Текущее время: Вт сен 22, 2026 13:20
СообщениеДобавлено: Вт ноя 30, 2010 02:19
Dir-655, Hardware Version: A4, Firmware Version: 1.34WW.
Периодически (раз в несколько минут-часов) пропадает связь на компе, подключенном по вай-фай. Сеть подключена, но написано "ограниченный доступ". Подключение - 150 Мбит.
С 20 MHz (1 канал) - скорость 65 Мбит, но ничего не падает. На 54 Мбитах - g, тоже ни единого разрыва.
Вот лог.
Сообщение при нормальном подключении-отключении:
[INFO]   Mon Nov 29 23:53:51 2010   BNP: Wireless system with MAC address F07BCB902508 disconnected for reason: Received Deauthentication
[INFO]   Mon Nov 29 23:48:25 2010   BNP: Wireless system with MAC address F07BCB902508 secured and linked
[INFO]   Mon Nov 29 23:48:25 2010   BNP: Wireless system with MAC address F07BCB902508 associated
Вот сообщения при "разрывах":
[INFO]   Tue Nov 30 01:58:01 2010   BNP: Wireless system with MAC address F07BCB902508 secured and linked
[INFO]   Tue Nov 30 01:58:01 2010   BNP: Wireless system with MAC address F07BCB902508 associated
[INFO]   Tue Nov 30 01:58:01 2010   Above message repeated 1 times
[INFO]   Tue Nov 30 00:56:52 2010   Administrator logout
[INFO]   Tue Nov 30 00:51:52 2010   Log viewed by IP address 192.168.0.11
[INFO]   Tue Nov 30 00:50:40 2010   Allowed configuration authentication by IP address 192.168.0.11
[INFO]   Tue Nov 30 00:34:38 2010   BNP: Wireless system with MAC address F07BCB902508 secured and linked
[INFO]   Tue Nov 30 00:34:38 2010   BNP: Wireless system with MAC address F07BCB902508 associated
[INFO]   Tue Nov 30 00:34:38 2010   Above message repeated 1 times
[INFO]   Tue Nov 30 00:22:41 2010   Administrator logout
[INFO]   Tue Nov 30 00:17:30 2010   Allowed configuration authentication by IP address 192.168.0.11
[INFO]   Mon Nov 29 23:54:57 2010   BNP: Wireless system with MAC address F07BCB902508 secured and linked
[INFO]   Mon Nov 29 23:54:56 2010   BNP: Wireless system with MAC address F07BCB902508 associated
[INFO]   Mon Nov 29 23:54:56 2010   Above message repeated 1 times
За 2 часа - 3 раза пропадала связь.
Думал, драйвера сетевой и косяки ОС, но друг купил себе такой же роутер и говорит, что у него на wi-fi n то же самое...
У кого-нибудь наблюдается похожая ситуация? Что можно сделать, куда копать?
СообщениеДобавлено: Вт ноя 30, 2010 17:34
После прошивки сброс на заводские настройки осуществляли?
Какой беспроводной адаптер и какой драйвер используется на компьютере?
Какая ОС?
Какие настройки беспроводной сети роутера?
СообщениеДобавлено: Вт ноя 30, 2010 22:23
Сброс осуществлял.
Адаптеры Atheros AR9285. Драйвер у друга - 8.0.0.351. У меня 9.1.0.100.
Ноутбуки samsung и acer.
ОС - Win 7.
