Текущее время: Чт окт 29, 2026 15:20
 Заголовок сообщения: проблема с VPN на Dlink-Di 804HV
СообщениеДобавлено: Вт окт 05, 2010 16:35
Есть проблема не могу понять в чём именно.
Значит есть 2 офиса, главный и дочерний - в обоих стоят выше указанные длинки, на них настроен ВПН по ИП секу, в статусе пишит:
192.168.0.0/
255.255.255.0 ESP tunnel IKE established 3796 Drop
в логах вот что пишет:
Tuesday October 05, 2010 17:32:22 Send IKE (INFO) : delete 195.5.143.2 -> 80.247.190.210 phase 1
Tuesday October 05, 2010 17:32:22 IKE phase1 (ISAKMP SA) remove : 195.5.143.2 <-> 80.247.190.210
Tuesday October 05, 2010 17:32:22 Send IKE M1(INIT) : 195.5.143.2 --> 80.247.190.210
Tuesday October 05, 2010 17:32:29 Send IKE (INFO) : delete 195.5.143.2 -> 80.247.190.210 phase 1
Tuesday October 05, 2010 17:32:29 IKE phase1 (ISAKMP SA) remove : 195.5.143.2 <-> 80.247.190.210
Tuesday October 05, 2010 17:32:29 Send IKE M1(INIT) : 195.5.143.2 --> 80.247.190.210
Tuesday October 05, 2010 17:32:34 IKED re-TX : INIT to 80.247.190.210
Tuesday October 05, 2010 17:32:39 IKED re-TX : INIT to 80.247.190.210
Tuesday October 05, 2010 17:32:49 IKED re-TX : INIT to 80.247.190.210
Tuesday October 05, 2010 17:32:59 IKED re-TX : INIT to 80.247.190.210
Tuesday October 05, 2010 17:33:19 IKED re-TX : INIT to 80.247.190.210
Tuesday October 05, 2010 17:33:20 Send IKE (INFO) : delete 195.5.143.2 -> 80.247.190.210 phase 1
Tuesday October 05, 2010 17:33:20 IKE phase1 (ISAKMP SA) remove : 195.5.143.2 <-> 80.247.190.210
Tuesday October 05, 2010 17:33:20 Send IKE M1(INIT) : 195.5.143.2 --> 80.247.190.210
Tuesday October 05, 2010 17:33:20 Receive IKE M2(RESP) : 80.247.190.210 --> 195.5.143.2
Tuesday October 05, 2010 17:33:20 Try to match with ENC:3DES AUTH:PSK HASH:SHA1 Group:Group1
Tuesday October 05, 2010 17:33:20 Send IKE M3(KEYINIT) : 195.5.143.2 --> 80.247.190.210
Tuesday October 05, 2010 17:33:20 Receive IKE M4(KEYRESP) : 80.247.190.210 --> 195.5.143.2
Tuesday October 05, 2010 17:33:20 Send IKE M5(IDINIT) : 195.5.143.2 --> 80.247.190.210
Tuesday October 05, 2010 17:33:20 Receive IKE M6(IDRESP) : 80.247.190.210 --> 195.5.143.2
Tuesday October 05, 2010 17:33:20 IKE Phase1 (ISAKMP SA) established : 80.247.190.210 <-> 195.5.143.2
Tuesday October 05, 2010 17:33:20 Send IKE Q1(QINIT) : 192.168.0.0 --> 192.168.1.0
Tuesday October 05, 2010 17:33:20 Receive IKE Q2(QRESP) : [192.168.1.0|80.247.190.210]-->[195.5.143.2|192.168.0.0]
Tuesday October 05, 2010 17:33:20 Try to match ESP with MODE:Tunnel PROTOCAL:ESP-3DES AUTH:MD5 HASH:Others PFS(Group):NONE
Tuesday October 05, 2010 17:33:20 Send IKE Q3(QHASH) : 192.168.0.0 --> 192.168.1.0
Tuesday October 05, 2010 17:33:20 IKE Phase2 (IPSEC SA) established : [192.168.1.0|80.247.190.210]<->[195.5.143.2|192.168.0.0]
вроде соединение есть, или я ошибаюсь?
А сеть у мя на том конце не пингуеться, не то чтоб даж была возможность туда залесть.
В главном офисе поднят Винз, для подключения по имени.
В чём может быть проблема?
Заранее стпасибо.
 Заголовок сообщения: Re: проблема с VPN на Dlink-Di 804HV
СообщениеДобавлено: Вт окт 05, 2010 19:34
А откуда и что Вы пинговали?
Пробовали "Ping Test" в Длинковском "Tools/Misc"? Например, из 192.168.0.1 пропинговать 192.168.1.1 (я предполагаю, что адреса ваших ДЛинков в локалке х.x.x.1)
СообщениеДобавлено: Ср окт 06, 2010 00:03
я пингую в командной строке из сети 1.1 в сеть 0.1
и если внимательно посмотреть логи то там видно что сети разные и статус пишет что соединение есть и тонель открыт, то доступа нет ((((
СообщениеДобавлено: Ср окт 06, 2010 00:53
Одно из двух - или у вас на компьютерах DI не указаны шлюзом, или надо повторить настройки длинков, предварительно сбросив их по дефолту.
