Текущее время: Пт сен 25, 2026 11:12
 Заголовок сообщения: di804hv рвет связь
СообщениеДобавлено: Пт фев 18, 2011 10:43
Каждые полчаса, до этого год работал вообще без проблем. Ребутишь роутер, потом ручками коннектЮ, полчаса, час и опять разрывает соединение. Повайдер "Эртелеком", тип PPPoE.
System Logs
Sun Nov 07 14:22:50 2010 DOD:UDP trigger from 192.168.0.26:60496 to 79.132.7.7:55484
Sun Nov 07 14:22:50 2010 PPPoE start to dial-up
Sun Nov 07 14:22:50 2010 PADI sent
Sun Nov 07 14:22:51 2010 PADI sent
Sun Nov 07 14:22:53 2010 DOD:TCP trigger from 192.168.0.33:60081 to 140.114.15.44:443
Sun Nov 07 14:22:53 2010 PPPoE start to dial-up
Sun Nov 07 14:22:53 2010 PADI:3com sent
Sun Nov 07 14:22:54 2010 PADI:3com sent
Sun Nov 07 14:22:56 2010 DOD:TCP trigger from 192.168.0.33:60081 to 140.114.15.44:443
Sun Nov 07 14:22:56 2010 PPPoE start to dial-up
Sun Nov 07 14:22:56 2010 PADI sent
Sun Nov 07 14:22:56 2010 PADR sent
Sun Nov 07 14:22:56 2010 PADS recv 8002 0100
Sun Nov 07 14:22:56 2010 CHAP3: CHAP authentication success
Sun Nov 07 14:22:56 2010 IPCP3: IP is 88.ххх.ххх.ххх
Sun Nov 07 14:22:56 2010 IPCP3: DNS0 is 88.87.64.6
Sun Nov 07 14:22:56 2010 IPCP3: DNS1 is 88.87.65.3
Sun Nov 07 14:39:59 2010 PPPoE start to hang-up
Sun Nov 07 14:39:59 2010 PADT sent
Sun Nov 07 14:40:01 2010 Restarted by 192.168.0.33
Sun Nov 07 14:40:01 2010 DOD:UDP trigger from 192.168.0.61:49466 to 63.160.234.31:19940
Sun Nov 07 14:40:01 2010 PPPoE start to dial-up
Sun Nov 07 14:40:01 2010 PADI sent
Sun Nov 07 14:40:02 2010 PADI sent
Sun Nov 07 14:40:04 2010 DOD:UDP trigger from 192.168.0.23:35891 to 94.178.189.21:30629
Sun Nov 07 14:40:04 2010 PPPoE start to dial-up
Sun Nov 07 14:40:04 2010 PADI:3com sent
Sun Nov 07 14:40:05 2010 PADI:3com sent
Sun Nov 07 14:40:07 2010 DOD:UDP trigger from 192.168.0.61:49466 to 212.10.168.33:9132
Sun Nov 07 14:40:07 2010 PPPoE start to dial-up
Sun Nov 07 14:40:07 2010 PADI sent
Sun Nov 07 14:40:07 2010 PADR sent
Sun Nov 07 14:40:07 2010 PADS recv 8002 0100
Sun Nov 07 14:40:08 2010 CHAP3: CHAP authentication success
Sun Nov 07 14:40:08 2010 IPCP3: IP is 88.ххх.ххх.ххх
Sun Nov 07 14:40:08 2010 IPCP3: DNS0 is 88.87.64.6
Sun Nov 07 14:40:08 2010 IPCP3: DNS1 is 88.87.65.3
Mon Nov 08 03:37:28 2010 DDNS:update ххх.dyndns.org to 88.ххх.ххх.ххх
Mon Nov 08 03:38:25 2010 Connection is broken
Mon Nov 08 03:38:25 2010 PPPoE start to hang-up
Mon Nov 08 03:38:30 2010 PADT sent
Mon Nov 08 03:38:30 2010 DOD:TCP trigger from 192.168.0.33:62278 to 95.247.238.158:443
Mon Nov 08 03:38:30 2010 PPPoE start to dial-up
Mon Nov 08 03:38:30 2010 PADI sent
Mon Nov 08 03:38:31 2010 PADI sent
Mon Nov 08 03:38:35 2010 DOD:TCP trigger from 192.168.0.66:51847 to 88.198.6.55:8080
