Текущее время: Вт окт 06, 2026 06:49
 Заголовок сообщения: DIR-300NRU кто разрывает сессию?
СообщениеДобавлено: Ср май 04, 2011 05:47
собственно сабж
с чьей стороны идёт разрыв сессии: со стороны роутера или со стороны провайдера?
разрывы не зависят ни от загруженности канала, ни от времени суток - примерно (точнее даже сказать РОВНО) раз в час:
May 4 05:40:22 MAC filter disabled.
May 4 05:40:22 IPCP: secondary DNS address 88.87.64.6.
May 4 05:40:22 IPCP: primary DNS address 8.8.8.8.
May 4 05:40:22 IPCP: remote IP address 10.23.15.1.
May 4 05:40:22 IPCP: local IP address 10.23.15.237.
May 4 05:40:21 CHAP authentication succeeded.
May 4 05:40:21 PPPoE: Received PADS for session1. (Session ID: 196)
May 4 05:40:21 PPPoE: Sending PADR for session1.
May 4 05:40:21 PPPoE: Received PADO for session1, from 00:0c:42:70:95:6c.
May 4 05:40:21 PPPoE: Sending PADI for session1.
May 4 05:40:16 PPPoE: Sending PADT for session1. (Session ID: 192)
May 4 05:40:15 PPP: Connection terminated.
May 4 05:40:08 PPP: No response to 14 LCP echo requests.
May 4 05:28:03 Time synchronized at 2011/05/04, 05:28:03.
May 4 06:40:10 Time synchronized at 2011/05/04, 06:40:10.
May 4 06:40:09 Remote management is disabled.
May 4 06:40:09 Block WAN PING is enabled.
May 4 06:40:09 DMZ disabled.
May 4 06:40:09 VPN (RTSP) Pass-Through enabled.
May 4 06:40:09 VPN (L2TP) Pass-Through enabled.
May 4 06:40:09 VPN (IPSec) Pass-Through enabled.
May 4 06:40:09 VPN (PPTP) Pass-Through enabled.
May 4 06:40:09 Domain blocking disabled.
May 4 06:40:08 URL blocking disabled.
May 4 06:40:08 MAC filter disabled.
May 4 06:40:08 IPCP: secondary DNS address 88.87.64.6.
May 4 06:40:08 IPCP: primary DNS address 8.8.8.8.
May 4 06:40:08 IPCP: remote IP address 10.23.15.1.
May 4 06:40:08 IPCP: local IP address 10.23.15.237.
May 4 06:40:07 CHAP authentication succeeded.
May 4 06:40:07 PPPoE: Received PADS for session1. (Session ID: 19c)
May 4 06:40:07 PPPoE: Sending PADR for session1.
May 4 06:40:07 PPPoE: Received PADO for session1, from 00:0c:42:70:95:6c.
May 4 06:40:07 PPPoE: Sending PADI for session1
May 4 06:40:02 PPPoE: Sending PADT for session1. (Session ID: 196)
May 4 06:40:01 PPP: Connection terminated.
May 4 06:39:54 PPP: No response to 14 LCP echo requests
 Заголовок сообщения: Re: DIR-300NRU кто разрывает сессию?
СообщениеДобавлено: Ср май 04, 2011 09:22
Dom.ru, что ли? :) Провайдерская железка закрыла соединение, а роутер об этом не знает, и пытается проверить его жизнеспособность echo запросами. После 14 запросов говорит, что есть проблема, закрывает соединение и пытается заново приконнектиться.
СообщениеДобавлено: Ср май 04, 2011 09:28
аналогичная проблема - с той только разницей что помимо вашей проблемы наблюдается еще и такой эффект - сессия висит ( адрес и днс получен - а вот выйти никуда не возможно)... помогает принудительный разрыв сессии... периодически отваливается авторизация - со слов техподдержки у них по логам сессия висит - я же вижу попытки со стороны моего дира авторизоваться..... ( смена прошивки включая дд-врт проблему не решает ) т.к продлема скорее всего у провайдера.... только от этого не легче
СообщениеДобавлено: Ср май 04, 2011 09:43
Nite2, так и есть - сначала отрубается инет, затем переподключается роутер.
жуть - запарили уже...
P.S. ZyXEL вообще по пять минут поднимает соединение (да и то в лучшем случае, если поднимет) - сдам его сегодня нафиг и останусь при своём DIR-300.
СообщениеДобавлено: Ср май 04, 2011 15:49
На дом.ру надо подобрать модель роутера, для которой есть специальная прошивка, кастомизированная именно для дом.ру. По форумам провайдера пошарьтесь. Иначе так и будете мучаться разрывами связи.
СообщениеДобавлено: Ср май 04, 2011 16:27
Nite2, суть лишь в том, что это всего лишь пока что используется DNS дом.ру:
мой провайдер является для меня субпровайдером сетей дом.ру, корбины, повернет (Волжский) и инстрнет (там же), но пока суть да дело с заменой оборудования (а отрубает меня именно ИХ оборудование) вот такие траблы и появились... :(
не ну блин стоял микротик - я был как слон доволен! а тут на тебе - сервак хер знает какой... :(
P.S. да, кстать ZyXEL NBG460N EE сдал совершенно без проблем... подмышкой держал DIR-300 для тестирования/сравнения, а в СЦ даже его и не попросили, ничего вообще не тестировали, свернули так всё обратно в коробочку и денежку вернули в течении минут 10-ти.
СообщениеДобавлено: Ср май 04, 2011 17:57
DNS тут совершенно ни при чем. Проблема у дом.ру как провайдера. Их оборудование так настроено, что пропускает в порты чужой LCP трафик. А потом само же и не понимает, чего это роутер на него отвечает. Начинает считать, что роутер совершает атаку на него, и отрубает сессию. Все это мусолится уже который год, только дом.ру почему-то считает, что куча вендоров выпускают неправильные роутеры, а у них в настройках все в порядке. Или, может, закупили кучу такого оборудования, которое по-другому работать не умеет...
Я же говорю, ищите роутер, который будет работать с этим провайдером. Для определенных моделей определенных вендоров есть "исправленные" прошивки, на которых разрывов нет. О том, какие именно роутеры работают нормально, пишется на форуме провайдера.
СообщениеДобавлено: Пт май 06, 2011 09:32
Пытался связаться с представителями ДОМ.РУ - конкретного ответа не получил.
Сейчас этот форум просматривают: Google [Bot] и гости: 140
