Текущее время: Пн июн 22, 2026 21:47
 Заголовок сообщения: HOT-LINE DVG-3032S - DVG-2032S
СообщениеДобавлено: Пт апр 29, 2011 12:07
Добрый день!
имеются сабж с настроенной Hot-Line.
прошивки на обоих обновлены до версии 1.02.38.28.
происходит следующее - разрыв в процессе разговора.
Вот нормальное завершение:
15:43:07 [005330] 31: Fxs Pickup
15:43:07 [005330] 31: HotLineEnabled with [632]
15:43:07 [005330] 31: End Input Default Route [0]
15:43:07 [005330] 31: PhoneBook has GwNo=632, addr=192.168.0.246:5060
15:43:07 [005330] 31: ==7:Inviting
15:43:07 [005330] 31: VoIP CallOut, Invite <sip:632@192.168.0.246:5060;user=phone>
15:43:07 [005331] 31: 732=DIALING
15:43:07 [005333] 31: 732=PROCEEDING
15:43:07 [005336] 31: 732=CONNECTED
15:43:07 [005336] 31: Peer=192.168.0.246:10062, PT=8, RecvOnly=0
15:43:07 [005336] 31: RtpApiTalk[1,1], Peer=192.168.0.246:10062, PT=8, FC=6, NewOOB=0
15:43:07 [005336] 31: ==14:Talking
15:43:11 [005373] DSP_ch31_check=0
15:43:11 [005373] 31: Fxs Hangup
15:43:11 [005373] 31: Bye at Talking
15:43:11 [005373] 31: ==3:Idle
15:43:11 [005373] 31: SetFax(1)=0
15:43:11 [005375] 31: 732=DISCONNECT
15:43:11 [005375] 31: Release Old Dlg #2
А вот разрыв в процессе разговора:
16:18:01 [005585] 5: Fxs Pickup
16:18:01 [005585] 5: HotLineEnabled with [606]
16:18:01 [005585] 5: End Input Default Route [0]
16:18:01 [005585] 5: PhoneBook has GwNo=606, addr=192.168.0.246:5060
16:18:01 [005585] 5: ==7:Inviting
16:18:01 [005586] 5: VoIP CallOut, Invite <sip:606@192.168.0.246:5060;user=phone>
16:18:01 [005587] 5: 706=DIALING
16:18:01 [005588] 5: 706=PROCEEDING
16:18:02 [005592] 5: 706=CONNECTED
16:18:02 [005592] 5: Peer=192.168.0.246:10010, PT=8, RecvOnly=0
16:18:02 [005593] 5: RtpApiTalk[1,1], Peer=192.168.0.246:10010, PT=8, FC=6, NewOOB=0
16:18:02 [005593] 5: ==14:Talking
16:18:47 [006051] 5: 706=DISCONNECT
16:18:47 [006051] 5: Release Active Dlg
16:18:47 [006051] 5: ==15:PlayBusyTone
16:18:52 [006095] DSP_ch5_check=0
16:18:52 [006095] 5: Fxs Hangup
16:18:52 [006096] 5: ==3:Idle
16:18:52 [006096] 5: SetFax(1)=0
первое, что делал - это поменял прошивку, затем сбросил все настройки и настроил все заново,менял режимы Fax/Modem для линий, менял Gain-ы, менял кодеки (сейчас a-law)... - не спасает.
настройки данного HOT-LINE идентичны настройкам уже работающего на паре DVG-4032S и в точности совпадают с рекомендованными настроками по FAQ-у.
Вопрос: кто сталкивался и чем лечил?
 Заголовок сообщения: Re: HOT-LINE DVG-3032S - DVG-2032S
СообщениеДобавлено: Пт апр 29, 2011 12:10
а лог с 3032?
СообщениеДобавлено: Пт апр 29, 2011 12:30
нет - это лог с 2032S
просто проблема именно в нем, на мой взгляд.
в syslog-е на 3032S в момент разрыва (16:18:47 [006051] 5: 706=DISCONNECT) светится
Released By Peer
а в сислоге 2032S - честное признание - Released By Me
поэтому я и капаю со стороны абонентского FXS шлюза.
но на всякий - попозже выловлю на разрыве парный лог с обоих шлюзов.