Mon Nov 08 03:38:35 2010 PPPoE start to dial-up
Mon Nov 08 03:38:35 2010 PADI:3com sent
Mon Nov 08 03:38:36 2010 PADI:3com sent
Mon Nov 08 03:38:37 2010 DDNS:members.dyndns.org,-1
Mon Nov 08 03:38:40 2010 DOD:triggered internally
Mon Nov 08 03:38:40 2010 PPPoE start to dial-up
Mon Nov 08 03:38:40 2010 PADI sent
Mon Nov 08 03:38:41 2010 PADI sent
Mon Nov 08 03:38:44 2010 DOD:UDP trigger from 192.168.0.66:14250 to 94.180.224.248:39783
Mon Nov 08 03:38:44 2010 PPPoE start to dial-up
Mon Nov 08 03:38:44 2010 PADI:3com sent
Mon Nov 08 03:38:45 2010 PADI:3com sent
Mon Nov 08 03:38:48 2010 DOD:TCP trigger from 192.168.0.33:62891 to 66.220.151.86:80
Mon Nov 08 03:38:48 2010 PPPoE start to dial-up
Mon Nov 08 03:38:48 2010 PADI sent
Mon Nov 08 03:38:49 2010 PADI sent
Mon Nov 08 03:38:51 2010 DOD:TCP trigger from 192.168.0.33:62891 to 66.220.151.86:80
Mon Nov 08 03:38:51 2010 PPPoE start to dial-up
Mon Nov 08 03:38:51 2010 PADI:3com sent
Mon Nov 08 03:38:52 2010 PADI:3com sent
Mon Nov 08 03:38:54 2010 DOD:triggered internally
Mon Nov 08 03:38:54 2010 PPPoE start to dial-up
Mon Nov 08 03:38:54 2010 PADI sent
Mon Nov 08 03:38:55 2010 PADI sent
Mon Nov 08 03:38:57 2010 DOD:UDP trigger from 192.168.0.66:14250 to 92.243.64.124:57664
Mon Nov 08 03:38:57 2010 PPPoE start to dial-up
Mon Nov 08 03:38:57 2010 PADI:3com sent
Mon Nov 08 03:38:58 2010 PADI:3com sent
Mon Nov 08 03:39:01 2010 DOD:triggered internally
Mon Nov 08 03:39:01 2010 PPPoE start to dial-up
Mon Nov 08 03:39:01 2010 PADI sent
Mon Nov 08 03:39:02 2010 PADI sent
Mon Nov 08 03:39:04 2010 DOD:UDP trigger from 192.168.0.66:14250 to 85.173.13.246:15702
Mon Nov 08 03:39:04 2010 PPPoE start to dial-up
Mon Nov 08 03:39:04 2010 PADI:3com sent
Mon Nov 08 03:39:05 2010 PADI:3com sent
Mon Nov 08 03:39:08 2010 DOD:TCP trigger from 192.168.0.66:51856 to 95.28.69.201:16832
Mon Nov 08 03:39:08 2010 PPPoE start to dial-up
Mon Nov 08 03:39:08 2010 PADI sent
Mon Nov 08 03:39:09 2010 PADI sent
Mon Nov 08 03:39:11 2010 DOD:TCP trigger from 192.168.0.66:51864 to 88.198.6.54:8080
Mon Nov 08 03:39:11 2010 PPPoE start to dial-up
Mon Nov 08 03:39:11 2010 PADI:3com sent
Mon Nov 08 03:39:12 2010 PADI:3com sent
Mon Nov 08 03:39:14 2010 DOD:TCP trigger from 192.168.0.66:51864 to 88.198.6.54:8080
Mon Nov 08 03:39:14 2010 PPPoE start to dial-up
Mon Nov 08 03:39:14 2010 PADI sent
Mon Nov 08 03:39:15 2010 PADI sent
Mon Nov 08 03:39:19 2010 DOD:triggered internally
Mon Nov 08 03:39:19 2010 PPPoE start to dial-up
Mon Nov 08 03:39:19 2010 PADI:3com sent
Mon Nov 08 03:39:20 2010 PADI:3com sent
Mon Nov 08 03:39:22 2010 DOD:triggered internally
Mon Nov 08 03:39:22 2010 PPPoE start to dial-up
Mon Nov 08 03:39:22 2010 PADI sent
Mon Nov 08 03:39:23 2010 PADI sent
