Текущее время: Вс июн 28, 2026 18:51
 Заголовок сообщения: DIR - 825 разрывает соединение
СообщениеДобавлено: Вс ноя 14, 2010 19:49
DIR - 825 разрывает соединение каждые 10 минут? Что делать? Версия прошивки последняя 2.05
Nov 14 19:43:52 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:42:52 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:41:52 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:41:06 notice Blocked incoming TCP SynAck packet from 94.78.207.193:50825 to 91.207.136.105:61703 with unexpected sequence
Nov 14 19:40:57 info QoS engine: can not measured bandwidth. Please reboot and try again
Nov 14 19:40:52 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:40:03 info read /etc/hosts - 1 addresses
Nov 14 19:40:03 info using nameserver 91.207.136.36#53
Nov 14 19:40:03 info reading /etc/resolv.conf
Nov 14 19:40:03 info compile time options: IPv6 GNU-getopt no-ISC-leasefile no-DBus no-I18N no-TFTP
Nov 14 19:40:03 info started, version 2.41 cachesize 150
Nov 14 19:39:55 info exiting on receipt of SIGTERM
Nov 14 19:39:55 info using nameserver 91.207.136.36#53
Nov 14 19:39:55 info reading /etc/resolv.conf
Nov 14 19:39:55 notice pppd sent restart signal to rc
Nov 14 19:39:55 notice pppd check for rc to be idle ?
Nov 14 19:39:55 notice primary DNS address 91.207.136.36
Nov 14 19:39:55 notice ipcp_up: remote PPP IP address 91.207.136.4
Nov 14 19:39:55 notice ipcp_up: local PPP IP address 91.207.136.105
Nov 14 19:39:55 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
Nov 14 19:39:55 notice PAP authentication succeeded
Nov 14 19:39:52 notice Connect: ppp0 '--' pptp (91.207.136.4)
Nov 14 19:39:52 info Using interface ppp0
Nov 14 19:39:52 notice anon log[ctrlp_disp:pptp_ctrl.c:895]: Outgoing call established (call ID 6, peer's call ID 539).
Nov 14 19:39:52 notice anon log[ctrlp_disp:pptp_ctrl.c:856]: Received Outgoing Call Reply.
Nov 14 19:39:52 notice anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
Nov 14 19:39:51 notice anon log[ctrlp_disp:pptp_ctrl.c:771]: Client connection established.
Nov 14 19:39:51 notice anon log[ctrlp_disp:pptp_ctrl.c:737]: Received Start Control Connection Reply
Nov 14 19:39:51 notice anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
Nov 14 19:39:51 notice anon log[callmgr_main:pptp_callmgr.c:140]: unix_sock
Nov 14 19:39:51 notice anon log[callmgr_main:pptp_callmgr.c:136]: control connection
Nov 14 19:39:51 notice anon log[callmgr_main:pptp_callmgr.c:132]: IP: 91.207.136.4
Nov 14 19:39:51 notice pppd 2.4.3 started by root, uid 0
Nov 14 19:39:51 info PPTP plugin version 0.7.12 compiled for pppd-2.4.3, linux-2.6.15
Nov 14 19:39:51 info Plugin /lib/pptp.so loaded.
Nov 14 19:39:42 info Die Exit.
Nov 14 19:39:42 notice ppp auth: Connection terminated.
Nov 14 19:39:42 info Sent 136241893 bytes, received 4009304 bytes.
Nov 14 19:39:42 info Connect time 11.0 minutes.
Nov 14 19:39:42 info Terminating on signal 15
Nov 14 19:39:42 notice anon log[call_callback:pptp_callmgr.c:79]: Closing connection (call state)
Nov 14 19:39:42 notice anon log[pptp_send_ctrl_packet:pptp_ctrl.c:620]: write error: Broken pipe
Nov 14 19:39:42 notice anon log[callmgr_main:pptp_callmgr.c:269]: Closing connection (shutdown)
Nov 14 19:39:42 notice anon log[pptp_read_some:pptp_ctrl.c:549]: read error: Connection reset by peer
Nov 14 19:38:41 notice anon log[logecho:pptp_ctrl.c:677]: no more Echo Reply/Request packets will be reported.
