Текущее время: Чт сен 03, 2026 19:10
Начать новую тему Ответить на тему  [ Сообщений: 17 ]  На страницу Пред.  1, 2
СообщениеДобавлено: Чт окт 21, 2010 16:56
DGS-3426:admin#sh gvrp
Command: show gvrp
Global GVRP : Disabled
Port     PVID  GVRP      Ingress Checking  Acceptable Frame Type
 1:1     3     Disabled  Enabled           All Frames
A1:2     1     Disabled  Enabled           All Frames
A1:3     1     Disabled  Enabled           All Frames
A1:4     1     Disabled  Enabled           All Frames
A1:5     1     Disabled  Enabled           All Frames
A1:6     1     Disabled  Enabled           All Frames
A1:7     1     Disabled  Enabled           All Frames
A1:8     1     Disabled  Enabled           All Frames
A1:9     1     Disabled  Enabled           All Frames
A1:10    1     Disabled  Enabled           All Frames
A1:11    1     Disabled  Enabled           All Frames
A1:12    1     Disabled  Enabled           All Frames
A1:13    1     Disabled  Enabled           All Frames
A1:14    1     Disabled  Enabled           All Frames
A1:15    1     Disabled  Enabled           All Frames
A1:16    1     Disabled  Enabled           All Frames
A1:17    1     Disabled  Enabled           All Frames
 1:18    1     Disabled  Enabled           All Frames
 1:19    1     Disabled  Enabled           All Frames
 1:20    1     Disabled  Enabled           All Frames
 1:21    1     Disabled  Enabled           All Frames
 1:22    1     Disabled  Enabled           All Frames
 1:23    1     Disabled  Enabled           All Frames
 1:24    1     Disabled  Enabled           All Frames
 2:1     3     Disabled  Enabled           All Frames
A2:2     1     Disabled  Enabled           All Frames
A2:3     1     Disabled  Enabled           All Frames
A2:4     1     Disabled  Enabled           All Frames
A2:5     1     Disabled  Enabled           All Frames
A2:6     1     Disabled  Enabled           All Frames
A2:7     1     Disabled  Enabled           All Frames
A2:8     1     Disabled  Enabled           All Frames
A2:9     1     Disabled  Enabled           All Frames
A2:10    1     Disabled  Enabled           All Frames
A2:11    1     Disabled  Enabled           All Frames
A2:12    1     Disabled  Enabled           All Frames
A2:13    1     Disabled  Enabled           All Frames
A2:14    1     Disabled  Enabled           All Frames
A2:15    1     Disabled  Enabled           All Frames
A2:16    1     Disabled  Enabled           All Frames
A2:17    1     Disabled  Enabled           All Frames
 2:18    1     Disabled  Enabled           All Frames
 2:19    1     Disabled  Enabled           All Frames
 2:20    1     Disabled  Enabled           All Frames
 2:21    1     Disabled  Enabled           All Frames
 2:22    1     Disabled  Enabled           All Frames
 2:23    1     Disabled  Enabled           All Frames
 2:24    9     Disabled  Enabled           All Frames
 Total Entries : 48
DGS-3426:admin#sh sw
Command: show switch
Device Type       : DGS-3426 Gigabit Ethernet Switch
Unit ID           : 1
MAC Address       : 00-26-5A-84-DE-50
IP Address        : 194.190.6.111 (Manual)
VLAN Name         : default
Subnet Mask       : 255.255.255.0
Default Gateway   :
Boot PROM Version : Build 1.00-B13
Firmware Version  : Build 2.70.B54
Hardware Version  : A2
Serial Number     :
System Name       :
System Location   :
System Contact    :
Spanning Tree     : Disabled
GVRP              : Disabled
IGMP Snooping     : Disabled
MLD Snooping      : Disabled
RIP               : Disabled
RIPng             : Disabled
TELNET            : Enabled (TCP 23)
WEB               : Disabled
SNMP              : Disabled
RMON              : Disabled
SSL status        : Disabled
SSH status        : Disabled
802.1x            : Disabled
Jumbo Frame       : On
Clipaging         : Enabled
MAC Notification  : Disabled
Port Mirror       : Disabled
SNTP              : Enabled
HOL Prevention State : Enabled
Syslog Global State  : Disabled
Single IP Management : Disabled
Dual Image           : Supported
Password Encryption Status : Enabled
DNS Resolver        : Disabled
DGS-3426:admin#
СообщениеДобавлено: Пн окт 25, 2010 15:48
Пришлите мне, пожалуйста, полный конфигурационный файл устройства для анализа.
Сейчас этот форум просматривают: Google [Bot] и гости: 18