Настройки:
http://img148.imageshack.us/img148/4585/wifi0.png
У друга в логах вообще такая фигня:
[INFO] Tue Nov 30 21:28:30 2010 Allowed configuration authentication by IP address 192.168.0.198
[INFO] Tue Nov 30 21:12:39 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 21:12:39 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 21:12:39 2010 Above message repeated 1 times
[INFO] Tue Nov 30 21:02:31 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 21:02:31 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 21:02:31 2010 Above message repeated 1 times
[INFO] Tue Nov 30 21:02:30 2010 Wireless restart
[INFO] Tue Nov 30 20:48:55 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 20:48:55 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 20:48:55 2010 Above message repeated 1 times
[INFO] Tue Nov 30 20:48:54 2010 Wireless restart
[INFO] Tue Nov 30 20:47:58 2010 BUZZY_Network: Wireless system with MAC address 00263716D7EC secured and linked
[INFO] Tue Nov 30 20:47:58 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 20:47:57 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 20:47:57 2010 Above message repeated 1 times
[INFO] Tue Nov 30 20:47:57 2010 BUZZY_Network: Wireless system with MAC address 00263716D7EC associated
[INFO] Tue Nov 30 20:47:56 2010 Wireless restart
[INFO] Tue Nov 30 20:46:59 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 20:46:59 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 20:46:59 2010 Above message repeated 1 times
[INFO] Tue Nov 30 20:46:58 2010 Wireless restart
[INFO] Tue Nov 30 20:24:51 2010 BUZZY_Network: Wireless system with MAC address 00263716D7EC secured and linked
[INFO] Tue Nov 30 20:24:50 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 20:24:50 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 20:24:50 2010 Above message repeated 1 times
[INFO] Tue Nov 30 20:24:50 2010 BUZZY_Network: Wireless system with MAC address 00263716D7EC associated
[INFO] Tue Nov 30 20:24:49 2010 Wireless restart
[INFO] Tue Nov 30 20:15:51 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 secured and linked
[INFO] Tue Nov 30 20:15:51 2010 BUZZY_Network: Wireless system with MAC address F07BCB880F56 associated
[INFO] Tue Nov 30 20:15:51 2010 Above message repeated 1 times
[INFO] Tue Nov 30 20:15:49 2010 Wireless restart
[INFO] Tue Nov 30 19:47:14 2010 Administrator logout
СообщениеДобавлено: Ср дек 01, 2010 11:23
Конфиг устройства мне на почту прислать можете?
СообщениеДобавлено: Сб дек 04, 2010 11:56
Отправил в пм конфиг, почту не вижу.
СообщениеДобавлено: Сб дек 04, 2010 18:01
Проблему подтверждаю, в день 3-4 самопроизвольных разрыва, в логе разрыв виден либо как:
Wireless restart
либо как:
Wireless system with MAC address XXXXXXXXXXXX secured and linked
Wireless system with MAC address XXXXXXXXXXXX associated
при отсутствующих Received Deauthentication
Режим - чистый 11n, полоса 40МГц, канал вручную 11 (пробовал разные), шифрование WPA2PSK+AES. Прошивка FW134WWB08Beta.bin
Клиенты Atheros AR9285 и Ralink RT2870.
СообщениеДобавлено: Пн дек 06, 2010 09:52
Wireless Radio :Enabled
802.11 Mode : Mixed 802.11n and 802.11g
Channel Width :20MHz
Channel :3
WISH : Active
Wi-Fi Protected Setup :Disabled
При таких настройках разрывов нет. По крайней мере таких частых. Давно дома часами не сидел, но за 2-4 часа в логах разрывов нет.
СообщениеДобавлено: Пн дек 06, 2010 22:58
Подтверждаю проблему!
DIR-655 A3 F/W 1.34 beta 8
Проявляется при настройках:
802.11n only и при 802.11n + g
Шифрование: WPA2-PSK + AES
Ширина канала: Auto (20/40 MHz)
Клиент: Windows XP SP3, DWA-645 1.60b5 ftp://ftp.dlink.ru/pub/Wireless/DWA-645/Drivers/Win7/DWA-645_A2A3_Utility_v1.60(E)b05.rar и более старых версиях драйверов. Уровень сигнала по данным адаптера - отличный, в роутере => 50%, скорость не стабильная от 54 до 270Mbps...
На частоту обрывов влияет скорость обмена данными по сети - если копировать с шары компьютера подключенного по Gigabit/Fast Ethernet обрыв можно получить через 10-15 мин, иногда раньше... сначала грешил на энергосбережение адаптера, отключение не помогает.
