Текущее время: Чт окт 01, 2026 14:54
СообщениеДобавлено: Вс мар 27, 2011 12:46
Заметил что полка скорости 100мбит порта у 3526 - 9523840 байт/c
Firmware: Build 5.01.B65
Что не так?
DES-3526:admin#show packet ports 24
Command: show packet ports 24
Port number : 24
Frame Size    Frame Counts  Frames/sec    Frame Type  Total       Total/sec
64            3904694089    4164          RX Bytes    1803328941  1255268
65-127        4065654054    1369          RX Frames   3966883121  5609
128-255       695448025     296
256-511       356091683     296           TX Bytes    813585956   9523840
512-1023      550707823     311           TX Frames   1692981979  8945
1024-1518     382213871     8118
Unicast RX    3935075372    5600
Multicast RX  14451239      0
Broadcast RX  17356510      9
конфиг практически неизменный от начальных значений, все фичи выключены
DES-3526:admin#show config
Command: show config
Next possible completions:
current_config config_in_nvram
DES-3526:admin#show config current_config
Command: show config current_config
# DES-3526 Configuration
# Firmware: Build 5.01.B65
# Copyright(C) 2008 D-Link Corporation. All rights reserved.
# BASIC
config serial_port baud_rate 9600 auto_logout 10_minutes
enable telnet 23
disable web
# ACCOUNT LIST
create account admin admin
# PASSWORD ENCRYPTION
disable password encryption
config terminal_line default
# BNR
config command_prompt default
# STORM
config traffic control_trap none
config traffic control 1-5 broadcast disable multicast disable unicast disable action drop threshold 128000
# LOOP_DETECT
disable loopdetect
config loopdetect recover_timer 60
config loopdetect interval 10
config loopdetect mode port-based
config loopdetect ports 1-26 state disabled
# GM
config sim candidate
disable sim
config sim dp_interval 30
config sim hold_time 100
# SYSLOG
disable syslog
config system_severity trap information
config system_severity log information
# QOS
config scheduling 0 max_packet 0 max_latency 0
config scheduling 1 max_packet 0 max_latency 0
config scheduling 2 max_packet 0 max_latency 0
config scheduling 3 max_packet 0 max_latency 0
config 802.1p user_priority 0 1
config 802.1p user_priority 1 0
config 802.1p user_priority 2 0
config 802.1p user_priority 3 1
config 802.1p user_priority 4 2
config 802.1p user_priority 5 2
config 802.1p user_priority 6 3
config 802.1p user_priority 7 3
config 802.1p default_priority 1-26 0
config bandwidth_control 1-24 rx_rate 99 tx_rate 99
config bandwidth_control 25-26 rx_rate no_limit tx_rate no_limit
# MIRROR
disable mirror
# TRAF-SEGMENTATION
config traffic_segmentation 1-26 forward_list 1-26
# PORT
config ports 1-5,7,10-11,18,24 speed auto flow_control disable mdix auto learning enable state enable trap enable
config ports 6 speed auto flow_control disable mdix auto learning enable state enable description "glu33_opt" trap enable
config ports 8 speed auto flow_control disable mdix auto learning enable state enable description "Saksk-Genova_opt" trap enable
config ports 9 speed auto flow_control disable mdix auto learning enable state enable description "Ldoz_opt" trap enable
config ports 12 speed auto flow_control disable mdix auto learning enable state enable description "serv2" trap enable
config ports 13 speed auto flow_control disable mdix auto learning enable state enable description "Vald7-1" trap enable
config ports 14 speed auto flow_control disable mdix auto learning enable state enable description "mv16-Obsk3" trap enable
config ports 15 speed auto flow_control disable mdix auto learning enable state enable description "gs5-15_opt" trap enable
config ports 16 speed auto flow_control disable mdix auto learning enable state enable description "mzh15_opt" trap enable
config ports 17 speed auto flow_control disable mdix auto learning enable state enable description "gs17_opt" trap enable
config ports 19 speed auto flow_control disable mdix auto learning enable state enable description "mv49" trap enable
config ports 20 speed auto flow_control disable mdix auto learning enable state enable description "karalez" trap enable
config ports 21 speed auto flow_control disable mdix auto learning enable state enable description "gs31_opt" trap enable
config ports 22 speed auto flow_control disable mdix auto learning enable state enable description "mv51" trap enable
config ports 23 speed auto flow_control disable mdix auto learning enable state enable description "mzh3_opt" trap enable
config ports 25 medium_type copper speed auto flow_control disable mdix auto learning enable state enable description "Memet-Dub-Prom-1Gopt" trap enable
