Текущее время: Вс окт 04, 2026 01:01
СообщениеДобавлено: Вт дек 28, 2010 12:37
Конифг
enable igmp_snooping
config igmp_snooping data_driven_learning max_learned_entry 56
enable igmp_snooping multicast_vlan
create igmp_snooping multicast_vlan v4001 4001
config igmp_snooping multicast_vlan v4001 state enable
config igmp_snooping multicast_vlan v4001 replace_source_ip 10.12.30.15
config igmp_snooping multicast_vlan v4001 add member_port 1-24
config igmp_snooping multicast_vlan v4001 add tag_member_port 26-28
config igmp_snooping multicast_vlan v4001 add source_port 25
create mcast_filter_profile profile_id 1 profile_name IPTV1
create mcast_filter_profile profile_id 23 profile_name firmware
config mcast_filter_profile profile_id 1 add 238.1.53.0-238.1.53.255
config mcast_filter_profile profile_id 23 add 224.2.2.0-224.2.2.255
config max_mcast_group port 1-28 max_group 256
config limited_multicast_addr ports 1-24 access permit
config limited_multicast_addr ports 1-24 add profile_id 1
config limited_multicast_addr ports 1-24 add profile_id 23
Т.е. настроен ISM vlan 4001, клиенты находятся в vlan 110
Теперь смотрим:
Command: show igmp_snooping forwarding
 VLAN Name      : v110
 Multicast Group: 224.0.0.22
 MAC Address    : 01-00-5E-00-00-16
 Member Ports   :
 VLAN Name      : v110
 Multicast Group: 224.0.1.60
 MAC Address    : 01-00-5E-00-01-3C
 Member Ports   :
 VLAN Name      : v110
 Multicast Group: 239.192.152.143
 MAC Address    : 01-00-5E-40-98-8F
 Member Ports   :
 VLAN Name      : v110
 Multicast Group: 239.255.2.2
 MAC Address    : 01-00-5E-7F-02-02
 Member Ports   :
 VLAN Name      : v110
 Multicast Group: 239.255.255.250
 MAC Address    : 01-00-5E-7F-FF-FA
 Member Ports   :
 VLAN Name      : v4001
 Multicast Group: 238.1.53.2
 MAC Address    : 01-00-5E-01-35-02
 Member Ports   : 25
 VLAN Name      : v4001
 Multicast Group: 238.1.53.3
 MAC Address    : 01-00-5E-01-35-03
 Member Ports   : 25
 VLAN Name      : v4001
 Multicast Group: 238.1.53.49
 MAC Address    : 01-00-5E-01-35-31
 Member Ports   : 25
 Total Entries : 42
Почему снупятся запросы в 110 влане? Почему не работает limited_multicast ( например для 224.0.1.60, 239.192.152.143, 239.255.2.2 ...)
Или все это не страшно, и переживания по этому поводу от лукавого?
Command: show igmp_snooping vlan v110
 IGMP Snooping Global State            : Enabled
 Multicast Router Only                 : Disabled
 Data Driven Learning Max Entries      : 56
 VLAN  Name                    : v110
 Query Interval                : 125
 Max Response Time             : 10
 Robustness Value              : 2
 Last Member Query Interval    : 1
 Host Timeout                  : 260
 Route Timeout                 : 260
 Leave Timer                   : 2
 Querier State                 : Disabled
 Querier Router Behavior       : Non-Querier
 State                         : Disabled
 Multicast Fast Leave          : Disabled
 Data Driven Learning Aged Out : Disabled
Boot PROM Version  : Build 1.00.B06
Firmware Version   : Build 2.50.B08
Hardware Version   : A1
СообщениеДобавлено: Вт дек 28, 2010 12:47
Так и должно быть. Чтобы избавиться от левых групп надо использовать CPU ACL
СообщениеДобавлено: Вт дек 28, 2010 12:55
Если не делать CPU ACL будут ли какие-то негативные последствия для самого коммутатора в данной ситуации?
СообщениеДобавлено: Вт дек 28, 2010 13:00
только если переполнится таблица igmp групп
СообщениеДобавлено: Вт дек 28, 2010 13:05
Еще просьба уточнить:
VLAN Name : v4001
Member Ports : 25
На эту группу никто не подписан, но тем не менее видим 25 порт участвует в форвандинге, хотя на самом деле он source.
СообщениеДобавлено: Чт дек 30, 2010 06:30
А рост количества igmp групп не может вызвать рост записей в таблице fdb и тем самым её переполнение?
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 120