СообщениеДобавлено: Вт дек 21, 2010 22:58
Вот что было в журнале Upgrade по аналогичному поводу:
Q: У меня WiFi-роутер D-Link DIR-655, и для ноута прикуплена недавно специально к нему в пару карточка PCMCIA D-Link DWA-645 (ноут старый, в нем только WiFi стандарта 802.11g, а это медленно, заменить же WiFi карточку mini-PCI в нем по ряду причин невозможно). Оба дивайса стандарта 802.11n, и работают в паре очень быстро – скорость доходит до 10 Мбайт/сек, что быстрее стомегабитной проводной сети. Правда, с роутером пришлось немного помучаться – все глюки прошивок в нем устранили относительно недавно. Но теперь все отлично, кроме одной проблемы. Беспроводное соединение работает нестабильно. Бывает, что часами держится, а бывает, что слетает каждую минуту, причем ноут находится на расстоянии двух метров от роутера. Что я только не делал – и скорость снижал, и параметры разные в роутере менял – нечего не получается. Все равно – то связь как монолит держится, то рвется постоянно. В принципе, у нас в доме много соседей с WiFi, и я уже думаю, что причина в этом. Появляется какая-то помеха, и стабильность теряется. Заметил, что в момент потери коннекта утилита Atheros Control Utility пишет, что Current Transmit Rate становится равен 1Мбит/сек. Каких-то других симптомов я не обнаружил. Даже уровень сигнала в эти моменты не снижается! Такое ощущение, что в моменты потери связи карточка и роутер занимаются какими-то своими делами, забывая про передачу данных. Собственно, хотелось посоветоваться, в каком направлении мне дальше рыть? Все бы ничего, но из-за этого невозможно смотреть кино или даже музыку слушать с сетевого диска. При подключении с помощью старой карты 802.11g такого я не наблюдаю, но ее скорости на HD-видео не хватает.
А: У карточек на чипе Atheros, вернее, у драйверов для них, есть одна неприятная особенность, с которой сталкиваются некоторые пользователи. Попробуйте скачать утилиту DPC Latency Checker (thesycon.de/eng/latency_check.shtml) и посмотрите, как будет вести себя график при включенном WiFi. Вы заметите, что даже если вы ничего не загружаете, периодически, раз минуту будут появляться большие красные столбики на графике, сигнализирующие о серьезных задержках в системе. Если же начнете что-то сильно качать, то график станет вообще весь красным. И если последнее еще можно понять, то ежеминутные пики выглядят странно. Так вот, многие отмечают, что пропадания связи оказываются синхронизированы с этими самыми ежеминутными задержками. Пропадания могут происходить, естественно, не каждую минуту, но если происходят, то как раз на таких вот пиках. Пики же эти, и их периодичность связаны с тем, что по умолчанию карточка настроена на ежеминутное сканирование эфира в поисках других точек доступа. Зачем это нужно делать, если вы уже подключены к своей ТД – не вполне понятно. И особенно непонятно, зачем это делать в ущерб уже имеющемуся подключению. В настройках карточки в Диспетчере устройств вы можете изменить периодичность таких сканирований, увеличив значение параметра Scan Valid Interval до 120, то есть до двух минут, но не более. И это помогает не сильно. В отличие от полного запрета такого сканирования, которое ситуацию с потерями связи меняет кардинально. Но все дело в том, что данная опция по умолчанию не присутствует в настройках адаптера! Atheros вообще отличается тем, что из кучи доступных настроек в диалоге отображается лишь самый минимум. Поэтому, чтобы решить проблему вам надо вручную установить параметр "bkScanEnable"="0" в разделе реестра, соответствующем вашему сетевому адаптеру – он будет выглядеть примерно так:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002bE10318}\0061
Длинный набор цифр и особенно - последний четырехзначный номер в вашем случае будет, скорее всего, другим, будьте внимательны. Ищите правильный раздел по имени адаптера. Не забудьте перегрузить ПК после внесения параметра.
Либо можно сделать так, чтобы в меню настроек адаптера появилась недостающая опция. Для этого надо импортировать в реестр примерно такой reg-файл:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002bE10318}\0061\Ndi\params\bkScanEnable]
"ParamDesc"="BackgroundScan On/Off"
"Base"="10"
"default"="1"
"type"="enum"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E972-E325-11CE-BFC1-08002bE10318}\0061\Ndi\params\bkScanEnable\enum]
"1"="On"
"0"="Off"
Опять же обращаю внимание – идентификатор адаптера и его номер (0061 в нашем примере) у вас будут другими! После внесения всех изменений вам останется только выставить в опциях появившийся там параметр BackgroundScan On/Off в положение Off, и бесконечные сканирования прекратятся. Даже перезагрузка не понадобится.
