Текущее время: Вс окт 04, 2026 01:15
 Заголовок сообщения: два потока Multicast в DGS-3200-10
СообщениеДобавлено: Чт май 05, 2011 12:46
Есть схема:
поток Multicast (vlan IPTV tag 100) ->DGS-3200-10:
enable igmp_snooping
config igmp_snooping vlan IPTV host_timeout 260 router_timeout 260 leave_timer 2 state enable fast_leave enable
config igmp_snooping querier vlan IPTV query_interval 125 max_response_time 10 robustness_variable 2 last_memb
er_query_interval 1 state enable version 3
config igmp_snooping data_driven_learning vlan IPTV state disable aged_out enable
config igmp_snooping data_driven_learning max_learned_entry 56
config router_ports IPTV add 1-2,10
config router_ports_forbidden IPTV add 3-9
config igmp access_authentication ports 1-10 state disable
дальше в DGS-3627G на нем:
enable igmp_snooping forward_mcrouter_only
config igmp_snooping vlan 10 report_suppression disable
config igmp_snooping vlan 10 state enable fast_leave disable
config igmp_snooping querier vlan 10 query_interval 125 max_response_time 5 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp_snooping vlan IPTV report_suppression disable
config igmp_snooping vlan IPTV state enable fast_leave disable
config igmp_snooping querier vlan IPTV query_interval 125 max_response_time 10 robustness_variable 2 last_member_query_interval 1 state disable version 3
config igmp ipif 10 version 3 query_interval 125 max_response_time 5 robustness_variable 2 state enable
config igmp ipif 10 last_member_query_interval 1
config igmp check_subscriber_source_network ipif 10 disable
config igmp ipif 100 version 3 query_interval 125 max_response_time 10 robustness_variable 2 state enable
config igmp ipif 100 last_member_query_interval 1
config igmp check_subscriber_source_network ipif 100 disable
disable pim
enable dvmrp
config dvmrp ipif 10 metric 1 probe 1 neighbor_timeout 35 state enable
config dvmrp ipif 100 metric 1 probe 1 neighbor_timeout 35 state enable
disable ospf
дальше в DGS-3100-24TG:
config igmp_snooping 10 state enable
дальше в DES-1228/ME (конечный):
config igmp_snooping vlan_name 10 host_timeout 260 router_timeout 260 leave_timer 2 state disable fast_leave
disable
config igmp_snooping data_driven_learning vlan_name 10 aged_out disable
_____________________________
1. так вот, телевидение (в 10 vlan) работает (правда иногда подвисает и подрассыпается)
2. при подключении 2ого потока Multicast (vlan IPTV tag 100) в DGS-3200-10 порт 2
все жутко рассыпается и загрузка cpu на DGS-3200-10 поднимается прибл. (с 30-40% до 80-90%)
 Заголовок сообщения: Re: два потока Multicast в DGS-3200-10
СообщениеДобавлено: Чт май 05, 2011 16:48
config igmp_snooping vlan IPTV ... state enable fast_leave enable
config igmp_snooping querier vlan IPTV ... state enable version 3
fast leave нужен на конечных свичах, там где юзеры
лучше всего использовать IGMPv2
config igmp_snooping vlan_name 10 ... state disable fast_leave disable
надо включать снупинг в влане на оконечном свиче
почему не используете ISM VLAN?
P.S. используйте для конфигов тег code, большие конфиги заключайте не только в тег code, но и в тег spoiler - всем будет удобно
с уважением, БП
СообщениеДобавлено: Пт май 06, 2011 22:51
а на DGS-3200-10 надо делать ISM VLAN или только на конечных?
и еще при ISM VLAN на конечных свитчах надо прописать:
member_port 1-24 state enable replace_source_ip ххх.ххх.ххх.ххх
а если у меня два IPTV сервера как быть?
СообщениеДобавлено: Пн май 09, 2011 15:05
ISM VLAN == мультикаст VLAN создаваемый _только_ на оконечных, клиентских свичах
на всех остальных свичах - это самый обычный L2 VLAN в котором включен igmp snooping ;)
а не надо ничего писать! replace_source_ip - это проксирование, поэтому пишите там none - все нормально будет работать
с уважением, БП
СообщениеДобавлено: Вт май 10, 2011 23:37
сделал через ISM VLAN - картинка вообще не рассыпается (даже на HD), но появилась новая фишечка:
ровно каждые 5 мин 50 сек картинка застывает, висит 10 сек и отмирает, пол дня смотрел,
алгоритм застывания четко повторяется!
где разгадка не подскажете?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 103
