","VPN (IPSec) Pass-Through enabled."
"May 12 10:13:52  ","VPN (PPTP) Pass-Through enabled."
"May 12 10:13:52  ","Domain blocking disabled."
"May 12 10:13:52  ","URL blocking enabled (Deny)."
"May 12 10:13:51  ","MAC filter enabled (Allow)."
"May 12 10:13:51  ","IPCP: secondary DNS address 89.109.235.236."
"May 12 10:13:51  ","IPCP: primary DNS address 89.109.235.230."
"May 12 10:13:51  ","IPCP: remote IP address 10.0.0.1."
"May 12 10:13:51  ","IPCP: local IP address 192.168.1.22."
"May 12 10:13:51  ","CHAP authentication succeeded."
"May 12 10:13:51  ","PPPoE: Received PADS for session1. (Session ID: 8b)"
"May 12 10:13:51  ","PPPoE: Sending PADR for session1."
"May 12 10:13:51  ","PPPoE: Received PADO for session1, from: 00:21:91:0b:f0:21"
"May 12 10:13:50  ","PPPoE: Sending PADI for session1."
"May 12 10:13:46  ","PPP: Connection terminated."
"May 12 10:13:46  ","WAN disconnected (PPTP)."
"May 12 10:09:40  ","Log message was cleared."
 Заголовок сообщения: Re: DIR-320 не работает PPPoE
СообщениеДобавлено: Пт май 13, 2011 09:33
Не совсем понимаю проблему, если нет Интернет, то как тогда все работает на стационарном компьютере?
viewtopic.php?f=3&t=110340
СообщениеДобавлено: Пт май 13, 2011 20:06
Если компьютер с Windows напрямую подсоединить к сети и на нем запустить PPPoE соединение то все работает. Если роутер подсоединить к сети то соединение устанавливается, синий значок загорается, но интернет не работает нигде, ни на роутере ни на компьютерах за ним.
Сейчас этот форум просматривают: Baidu [Spider] и гости: 63