И, наконец, можно сделать так, что в настройках адаптера появятся и другие скрытые опции, но для этого вам придется установить модифицированный драйвер, который вы найдете на уже упоминавшемся форуме laptopvideo2go.com/forum/index.php, в разделе Atheros.
Попробуйте, и скорее всего проблема будет решена, ну или же будет беспокоить вас в десятки раз реже.
Кстати, утилиту DPC Latency Checker настоятельно рекомендую всем пользователям. Она способна выявить наличие в системе проблемных драйверов, что особенно важно при работе со звуком и видео во избежание выпадений сигнала. Не лишним будет ее запуск и на новом агрегате при его покупке. Почитать о работе с ней можно, например, тут - nasetka.ru/1057/index.html.
СообщениеДобавлено: Вс апр 17, 2011 19:05
Доброго времени суток. Приобрел неделю назад данный девайс, возникла такая же проблема как у вас. Соединение по локалке работает нормально, но Wi-Fi на ноутбуке начинает глючить время от времени, а именно ноутбук на несколько секунд отключается от сети, либо пишет что нету доступа к сети, затем снова через несколько секунд к ней подключается, особенно часто разрывы происходят при нагрузках. Ранее пользовался DIR-300, таких проблем не было. Сейчас стоит прошивка DIR655Ax_FW134WWB08Beta, ставил и FW134WWB02Beta, проблема не решилась. Более старшие прошивки установить не могу, потому что там отсуствует Russian L2TP. Менял настройки, отключал Wi-Fi Protection, ничего не помогло. Может кто-нибудь что подсказать, или же идти менять роутер в магазин?
В логе при разрыве указано VladLink: Wireless system with MAC address 0022688F2367 disconnected for reason: Received Deauthentication
СообщениеДобавлено: Пн апр 18, 2011 12:51
Такая ситуация происходит под нагрузкой или даже если не используете сеть?
СообщениеДобавлено: Ср апр 20, 2011 08:13
Под нагрузкой, например когда открываешь несколько страниц в браузере либо перекидываешь файл по сети между ноутбуком и компьютером.
СообщениеДобавлено: Ср апр 20, 2011 10:45
Спасибо. Максимальное время можете сказать за которое это проблема возникает?
В данный момент поставили устройство на длитильный тест дял выявления проблемы.
СообщениеДобавлено: Чт апр 21, 2011 17:38
Я два дня назад переустановил Windows, проблема не изчезла, разрывы были... Затем обновил драйвер на самый последний с оф. сайта Atheros и вроде пока что полет нормальный, тьфу-тьфу-тьфу :) Обрывов за эти два дня не замечал, буду тестировать дальше.
А ранее проблема возникала практически сразу, если дать нагрузку на сеть...
СообщениеДобавлено: Вт май 03, 2011 04:24
Sergey Vasiliev, спасибо, что уделяете время комьюнити.
Давно не пользуюсь дома ноутбуком длительное время, поэтому проблему не воспринимаю так остро. Но девушка сидит рядом напротив роутера, и у друга такой же как был так и стоит.
Хочу сказать, что ничего не изменилось ни на новых драйверах, ни после всяческих советов из гугла. Как было, так и есть, логи все такие же. Устройство работает очень долго, не отключал уже пару месяца, все логи забиты сообщениями как было выше.
Хотя после сообщения STN, сделал, как он написал, и кинул ноут в угол (около 6 часов работал), разрыва не было ни одного. Отсюда можно заключить, что да, разрыв происходит во время нагрузки.
Как я писал выше разрыв не более 3-5 секунд, вин 7 пишет "без доступа к сети" или "ограниченный доступ". В асечко-интернетах это не критично, поэтому скорее всего, так мало данных о проблеме.
Но если ноут использовать, как основной комп и при этом еще играть на нем, то разрывы замечаешь постоянно.
Очень интересно, что показал стресс тест, какая карточка была на устройстве (щас пока проблему вижу только на атеросах)? Попробуйте поиграть в онлайн игру пару часов, уверен, что заметите все, что надо.
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 58