Mon Nov 08 03:39:27 2010 DOD:triggered internally
Mon Nov 08 03:39:27 2010 PPPoE start to dial-up
Mon Nov 08 03:39:27 2010 PADI:3com sent
Mon Nov 08 03:39:28 2010 PADI:3com sent
Mon Nov 08 03:39:32 2010 DOD:UDP trigger from 192.168.0.66:14250 to 77.73.24.53:58988
Mon Nov 08 03:39:32 2010 PPPoE start to dial-up
Mon Nov 08 03:39:32 2010 PADI sent
Mon Nov 08 03:39:33 2010 PADI sent
Mon Nov 08 03:39:35 2010 DOD:TCP trigger from 192.168.0.33:62298 to 87.239.184.124:443
Mon Nov 08 03:39:35 2010 PPPoE start to dial-up
Mon Nov 08 03:39:35 2010 PADI:3com sent
Mon Nov 08 03:39:36 2010 PADI:3com sent
Mon Nov 08 03:39:40 2010 DOD:UDP trigger from 192.168.0.66:14250 to 77.108.196.183:15225
Mon Nov 08 03:39:40 2010 PPPoE start to dial-up
Mon Nov 08 03:39:40 2010 PADI sent
Mon Nov 08 03:39:41 2010 PADI sent
Mon Nov 08 03:39:45 2010 DOD:UDP trigger from 192.168.0.66:14250 to 95.52.94.13:45593
Mon Nov 08 03:39:45 2010 PPPoE start to dial-up
Mon Nov 08 03:39:45 2010 PADI:3com sent
Mon Nov 08 03:39:46 2010 PADI:3com sent
Mon Nov 08 03:39:50 2010 DOD:triggered internally
Mon Nov 08 03:39:50 2010 PPPoE start to dial-up
Mon Nov 08 03:39:50 2010 PADI sent
Mon Nov 08 03:39:51 2010 PADI sent
Mon Nov 08 03:39:53 2010 DOD:TCP trigger from 192.168.0.33:62942 to 66.220.151.86:80
Mon Nov 08 03:39:53 2010 PPPoE start to dial-up
Mon Nov 08 03:39:53 2010 PADI:3com sent
Mon Nov 08 03:39:54 2010 PADI:3com sent
Mon Nov 08 03:39:57 2010 DOD:TCP trigger from 192.168.0.66:51875 to 87.239.184.124:8080
Mon Nov 08 03:39:57 2010 PPPoE start to dial-up
Mon Nov 08 03:39:57 2010 PADI sent
Mon Nov 08 03:39:58 2010 PADI sent
Mon Nov 08 03:40:00 2010 DOD:TCP trigger from 192.168.0.66:51875 to 87.239.184.124:8080
Mon Nov 08 03:40:00 2010 PPPoE start to dial-up
Mon Nov 08 03:40:00 2010 PADI:3com sent
Mon Nov 08 03:40:01 2010 PADI:3com sent
Mon Nov 08 03:40:03 2010 DOD:TCP trigger from 192.168.0.33:62299 to 77.79.141.70:443
Mon Nov 08 03:40:03 2010 PPPoE start to dial-up
Mon Nov 08 03:40:03 2010 PADI sent
Mon Nov 08 03:40:04 2010 PADI sent
Mon Nov 08 03:40:06 2010 DOD:TCP trigger from 192.168.0.66:51878 to 93.80.127.126:40273
Mon Nov 08 03:40:06 2010 PPPoE start to dial-up
Mon Nov 08 03:40:06 2010 PADI:3com sent
Mon Nov 08 03:40:07 2010 PADI:3com sent
Mon Nov 08 03:40:11 2010 DOD:TCP trigger from 192.168.0.33:62803 to 217.20.145.66:80
Mon Nov 08 03:40:11 2010 PPPoE start to dial-up
Mon Nov 08 03:40:11 2010 PADI sent
Mon Nov 08 03:40:12 2010 PADI sent
Mon Nov 08 03:40:14 2010 DOD:TCP trigger from 192.168.0.33:62301 to 93.80.127.126:443
Mon Nov 08 03:40:14 2010 PPPoE start to dial-up
Mon Nov 08 03:40:14 2010 PADI:3com sent
Mon Nov 08 03:40:15 2010 PADI:3com sent
Mon Nov 08 03:40:17 2010 DOD:TCP trigger from 192.168.0.33:62803 to 217.20.145.66:80