СообщениеДобавлено: Пт апр 29, 2011 13:33
лог 2032:
14:27:40 [104382] 0: Fxs Pickup!
14:27:40 [104382] 0: HotLineEnabled with [601]
14:27:40 [104382] 0: End Input Default Route [0]
14:27:40 [104382] 0: PhoneBook has GwNo=601, addr=192.168.0.246:5060
14:27:40 [104382] 0: ==7:Inviting
14:27:40 [104382] 0: VoIP CallOut, Invite <sip:601@192.168.0.246:5060;user=phone>
14:27:40 [104384] 0: 701=DIALING
14:27:40 [104385] 0: 701=PROCEEDING
14:27:41 [104389] 0: 701=CONNECTED
14:27:41 [104389] 0: Peer=192.168.0.246:10000, PT=8, RecvOnly=0
14:27:41 [104389] 0: RtpApiTalk[1,1], Peer=192.168.0.246:10000, PT=8, FC=6, NewOOB=0
14:27:41 [104389] 0: ==14:Talking
14:28:11 [104694] 0: 701=DISCONNECT
14:28:11 [104694] 0: Release Active Dlg
14:28:11 [104694] 0: ==15:PlayBusyTone
14:28:13 [104717] DSP_ch0_check=0
14:28:13 [104717] 0: Fxs Hangup
14:28:13 [104717] 0: ==3:Idle
14:28:13 [104717] 0: SetFax(1)=0
лог 3032:
14:27:40 [104356] 0: 601=OFFERING
14:27:40 [104356] 0: Get CallerId=701
14:27:40 [104356] 0: Peer=192.168.0.247:10000, PT=8, RecvOnly=0
14:27:40 [104356] 0: TrunkPrefix=, Dest=, Dialno=
14:27:40 [104356] 0: FxoHookOff
14:27:40 [104356] 0: SetInputGain(4)
14:27:40 [104356] 0: ==18:TrunkDialOut
14:27:40 [104357] 0: Fxo DialOut OK
14:27:40 [104358] 0: 601=ACCEPT
14:27:40 [104358] 0: ==13:VoipAnswering
14:27:41 [104360] 0: 601=CONNECTED
14:27:41 [104361] 0: RtpApiTalk[1,1], Peer=192.168.0.247:10000, PT=8, FC=6, NewOOB=0
14:27:41 [104361] 0: ==14:Talking
14:28:11 [104663] 0: Fxo Detected BTC(2)
14:28:11 [104663] DSP_ch0_check=0
14:28:11 [104663] 0: FxoHookOn
14:28:11 [104663] 0: Bye at Talking
14:28:11 [104664] 0: ==15:PlayBusyTone
14:28:11 [104664] DSP_ch0_check=0
14:28:11 [104664] 0: FxoHookOn
14:28:11 [104664] 0: ==3:Idle
14:28:11 [104664] 0: SetInputGain(4)
14:28:11 [104664] 0: SetFax(1)=0
14:28:11 [104665] 0: 601=DISCONNECT
14:28:11 [104665] 0: Release Old Dlg #2
СообщениеДобавлено: Пт апр 29, 2011 13:40
Настраивайте cpt/cadence settings на 2032
СообщениеДобавлено: Пт апр 29, 2011 14:06
Вы имели ввиду в 3032 - раздел BTC?
оно действительно отличалось от того, что у меня на работающем HOT-LINE на 4032, но там стоит Auto Learning - Yes на них всех - это не собьет ручные настройки?
сейчас поставил, как 4032:
BTC # 1 210 190 0 0 Yes
BTC # 2 100 120 0 0 Yes
BTC # 3 330 240 0 0 Yes
BTC # 4 400 390 0 0 Yes
BTC # 5 250 320 350 400 Yes
наблюдаем.
Или Вы имели ввиду какие-то другие настройки cpt/cadence менять? (а остальное у меня идентично работающим 4032)
СообщениеДобавлено: Пт апр 29, 2011 14:20
обнулите все профили кроме 1 и 4
СообщениеДобавлено: Пт апр 29, 2011 15:06
сделал!
есть положительный результат!
ОГРОМНОЕ СПАСИБО!