Nov 14 19:38:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:37:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:36:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:36:30 notice Blocked incoming TCP SynAck packet from 87.103.55.218:54594 to 91.207.136.105:61397 with unexpected sequence
Nov 14 19:35:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:34:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:33:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:32:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:31:49 notice Blocked incoming TCP SynAck packet from 87.103.55.218:54594 to 91.207.136.105:61083 with unexpected sequence
Nov 14 19:31:43 notice Blocked incoming TCP SynAck packet from 87.103.55.218:54594 to 91.207.136.105:61083 with unexpected sequence
Nov 14 19:31:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:31:06 notice Blocked incoming TCP Ack packet from 92.126.52.66:27435 to 91.207.136.105:60809 with unexpected sequence
Nov 14 19:30:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:29:47 info QoS engine: can not measured bandwidth. Please reboot and try again
Nov 14 19:29:41 notice anon log[logecho:pptp_ctrl.c:675]: Echo Reply received.
Nov 14 19:28:53 info read /etc/hosts - 1 addresses
Nov 14 19:28:53 info using nameserver 91.207.136.36#53
Nov 14 19:28:53 info reading /etc/resolv.conf
Nov 14 19:28:53 info compile time options: IPv6 GNU-getopt no-ISC-leasefile no-DBus no-I18N no-TFTP
Nov 14 19:28:53 info started, version 2.41 cachesize 150
Nov 14 19:28:45 info exiting on receipt of SIGTERM
Nov 14 19:28:45 info using nameserver 91.207.136.36#53
Nov 14 19:28:45 info reading /etc/resolv.conf
Nov 14 19:28:45 notice pppd sent restart signal to rc
Nov 14 19:28:45 notice pppd check for rc to be idle ?
Nov 14 19:28:45 notice primary DNS address 91.207.136.36
Nov 14 19:28:45 notice ipcp_up: remote PPP IP address 91.207.136.3
Nov 14 19:28:45 notice ipcp_up: local PPP IP address 91.207.136.105
Nov 14 19:28:45 notice ipcp_up: Open /var/tmp/pptp_server_ip.txt (l2tp_server_ip.txt) fail or Using PPPoE
Nov 14 19:28:45 notice PAP authentication succeeded
Nov 14 19:28:41 notice Connect: ppp0 '--' pptp (91.207.136.3)
Nov 14 19:28:41 info Using interface ppp0
Nov 14 19:28:41 notice anon log[ctrlp_disp:pptp_ctrl.c:895]: Outgoing call established (call ID 5, peer's call ID 31640).
Nov 14 19:28:41 notice anon log[ctrlp_disp:pptp_ctrl.c:856]: Received Outgoing Call Reply.
Nov 14 19:28:41 notice anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 7 'Outgoing-Call-Request'
Nov 14 19:28:40 notice anon log[ctrlp_disp:pptp_ctrl.c:771]: Client connection established.
Nov 14 19:28:40 notice anon log[ctrlp_disp:pptp_ctrl.c:737]: Received Start Control Connection Reply
Nov 14 19:28:40 notice anon log[ctrlp_rep:pptp_ctrl.c:251]: Sent control packet type is 1 'Start-Control-Connection-Request'
Nov 14 19:28:40 notice anon log[callmgr_main:pptp_callmgr.c:140]: unix_sock
Nov 14 19:28:40 notice anon log[callmgr_main:pptp_callmgr.c:136]: control connection
 Заголовок сообщения: Re: DIR - 825 разрывает соединение
СообщениеДобавлено: Вс ноя 14, 2010 20:47
торрентами пользуетесь?
выключите qos если оно вам не нужно, либо задайте для него вручную скорость.