Mon Nov 08 03:40:17 2010 PPPoE start to dial-up
Mon Nov 08 03:40:17 2010 PADI sent
Mon Nov 08 03:40:18 2010 PADI sent
Mon Nov 08 03:40:21 2010 DOD:TCP trigger from 192.168.0.33:62303 to 69.64.58.38:443
Mon Nov 08 03:40:21 2010 PPPoE start to dial-up
Mon Nov 08 03:40:21 2010 PADI:3com sent
Mon Nov 08 03:40:22 2010 PADI:3com sent
Mon Nov 08 03:40:24 2010 DOD:TCP trigger from 192.168.0.33:62803 to 217.20.145.66:80
Mon Nov 08 03:40:24 2010 PPPoE start to dial-up
Mon Nov 08 03:40:24 2010 PADI sent
Mon Nov 08 03:40:25 2010 PADI sent
Mon Nov 08 03:40:32 2010 DOD:TCP trigger from 192.168.0.33:62304 to 213.146.189.206:443
Mon Nov 08 03:40:32 2010 PPPoE start to dial-up
Mon Nov 08 03:40:32 2010 PADI:3com sent
Mon Nov 08 03:40:33 2010 PADI:3com sent
Mon Nov 08 03:40:35 2010 DOD:TCP trigger from 192.168.0.33:62304 to 213.146.189.206:443
Mon Nov 08 03:40:35 2010 PPPoE start to dial-up
Mon Nov 08 03:40:35 2010 PADI sent
Mon Nov 08 03:40:36 2010 PADI sent
Mon Nov 08 03:40:38 2010 DOD:TCP trigger from 192.168.0.66:51897 to 213.146.189.206:12350
Mon Nov 08 03:40:38 2010 PPPoE start to dial-up
Mon Nov 08 03:40:38 2010 PADI:3com sent
Mon Nov 08 03:40:39 2010 PADI:3com sent
Mon Nov 08 03:40:41 2010 DOD:TCP trigger from 192.168.0.66:51902 to 121.103.236.23:14597
Mon Nov 08 03:40:41 2010 PPPoE start to dial-up
Mon Nov 08 03:40:41 2010 PADI sent
Mon Nov 08 03:40:42 2010 PADI sent
Mon Nov 08 03:40:45 2010 DOD:TCP trigger from 192.168.0.66:51908 to 69.64.58.38:8080
Mon Nov 08 03:40:45 2010 PPPoE start to dial-up
Mon Nov 08 03:40:45 2010 PADI:3com sent
Mon Nov 08 03:40:46 2010 PADI:3com sent
Mon Nov 08 03:40:48 2010 DOD:TCP trigger from 192.168.0.66:51914 to 119.238.253.171:28305
Mon Nov 08 03:40:48 2010 PPPoE start to dial-up
Mon Nov 08 03:40:48 2010 PADI sent
Mon Nov 08 03:40:49 2010 PADI sent
Mon Nov 08 03:40:51 2010 DOD:TCP trigger from 192.168.0.66:51914 to 119.238.253.171:28305
Mon Nov 08 03:40:51 2010 PPPoE start to dial-up
Mon Nov 08 03:40:51 2010 PADI:3com sent
Mon Nov 08 03:40:52 2010 PADI:3com sent
Mon Nov 08 03:40:54 2010 DOD:TCP trigger from 192.168.0.66:51918 to 121.102.97.106:63432
Mon Nov 08 03:40:54 2010 PPPoE start to dial-up
Mon Nov 08 03:40:54 2010 PADI sent
Mon Nov 08 03:40:55 2010 PADI sent
Mon Nov 08 03:40:57 2010 DOD:TCP trigger from 192.168.0.66:51918 to 121.102.97.106:63432
Mon Nov 08 03:40:57 2010 PPPoE start to dial-up
Mon Nov 08 03:40:57 2010 PADI:3com sent
Mon Nov 08 03:40:58 2010 PADI:3com sent
Mon Nov 08 03:41:00 2010 DOD:triggered internally
Mon Nov 08 03:41:00 2010 PPPoE start to dial-up
Mon Nov 08 03:41:00 2010 PADI sent
Mon Nov 08 03:41:01 2010 PADI sent
Mon Nov 08 03:41:04 2010 DOD:TCP trigger from 192.168.0.33:62313 to 94.79.54.222:443