СообщениеДобавлено: Ср окт 06, 2010 09:18
доступа нет ((((
развивая мысль г-на miant...
а что говорит netstat -rn
в обоих локалках
СообщениеДобавлено: Ср окт 06, 2010 15:14
доступа нет ((((
в обоих локалках
в локалке 1.1 по netstat -rn пишет следующее
активные маршруты:
Сетевой адрес Маска сети Адрес шлюза Интерфейс Метрика
0.0.0.0 0.0.0.0 192.168.1.1 192.168.1.52 20
80.247.190.Х 255.255.255.255 192.168.1.1 Х.Х.1.52 20
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
192.168.1.0 155.255.255.0 192.168.1.52 192.168.1.52 20
192.168.1.52 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.1.255 255.255.255.255 192.168.1.52 192.168.1.52 20
224.0.0.0 240.0.0.0 192.168.1.52 192.168.1.52 20
255.255.255.255 255.255.255.255 192.168.1.52 192.168.1.52 1
основной шлюз 192.168.1.1
постоянные маршруты отсутсвуют
_____________________________________________________
в локалке 0.1 по netstat -rn пишет следующее
активные маршруты:
0.0.0.0 0.0.0.0 192.168.0.254 192.168.0.58 20
192.168.0.0 255.255.255.0 192.168.0.58 192.168.0.58 20
192.168.0.58 255.255.255.255 127.0.0.1 127.0.0.1 20
192.168.0.255 255.255.255.255 192.168.0.58 192.168.0.58 20
195.5.143.Х 255.255.255.255 192.168.0.254 Х.Х.0.58 20
224.0.0.0 240.0.0.0 192.168.0.58 192.168.0.58 20
255.255.255.255 255.255.255.255 192.168.0.58 192.168.0.58 1
255.255.255.255 255.255.255.255 192.168.0.58 3 1
основной шлюз 192.168.0.254
Что можно сказать по данным команды?
Да инет при этом работает в обоих офисах без проблем, что шлюзы прописаны.
СообщениеДобавлено: Ср окт 06, 2010 16:24
1. Вы пинговали со станции в одной локалки (например 192.168.1.52) станцию в другой (например 192.168.0.58)?
А не пробовали, пинговать прямо с DI-804 (tools/misc)?
Например с DI-804 c адресом 192.168.0.254 пропинговать DI-804 c адресом 192.168.1.1
2. firewallы на станциях включены?
СообщениеДобавлено: Ср окт 06, 2010 17:00
из длинков пинговал грит ошибка.
на длинках фаейрволы не подняты
СообщениеДобавлено: Ср окт 06, 2010 17:48
тогда, непонятно, откуда у вас " ESP tunnel IKE established "... :-(
А Вы в ЛОГах IP адреса не исправляли, они у вас действительно такие?
На http://195.5.143.2/ появляется запрос логина/праоля на какой-то
"Kerio Connect WemMail". Это так надо?
я спрашивал не про DLinkи а пр рабочие станции. :-) На них FW включен?
СообщениеДобавлено: Ср окт 06, 2010 18:15
Да там дмз настроено на веб сервер :-), так что всё нормально
вот и я не пойму как это может быть соединение есть а связи вроде и нет ((
Завтра попробую заново всё настроить, посмотрим что измениться.. мож Длинки глючат.
СообщениеДобавлено: Ср окт 06, 2010 20:12
а они оба пишут, что мол, " ESP tunnel IKE established "?
А если на одном поDROPать, на другом тоже DROPается?
СообщениеДобавлено: Чт окт 07, 2010 15:01
дропает с любой стороны ))
пишет ресонект, нажимаешь ещё раз канал восстанавливаеться.
СообщениеДобавлено: Чт окт 07, 2010 17:59
Последняя прошивка, сброс по умолчанию и настройка заново обоих девайсов решит вашу проблему. Обновление опционально, остальное обязательно.
СообщениеДобавлено: Чт окт 07, 2010 19:09
угу, и попробуйте, для начала, ничего дополнительного (типа проброса портов) не делать, только VPN. ;-)
По моему опыту, связи не бывает чаще всего из-за фильтрации, либо маршрутизации (вернее, ее отсутствия)
СообщениеДобавлено: Пт окт 08, 2010 14:28
В общем сбрасывать и обновлять ни чего не стал и так последняя прошивка, просто перенастроил ВПН. И произошло чудо, соединение есть и при этом всё пингуеться. Да удивительные эти роуторы )))
Тогда след вопрос, в главном офисе стоит сервер с AD, DHCP, DNS, WINS - соответственно роутер выше указанный с поднятым на данный момент ВПН.
Могу ли я и как это лучше сделать чтоб машины находящиеся в другом отделении заходили в главный AD. (Там нет серверов и просто стоит второй длинк).
Необходима регистрация пользователей в главный офис, сейчас соответственно я пингую но зайти с главного могу только на компы которые в какой нить группе (например Номе), а те компы которые были раньше в домене (до перезда соответственно, нет доступа).
И второе заходить могу только по айпи адресу, но не могу зайти просто по имене ( что нужно поставить и где может в роутере что надо ещё прописать).
На главном Wins стоит, но с машинами на том конце не работает.
Заранее спасибо!
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 45
