Текущее время: Чт сен 17, 2026 08:20
 Заголовок сообщения: DI-824VUP PPTP VPN + Windows Mobile PPTP client
СообщениеДобавлено: Пн сен 27, 2010 17:01
Есть DI-824VUP и на нем поднят PPTP VPN. С компьютера коннект нормальный.
Настройки:
Authentication Protocol MSCHAP
MPPE Encryption Mode Enable
Пытаюсь подсоединиться с Windows Mobile 6.1 (Samsung Witu).
В девайс залит Connection Manager, в нем и проставляю настройки секурности:
Use Data Encription (галка стоит)
Use Extensible Auth Protocol (галка стоит), выбран MSV2-Challenge, серые галки в обоих версиях MS CHAP.
Логин, пароль - вводятся.
Получаю в логе:
Monday September 27, 2010 16:48:50 [START_CTRL_RQST]: tunnel 0
Monday September 27, 2010 16:48:50 [OUT_CALL_RQST]: tunnel 0, peer call 0x8
Monday September 27, 2010 16:48:59 [peer_call_id_search]: Not Found;[call_id=0],[tunn=0],[cnum=1]
Monday September 27, 2010 16:49:00 [STOP_CTRL_RQST]: tunnel 0
Monday September 27, 2010 16:49:00 [peer](1)general request to clear.
Monday September 27, 2010 16:49:00 destory call 0 from tunnel 0
Monday September 27, 2010 16:49:00 [pptp_call_destroy]: Closing PPTP call; [tunn=0], [call=0]
Monday September 27, 2010 16:49:00 [pptp_conn_destory]: Closing PPTP connection; index=0
Неверное имя пользователя.
Если галку Use Extensible Auth Protocol снять, то лог такой:
Monday September 27, 2010 17:05:06 [START_CTRL_RQST]: tunnel 0
Monday September 27, 2010 17:05:06 [OUT_CALL_RQST]: tunnel 0, peer call 0x8
Monday September 27, 2010 17:05:23 destory call 0 from tunnel 0
Monday September 27, 2010 17:05:23 [pptp_call_destroy]: Closing PPTP call; [tunn=0], [call=0]
Monday September 27, 2010 17:05:23 [pptp_conn_destory]: Closing PPTP connection; index=0
Т.е. имя пользователя вообще не доходит.
Если убрать галку с шифрования:
Monday September 27, 2010 17:43:48 [START_CTRL_RQST]: tunnel 0
Monday September 27, 2010 17:43:50 [OUT_CALL_RQST]: tunnel 0, peer call 0x8
Monday September 27, 2010 17:43:59 [peer_call_id_search]: Not Found;[call_id=49152],[tunn=0],[cnum=1]
Monday September 27, 2010 17:44:00 [STOP_CTRL_RQST]: tunnel 0
Monday September 27, 2010 17:44:00 [peer](1)general request to clear.
Monday September 27, 2010 17:44:00 destory call 0 from tunnel 0
Monday September 27, 2010 17:44:00 [pptp_call_destroy]: Closing PPTP call; [tunn=0], [call=0]
Monday September 27, 2010 17:44:00 [pptp_conn_destory]: Closing PPTP connection; index=0
КПК говорит - неопознанная ошибка при идентификации пользователя.
Вопрос - что не так с аутентификацией?
В чем разница с компьютерным подключением?
Какие настройки должны стоять?
СообщениеДобавлено: Вт сен 28, 2010 09:29
viewtopic.php?t=110340
СообщениеДобавлено: Вт сен 28, 2010 14:16
Это Вы к чему?
Хотите сказать, что не поняли, что я написал???
Поясняю - вопрос касается авторизации на PPTP VPN сервере мобильного устройства с WM 6.1. Почему, собственно, она не проходит. Ничего больше.
Отвечать одной ссылкой на правила форума - не вежливо.
Если Вы имеете ввиду маршрутизатор - DI-824VUP+ ревизии A1 с прошивкой v1.06b21
Теперь хотелось бы Ваших комментариев.
СообщениеДобавлено: Вт сен 28, 2010 17:17
Настройки предоставить можете на роутере?
Не совсем ясно куда подключаться пытаетесь, желательно предоставить схему сети.
СообщениеДобавлено: Ср сен 29, 2010 11:51
Виталий,
Задача ставится очень просто - поднять тоннель между роутером и устройством на Windows Mobile для доступа к локальной сети за роутером по RDP или самбе.
С компьютера это решается стандартными средствами легко и быстро. А вот с КПК - затык с авторизацией.
Конечно, это не совсем проблема оборудования D-Link, скорее косяк МелкоМягких. Однако хотелось бы решить этот вопрос...
СообщениеДобавлено: Ср сен 29, 2010 12:31
Для RDP PPTP сервер настраивать необязательно, достаточно настроить портфорвардинг через меню Virtual Servers.
http://www.dlink.ru/ru/faq/69/300.html
Разбирайтесь с клиентом на КПК, на тестовом стенде PPTP сервер работает.
СообщениеДобавлено: Ср сен 29, 2010 21:30
Кто же захочет такую дыру оставлять??? Для этого VPN и нужен.
Другое дело, что PPTP - худший вариант, но это детали. И доступ по самбе без VPN не организуешь. Опять же можно предложить взамен FTP, но это уже не то...
В принципе, ответ ожидаемый - он действительно связано не с оборудованием D-Link - не только у Вас, но и меня с компа работает.
Хочется в очередной раз сказать пару ласковых в адес МелкоМягких, но я все же воздержусь.
СообщениеДобавлено: Чт сен 30, 2010 11:26
Поищите альтернативный клиент, их много для WM. Какой-нибудь да подойдет :)