Mon Nov 08 03:41:04 2010 PPPoE start to dial-up
Mon Nov 08 03:41:04 2010 PADI:3com sent
Mon Nov 08 03:41:05 2010 PADI:3com sent
Mon Nov 08 03:41:07 2010 DOD:TCP trigger from 192.168.0.66:51923 to 95.53.172.58:3060
Mon Nov 08 03:41:07 2010 PPPoE start to dial-up
Mon Nov 08 03:41:07 2010 PADI sent
Mon Nov 08 03:41:08 2010 PADI sent
Mon Nov 08 03:41:12 2010 DOD:TCP trigger from 192.168.0.33:62312 to 70.38.40.189:443
Mon Nov 08 03:41:12 2010 PPPoE start to dial-up
Mon Nov 08 03:41:12 2010 PADI:3com sent
Mon Nov 08 03:41:13 2010 PADI:3com sent
Mon Nov 08 03:41:16 2010 DOD:TCP trigger from 192.168.0.33:62966 to 66.220.151.86:80
Mon Nov 08 03:41:16 2010 PPPoE start to dial-up
Mon Nov 08 03:41:16 2010 PADI sent
Mon Nov 08 03:41:17 2010 PADI sent
Mon Nov 08 03:41:20 2010 DOD:UDP trigger from 192.168.0.66:14250 to 95.26.48.154:53421
Mon Nov 08 03:41:20 2010 PPPoE start to dial-up
Mon Nov 08 03:41:20 2010 PADI:3com sent
Mon Nov 08 03:41:21 2010 PADI:3com sent
Mon Nov 08 03:41:26 2010 DOD:UDP trigger from 192.168.0.66:14250 to 78.106.206.115:14952
Mon Nov 08 03:41:26 2010 PPPoE start to dial-up
Mon Nov 08 03:41:26 2010 PADI sent
Mon Nov 08 03:41:27 2010 PADI sent
Mon Nov 08 03:41:30 2010 DOD:TCP trigger from 192.168.0.66:51935 to 70.38.40.189:8080
Mon Nov 08 03:41:30 2010 PPPoE start to dial-up
Mon Nov 08 03:41:30 2010 PADI:3com sent
Mon Nov 08 03:41:31 2010 PADI:3com sent
Mon Nov 08 03:41:34 2010 DOD:UDP trigger from 192.168.0.66:14250 to 92.243.64.125:46637
Mon Nov 08 03:41:34 2010 PPPoE start to dial-up
Mon Nov 08 03:41:34 2010 PADI sent
Mon Nov 08 03:41:35 2010 PADI sent
Mon Nov 08 03:41:40 2010 DOD:UDP trigger from 192.168.0.66:14250 to 79.111.235.148:44774
Mon Nov 08 03:41:40 2010 PPPoE start to dial-up
Mon Nov 08 03:41:40 2010 PADI:3com sent
Mon Nov 08 03:41:41 2010 PADI:3com sent
Mon Nov 08 03:41:45 2010 DOD:TCP trigger from 192.168.0.33:62211 to 213.146.189.205:443
Mon Nov 08 03:41:45 2010 PPPoE start to dial-up
Mon Nov 08 03:41:45 2010 PADI sent
Mon Nov 08 03:41:46 2010 PADI sent
Mon Nov 08 03:41:51 2010 DOD:TCP trigger from 192.168.0.33:62317 to 70.38.40.190:443
Mon Nov 08 03:41:51 2010 PPPoE start to dial-up
Mon Nov 08 03:41:51 2010 PADI:3com sent
Mon Nov 08 03:41:52 2010 PADI:3com sent
Mon Nov 08 03:41:54 2010 DOD:triggered internally
Mon Nov 08 03:41:54 2010 PPPoE start to dial-up
Mon Nov 08 03:41:54 2010 PADI sent
Mon Nov 08 03:41:55 2010 PADI sent
Mon Nov 08 03:41:57 2010 DOD:triggered internally
Mon Nov 08 03:41:57 2010 PPPoE start to dial-up
Mon Nov 08 03:41:57 2010 PADI:3com sent
Mon Nov 08 03:41:58 2010 PADI:3com sent
Mon Nov 08 03:42:06 2010 DOD:TCP trigger from 192.168.0.33:62318 to 90.157.120.224:443
Mon Nov 08 03:42:06 2010 PPPoE start to dial-up
Mon Nov 08 03:42:06 2010 PADI sent
