Текущее время: Вс сен 20, 2026 10:07
Начать новую тему Ответить на тему  [ Сообщений: 26 ]  На страницу 1, 2  След.
 Заголовок сообщения: dir-300 непонятка.помогите
СообщениеДобавлено: Ср сен 22, 2010 18:02
Здравствуйте.Проблема в том что роутер не соединяется с интернетом.подключение Russia PPPoE Dual Access. ввожу всё как тут http://www.dlink.ru/ru/faq/68/277.html но не соединяется.Привязки к мак адресу у провайдера нет.айпи адрес динамический.
логи:
    "Jan 1 00:14:32 ","Remote management is disabled."
    "Jan 1 00:14:32 ","Block WAN PING is enabled."
    "Jan 1 00:14:31 ","DMZ disabled."
    "Jan 1 00:14:31 ","VPN (L2TP) Pass-Through enabled."
    "Jan 1 00:14:31 ","VPN (IPSec) Pass-Through enabled."
    "Jan 1 00:14:31 ","VPN (PPTP) Pass-Through enabled."
    "Jan 1 00:14:31 ","Domain blocking disabled."
    "Jan 1 00:14:31 ","URL blocking disabled."
    "Jan 1 00:14:31 ","MAC filter disabled."
    "Jan 1 00:14:20 ","DHCP: Client send DISCOVER."
    "Jan 1 00:14:09 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:14:04 ","DHCP: Client send DISCOVER."
    "Jan 1 00:13:59 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:13:56 ","DHCP: Client send DISCOVER."
    "Jan 1 00:13:54 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:13:52 ","DHCP: Client send DISCOVER."
    "Jan 1 00:13:52 ","Remote management is disabled."
    "Jan 1 00:13:52 ","Block WAN PING is enabled."
    "Jan 1 00:13:52 ","DMZ disabled."
    "Jan 1 00:13:52 ","VPN (L2TP) Pass-Through enabled."
    "Jan 1 00:13:52 ","VPN (IPSec) Pass-Through enabled."
    "Jan 1 00:13:52 ","VPN (PPTP) Pass-Through enabled."
    "Jan 1 00:13:52 ","Domain blocking disabled."
    "Jan 1 00:13:52 ","URL blocking disabled."
    "Jan 1 00:13:52 ","MAC filter disabled."
    "Jan 1 00:13:50 ","DHCP: Client send DISCOVER."
    "Jan 1 00:10:59 ","Remote management is disabled."
    "Jan 1 00:10:59 ","Block WAN PING is enabled."
    "Jan 1 00:10:59 ","DMZ disabled."
    "Jan 1 00:10:59 ","VPN (L2TP) Pass-Through enabled."
    "Jan 1 00:10:59 ","VPN (IPSec) Pass-Through enabled."
    "Jan 1 00:10:59 ","VPN (PPTP) Pass-Through enabled."
    "Jan 1 00:10:59 ","Domain blocking disabled."
    "Jan 1 00:10:59 ","URL blocking disabled."
    "Jan 1 00:10:59 ","MAC filter disabled."
    "Jan 1 00:10:38 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:10:28 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:10:23 ","PPPoE: Sending PADI for session1."
    "Jan 1 00:10:17 ","Log message was cleared."
Поясните пожалуйста в чём проблема.Заранее спасибо.
СообщениеДобавлено: Чт сен 23, 2010 17:01
Connect mode select выставляйте в Always.
СообщениеДобавлено: Пт сен 24, 2010 11:38
Дело не в том что он разрывает соединение.он просто не соединяется когда нажимаешь кнопку коннект.уже раз 5 звонил провайдеру говорят с их стороны не каких проблем.сдал по гарантии в магазин, проверили работает.уже даже не знаю что думать...
СообщениеДобавлено: Пт сен 24, 2010 13:57
Ну а зачем заморачиваться Вам с "интернет по запросу", выставьте Always, как сказал Vitaliy Korkunov. Роутер будет сам пытаться коннектиться.
А также отключите Block WAN PING.
СообщениеДобавлено: Пт сен 24, 2010 21:03
не помогло =(
СообщениеДобавлено: Пн сен 27, 2010 12:14
Свяжитесь с провайдером и уточните, видит ли он МАС роутера у себя на линии?
СообщениеДобавлено: Пн сен 27, 2010 19:22
Говорят видят.Пригласил мастера он посмотрел развёл руками ушёл...
А вообще провайдер придерживается политики (инет на прямую работает остальное не наши проблемы).
СообщениеДобавлено: Пн сен 27, 2010 19:40
Правильная политика, но только, если данный девайс не рекомендован самим провайдером. :!:
DIR-100 на полке, DIR-655 в использовании...
СообщениеДобавлено: Пн сен 27, 2010 20:19
hutu, на картинке вижу, что у вас прошивка 2.02. Попробуйте обновить для начала на 2.05. Сбросьте настройки ресетом и настройте заново руками. Может, все заработает...
СообщениеДобавлено: Вт сен 28, 2010 10:59
Поменял прошивку опять же не помогло.1 числа приедут мантеры и сменят порт.Может это даст результат.
СообщениеДобавлено: Вт сен 28, 2010 11:21
У меня есть один DIR-300 NRU. С некоторых пор на нем время от времени проявляется непонятный баг.
Включаешь (или перегружаешь) роутер. Показывает, что на WAN порту соединение есть, но ничего не получает по dhcp. Вынимаешь кабель из WAN порта, ждешь секунд 5, вставляешь обратно. Через некоторое время появляется соединение по dhcp, а потом и vpn поверх него устанавливается.
Попробуйте так же. Может, сразу после включения у вас тоже не видит по WAN порту ничего?
СообщениеДобавлено: Вт окт 05, 2010 21:15
Во общем допёк тех поддержку они чего то там у себя поделали и сказали что подняли порт.Теперь роутер стал реагировать на юзернет.Перепрошил прошивкой dlink-dir300b-factory-webflash
интернет зацепился но упала скорость и теперь индикаторы питания и интернета горят жёлтым.Завтра опять буду звонить провайдеру может что то новое узнаю...
СообщениеДобавлено: Ср окт 06, 2010 11:07
... и теперь индикаторы питания и интернета горят жёлтым.Завтра опять буду звонить провайдеру может что то новое узнаю...
провайдер тут непричём - не следовало просто прошиваться альтернативной прошивкой.
СообщениеДобавлено: Ср окт 06, 2010 11:45
Посоветуйте прошивку.
СообщениеДобавлено: Ср окт 06, 2010 20:24
Аналогичная проблема: индикатор интернета никак гореть не хочет (и интернета нет соответсвенно), носил по гарнтии проверили-сказали есть..убедился лично что интернет был, на вопрос "КАК!?!?" ответили, что сами как-то настроили, но говорить "секрет" настройки не хотят..
провайдер мягко отправил куда подальше с просьбой настроить роутер
зы изначально интернет был где то с месяц, а потом скорее всего при отсоединении кабеля пропал
зыы логи если надо, могу приложить
ХЕЛП!