config ports 25 medium_type fiber speed auto flow_control disable learning enable state enable description "Memet-Dub-Prom-1Gopt" trap enable
config ports 26 medium_type copper speed auto flow_control disable mdix auto learning enable state enable description "servers" trap enable
config ports 26 medium_type fiber speed auto flow_control disable learning enable state enable description "servers" trap enable
# PORT_LOCK
disable port_security trap_log
config port_security ports 1-26 admin_state disable max_learning_addr 1 lock_address_mode DeleteOnReset
# 8021X
disable 802.1x
config 802.1x auth_protocol radius_eap
config 802.1x capability ports 1-26 none
config 802.1x auth_parameter ports 1-26 direction both port_control auto quiet_period 60 tx_period 30 supp_timeout 30 server_timeout 30 max_req 2 reauth_period 3600 enable_reauth disable
# SNMPv3
delete snmp community public
delete snmp community private
delete snmp user initial
delete snmp group initial
delete snmp view restricted all
delete snmp view CommunityView all
config snmp engineID 800000ab0300219193e41a
create snmp view restricted 1.3.6.1.2.1.1 view_type included
create snmp view restricted 1.3.6.1.2.1.11 view_type included
create snmp view restricted 1.3.6.1.6.3.10.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.11.2.1 view_type included
create snmp view restricted 1.3.6.1.6.3.15.1.1 view_type included
create snmp view CommunityView 1 view_type included
create snmp view CommunityView 1.3.6.1.6.3 view_type excluded
create snmp view CommunityView 1.3.6.1.6.3.1 view_type included
create snmp group public v1 read_view CommunityView notify_view CommunityView
create snmp group public v2c read_view CommunityView notify_view CommunityView
create snmp group initial v3 noauth_nopriv read_view restricted notify_view restricted
create snmp group private v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group private v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group ReadGroup v1 read_view CommunityView notify_view CommunityView
create snmp group ReadGroup v2c read_view CommunityView notify_view CommunityView
create snmp group WriteGroup v1 read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp group WriteGroup v2c read_view CommunityView write_view CommunityView notify_view CommunityView
create snmp community private view CommunityView read_write
create snmp community public view CommunityView read_only
create snmp user initial initial
# MANAGEMENT
enable snmp traps
enable snmp authenticate traps
config snmp system_name D-Link
disable rmon
# VLAN
disable asymmetric_vlan
config vlan default delete 1-26
config vlan default add untagged 1-26
config vlan default advertisement enable
disable gvrp
config gvrp 1-26 state disable ingress_checking enable acceptable_frame admit_all pvid 1
# FDB
config fdb aging_time 300
config multicast port_filtering_mode 1-26 forward_unregistered_groups
# MAC_ADDRESS_TABLE_NOTIFICATION
config mac_notification interval 1 historysize 1
disable mac_notification
config mac_notification ports 1-26 disable
# STP
config stp version rstp
config stp maxage 20 maxhops 20 forwarddelay 15 txholdcount 6 fbpdu enable
config stp priority 32768 instance_id 0
config stp hellotime 2
config stp mst_config_id name 00:21:91:93:E4:1A revision_level 0
disable stp
config stp ports 1-26 externalCost auto edge false p2p auto state enable
config stp ports 1-26 fbpdu disable
config stp ports 1-26 restricted_role false
config stp ports 1-26 restricted_tcn false
config stp mst_ports 1-26 instance_id 0 internalCost auto priority 128
# SSH
config ssh server maxsession 8
config ssh server contimeout 300
config ssh server authfail 2
config ssh server rekey never
config ssh server port 22
enable ssh
# SSL
disable ssl
enable ssl ciphersuite RSA_with_RC4_128_MD5
enable ssl ciphersuite RSA_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite DHE_DSS_with_3DES_EDE_CBC_SHA
enable ssl ciphersuite RSA_EXPORT_with_RC4_40_MD5
config ssl cachetimeout timeout 600
# SAFE_GUARD
config safeguard_engine state disable cpu_utilization rising_threshold 100 falling_threshold 20 trap_log enable
# TIMERANGE
# ACL
disable cpu_interface_filtering
# SNTP
disable sntp
config time_zone operator - hour 6 min 0
config sntp primary 0.0.0.0 secondary 0.0.0.0 poll-interval 720
config dst disable
# IPBIND
disable address_binding acl_mode
disable address_binding trap_log
disable address_binding dhcp_snoop
config address_binding dhcp_snoop max_entry ports 1-26 limit 5
# FILTER
# ARP_Spoofing_Prevention
# ROUTE
# SNOOP
enable igmp_snooping