Mon Nov 08 03:42:07 2010 PADI sent
Mon Nov 08 03:42:09 2010 DOD:TCP trigger from 192.168.0.66:51940 to 95.78.45.65:54666
Mon Nov 08 03:42:09 2010 PPPoE start to dial-up
Mon Nov 08 03:42:09 2010 PADI:3com sent
Mon Nov 08 03:42:10 2010 PADI:3com sent
Mon Nov 08 03:42:12 2010 DOD:TCP trigger from 192.168.0.33:62324 to 121.111.111.178:443
Mon Nov 08 03:42:12 2010 PPPoE start to dial-up
Mon Nov 08 03:42:12 2010 PADI sent
Mon Nov 08 03:42:13 2010 PADI sent
Mon Nov 08 03:42:15 2010 DOD:TCP trigger from 192.168.0.33:62324 to 121.111.111.178:443
Mon Nov 08 03:42:15 2010 PPPoE start to dial-up
Mon Nov 08 03:42:15 2010 PADI:3com sent
Mon Nov 08 03:42:16 2010 PADI:3com sent
Mon Nov 08 03:42:18 2010 DOD:TCP trigger from 192.168.0.33:62325 to 115.164.48.96:443
Mon Nov 08 03:42:18 2010 PPPoE start to dial-up
Mon Nov 08 03:42:18 2010 PADI sent
Mon Nov 08 03:42:19 2010 PADI sent
Mon Nov 08 03:42:21 2010 DOD:TCP trigger from 192.168.0.33:62325 to 115.164.48.96:443
Mon Nov 08 03:42:21 2010 PPPoE start to dial-up
Mon Nov 08 03:42:21 2010 PADI:3com sent
Mon Nov 08 03:42:22 2010 PADI:3com sent
Mon Nov 08 03:42:25 2010 DOD:triggered internally
Mon Nov 08 03:42:25 2010 PPPoE start to dial-up
Mon Nov 08 03:42:25 2010 PADI sent
Mon Nov 08 03:42:26 2010 PADI sent
Mon Nov 08 03:42:28 2010 DOD:TCP trigger from 192.168.0.33:62326 to 219.111.55.206:443
Mon Nov 08 03:42:28 2010 PPPoE start to dial-up
Mon Nov 08 03:42:28 2010 PADI:3com sent
Mon Nov 08 03:42:29 2010 PADI:3com sent
Mon Nov 08 03:42:31 2010 DOD:TCP trigger from 192.168.0.66:51971 to 221.56.195.146:48016
Mon Nov 08 03:42:31 2010 PPPoE start to dial-up
Mon Nov 08 03:42:31 2010 PADI sent
Mon Nov 08 03:42:32 2010 PADI sent
Mon Nov 08 03:42:34 2010 DOD:TCP trigger from 192.168.0.66:51971 to 221.56.195.146:48016
Mon Nov 08 03:42:34 2010 PPPoE start to dial-up
Mon Nov 08 03:42:34 2010 PADI:3com sent
Mon Nov 08 03:42:35 2010 PADI:3com sent
Mon Nov 08 03:42:38 2010 DOD:TCP trigger from 192.168.0.33:62329 to 62.75.224.229:443
Mon Nov 08 03:42:38 2010 PPPoE start to dial-up
Mon Nov 08 03:42:38 2010 PADI sent
Mon Nov 08 03:42:39 2010 PADI sent
Mon Nov 08 03:42:41 2010 DOD:TCP trigger from 192.168.0.33:62329 to 62.75.224.229:443
Mon Nov 08 03:42:41 2010 PPPoE start to dial-up
Mon Nov 08 03:42:41 2010 PADI:3com sent
Mon Nov 08 03:42:42 2010 PADI:3com sent
Mon Nov 08 03:42:46 2010 DOD:TCP trigger from 192.168.0.33:62211 to 213.146.189.205:443
Mon Nov 08 03:42:46 2010 PPPoE start to dial-up
Mon Nov 08 03:42:46 2010 PADI sent
Mon Nov 08 03:42:47 2010 PADI sent
Mon Nov 08 03:42:53 2010 DOD:TCP trigger from 192.168.0.33:62994 to 66.220.151.86:80
Mon Nov 08 03:42:53 2010 PPPoE start to dial-up
Mon Nov 08 03:42:53 2010 PADI:3com sent
Mon Nov 08 03:42:54 2010 PADI:3com sent
Mon Nov 08 03:42:56 2010 DOD:TCP trigger from 192.168.0.33:62994 to 66.220.151.86:80
Mon Nov 08 03:42:56 2010 PPPoE start to dial-up
Mon Nov 08 03:42:56 2010 PADI sent
Mon Nov 08 03:42:57 2010 PADI sent
Mon Nov 08 03:42:59 2010 DOD:UDP trigger from 192.168.0.66:14250 to 94.124.241.43:60599
Mon Nov 08 03:42:59 2010 PPPoE start to dial-up
Mon Nov 08 03:42:59 2010 PADI:3com sent
Mon Nov 08 03:43:00 2010 PADI:3com sent
Mon Nov 08 03:43:02 2010 DOD:TCP trigger from 192.168.0.66:51979 to 62.75.224.229:8080
Mon Nov 08 03:43:02 2010 PPPoE start to dial-up
Mon Nov 08 03:43:02 2010 PADI sent
Mon Nov 08 03:43:03 2010 PADI sent
Mon Nov 08 03:43:05 2010 DOD:TCP trigger from 192.168.0.66:51979 to 62.75.224.229:8080
Mon Nov 08 03:43:05 2010 PPPoE start to dial-up
Mon Nov 08 03:43:05 2010 PADI:3com sent
Mon Nov 08 03:43:06 2010 PADI:3com sent
Mon Nov 08 03:43:08 2010 DOD:TCP trigger from 192.168.0.66:51983 to 95.78.187.57:12684
Mon Nov 08 03:43:08 2010 PPPoE start to dial-up
Mon Nov 08 03:43:08 2010 PADI sent
Mon Nov 08 03:43:09 2010 PADI sent
Mon Nov 08 03:43:11 2010 DOD:TCP trigger from 192.168.0.66:51983 to 95.78.187.57:12684
Mon Nov 08 03:43:11 2010 PPPoE start to dial-up
Mon Nov 08 03:43:11 2010 PADI:3com sent
Mon Nov 08 03:43:12 2010 PADI:3com sent
Mon Nov 08 03:43:15 2010 DOD:UDP trigger from 192.168.0.26:56984 to 212.53.40.40:5060
Mon Nov 08 03:43:15 2010 PPPoE start to dial-up
Mon Nov 08 03:43:15 2010 PADI sent
Mon Nov 08 03:43:16 2010 PADI sent
Mon Nov 08 03:43:18 2010 DOD:UDP trigger from 192.168.0.66:14250 to 94.180.10.146:55561
Mon Nov 08 03:43:18 2010 PPPoE start to dial-up
Mon Nov 08 03:43:18 2010 PADI:3com sent
Mon Nov 08 03:43:19 2010 PADI:3com sent
Mon Nov 08 03:43:21 2010 DOD:triggered internally
Mon Nov 08 03:43:21 2010 PPPoE start to dial-up
Mon Nov 08 03:43:21 2010 PADI sent
Mon Nov 08 03:43:22 2010 Restarted by 192.168.0.33
Mon Nov 08 03:43:23 2010 DOD:TCP trigger from 192.168.0.33:62340 to 88.198.6.55:443
Mon Nov 08 03:43:23 2010 PPPoE start to dial-up
Mon Nov 08 03:43:23 2010 PADI sent
Mon Nov 08 03:43:24 2010 PADI sent
Mon Nov 08 03:43:24 2010 PADR sent
Mon Nov 08 03:43:24 2010 PADS recv 8002 0100
Mon Nov 08 03:43:24 2010 CHAP3: CHAP authentication success
Mon Nov 08 03:43:24 2010 IPCP3: IP is 88.ххх.ххх.ххх
Mon Nov 08 03:43:24 2010 IPCP3: DNS0 is 88.87.64.6
Mon Nov 08 03:43:24 2010 IPCP3: DNS1 is 88.87.65.3
 Заголовок сообщения: Re: di804hv рвет связь
СообщениеДобавлено: Сб фев 19, 2011 14:31
Поменял б\п, сутки отработал нормально, потом опять разорвал соединение и пока не перезагрузил, и руками не нажал коннект, роутер не подключался к пров. Роутер подключен к электричеству через ИБП.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 61