config igmp_snooping default host_timeout 260 router_timeout 260 leave_timer 2 state enable
config igmp_snooping querier default query_interval 125 max_response_time 10 robustness_variable 2
config igmp_snooping querier default last_member_query_interval 1 state enable
config limited_multicast_addr ports 1-26 access deny state disable
# LACP
config link_aggregation algorithm mac_source
config lacp_port 1-26 mode passive
# GVLAN
# IP
config ipif System vlan default ipaddress 10.90.90.93/29 state enable
disable autoconfig
# ARP
config arp_aging time 20
config gratuitous_arp send ipif_status_up enable
config gratuitous_arp send dup_ip_detected enable
config gratuitous_arp learning enable
# LLDP
disable lldp
config lldp message_tx_interval 30
config lldp tx_delay 2
config lldp message_tx_hold_multiplier 4
config lldp reinit_delay 2
config lldp notification_interval 5
config lldp ports 1-26 notification disable
config lldp ports 1-26 admin_status tx_and_rx
# ACCESS_AUTHENTICATION_CONTROL
config authen_login default method local
config authen_enable default method local_enable
config authen application console login default
config authen application console enable default
config authen application telnet login default
config authen application telnet enable default
config authen application ssh login default
config authen application ssh enable default
config authen application http login default
config authen application http enable default
config authen parameter response_timeout 0
config authen parameter attempt 3
config authen enable_admin all state enable
disable authen_policy
# DHCP_RELAY
disable dhcp_relay
config dhcp_relay hops 4 time 0
config dhcp_relay option_82 state disable
config dhcp_relay option_82 check disable
config dhcp_relay option_82 policy replace
config dhcp_relay option_82 remote_id default
config dhcp_relay option_60 state disable
config dhcp_relay option_60 default mode drop
config dhcp_relay option_61 state disable
config dhcp_relay option_61 default drop
# DHCP_LOCAL_RELAY
disable dhcp_local_relay
# End of configuration file for DES-3526
СообщениеДобавлено: Пн мар 28, 2011 13:37
как проверяете-то?..
Это текст, который можно добавлять к размещаемым вами сообщениям. Длина его ограничена 255 символами.
СообщениеДобавлено: Пн мар 28, 2011 19:23
проверяю по show packet ports с разных направлений.
Трафик упирается в 9523840 и стоит на этом значении, при этом растет пинг.
Попробовал в конфиге применить
вместо no_limit - не повлияло на результат
СообщениеДобавлено: Вт мар 29, 2011 02:04
wireshark iperf в помощь.
А можно вопрос? Почему это Вас беспокоит?
СообщениеДобавлено: Вт мар 29, 2011 10:31
наверное, потому, что пинг растёт =)
ТС: прошивка у вас, мягко говоря, оооочень старая, обновите на всякий случай
СообщениеДобавлено: Ср мар 30, 2011 11:16
странный вопрос, наверное потому что я недополучаю 25% полосы?
СообщениеДобавлено: Ср мар 30, 2011 11:52
Эти счётчики нельзя использовать для замеров скорости передачи, для этого есть специальные инструменты.
P.S.
У меня на тесте цифры получились больше
TX Bytes 12294282
при 93.7 Mbits/sec
СообщениеДобавлено: Ср мар 30, 2011 12:26
это не проблема единичной станции, а проблема сегментов подключенных к этому свичу. Те сегменты, которые генерят достаточно трафика, упираются в значение 9300 кб/с (9523840/1024)
ок, пропущу через другой свич дополнительно, где нет такого ограничения в показаниях
СообщениеДобавлено: Ср мар 30, 2011 12:52
странно,
у свича Firmware: Build 5.01.B65.,
смотрю http://ftp.dlink.ru/pub/Switch/DES-3526 ... /Firmware/
[DIR]   Parent Directory        -
[ ]   DES-3500_Series_A4G_Release Note_v5.01.B65.doc   28-May-2010 18:20    147K
[TXT]   DES-3500_Series_Release Note for FW_v5.01.B52-(D-Link).txt   18-Nov-2008 12:31    20K
[ ]   DES-3526DC_5.01-B52.had   18-Nov-2008 12:32    3.2M
[ ]   DES-3526DC_A3_PROM code_v5.00.011.had   28-May-2010 18:20    130K
[ ]   DES-3526DC_A3_v5.01.B65.had   28-May-2010 18:20    3.2M
[ ]   DES-3526_PROM code_5.00.011.had   28-May-2010 18:20    128K
[ ]   DES-3526_Runtime code_5.01.B65.had   28-May-2010 18:20    3.2M
[ ]   DES3526_5.01-B52.had   18-Nov-2008 12:32    3.2M
[TXT]   README!.txt   15-Apr-2010 12:03    493
[ ]   acert.der   07-Apr-2006 16:09    721
[ ]   akey.der   07-Apr-2006 16:09    608
- не вижу ничего новее
СообщениеДобавлено: Ср мар 30, 2011 13:31
В специальной теме можно запросить: http://forum.dlink.ru/viewtopic.php?f=2&t=92700
СообщениеДобавлено: Сб апр 02, 2011 11:29
тесты скорости показали значения до 89Мбит/c,
кроме того SNMP счетчики выдают до 12066052 байт/c.
Спасибо.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 103
