Текущее время: Пн июн 22, 2026 21:54
СообщениеДобавлено: Ср сен 22, 2010 14:58
Коммутатор сброшен по умолчанию.
Старт:
*** Running  SW  Ver. 3.60.28  Date  08-Jun-2010  Time  11:09:16 ***
Serial Number :  F3Q318C000026.
HW version is: 04
Base Mac address is: 00:24:01:30:0b:a9
Dram size is: 64M bytes
Flash size is: 16M bytes
01-Jan-2000 01:01:08 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:08 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - DGS-3100-24TG ST
-- Unit Number 1                  --
01-Jan-2000 01:01:22 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
01-Jan-2000 01:01:36 %INIT-I-InitCompleted: Initialization task is completed
-- Unit Number 1  Master Enabled --
01-Jan-2000 01:01:37 %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - operational.
01-Jan-2000 01:01:37 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operational.
Tapi Version: v1.3.3.1
Core Version: v1.3.3.1
01-Jan-2000 01:01:38 %SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 22
01-Jan-2000 01:01:38 %SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 22
>lcli
UserName:admin
01-Jan-2000 01:01:41 %LINK-W-Down:  1:12
DGS-3100# 01-Jan-2000 01:01:41 %LINK-W-Down:  Vlan 1
01-Jan-2000 01:01:41 %LINK-W-Down:  1:16
01-Jan-2000 01:01:41 %LINK-W-Down:  1:20
DGS-3100#
Коммутатор:
DGS-3100# show switch
Device Type         : DGS-3100-24TG  Gigabit stackable L2 Managed Switch
MAC Address         : 00:24:01:30:0b:a9
IP Address          : 10.90.90.90
VLAN Name           : default
Subnet Mask         : 255.0.0.0
Default Gateway     : 0.0.0.0
Boot PROM Version   : 1.0.1.05
Firmware Version    : 3.60.28
Hardware Version    : 04
Serial Number       : F3Q318C000026(unit 1)
System Name         : DGS-3100
System Location     :
System Contact      :
System Up Time      : 0 days 0 hours 1 mins 52 seconds
Spanning Tree       : Disabled
GVRP                : Disabled
IGMP Snooping       : Disabled
TELNET              : Enabled
WEB                 : Enabled (TCP 80)
Вставляем uplink sfp:
DGS-3100# 01-Jan-2000 01:04:56 %Fiber-I-SFP-PRESENT-CHNG: 1:24 SFP status is present.
01-Jan-2000 01:04:56 %LINK-I-Up:  Vlan 1
01-Jan-2000 01:04:56 %LINK-I-Up:  1:24
01-Jan-2000 01:04:57 %LINK-W-Down:  Vlan 1
01-Jan-2000 01:04:57 %LINK-W-Down:  1:24
01-Jan-2000 01:04:59 %LINK-I-Up:  Vlan 1
01-Jan-2000 01:04:59 %LINK-I-Up:  1:24
DGS-3100# show ports 1:10-24
Port  Port       Settings                Connection              Address
      State      Speed/Duplex/FlowCtrl   Speed/Duplex/FlowCtrl   Learning
1:10  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:11  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:12  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:13  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:14  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:15  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:16  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:17  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:18  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:19  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:20  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:21  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:22  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:23  Enabled    1000M/Full/Disabled     Link Down               Enabled
1:24  Enabled    1000M/Full/Disabled     1000M/Full/Disabled     Enabled
Тушим все порты кроме uplink (24)
DGS-3100# config ports 1:1-23 state disable
01-Jan-2000 01:06:33 %LINK-W-Down:  Vlan 1
01-Jan-2000 01:06:33 %LINK-W-Down:  1:24
Success.
1:10  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:11  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:12  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:13  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:14  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:15  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:16  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:17  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:18  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:19  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:20  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:21  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:22  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:23  Disabled   1000M/Full/Disabled     Link Down               Enabled
1:24  Enabled    1000M/Full/Disabled     Link Down               Enabled
Включаем обратно:
DGS-3100# config ports 1:10-23 state enable
Success.
DGS-3100# show 01-Jan-2000 01:11:50 %LINK-I-Up:  Vlan 1
01-Jan-2000 01:11:50 %LINK-I-Up:  1:24
ports 1:10-24
Пробуем на другом порту:
1:20  Enabled    1000M/Full/Disabled     1000M/Full/Disabled     Enabled
DGS-3100# conf ports 1-19 st disable
Success.
DGS-3100# 01-Jan-2000 01:13:30 %LINK-I-Up:  1:24
Вот как бы как лечить?
СообщениеДобавлено: Ср сен 22, 2010 16:07
Я протестирую по Вашему описанию и напишу Вам по результатам.
СообщениеДобавлено: Чт сен 23, 2010 09:35
На тестовом стенде такой проблемы не обнаружено.Обновите пром на тот, который я Вам выслал.Если это не поможет пришлите мне свой конфигурационный файл.
СообщениеДобавлено: Чт сен 23, 2010 11:13
[quote="3JIo6HbIu_MbIw"]Коммутатор сброшен по умолчанию.
VLAN Name           : default
[b]Boot PROM Version   : 1.0.1.05[/b]
System Location     :
System Contact      :
GVRP                : Disabled
TELNET              : Enabled
[/quote]
Конфигурационный файл еще надо слать?
Прошивки пробовал все начиная с 2.00
СообщениеДобавлено: Чт сен 23, 2010 11:15
В этом случае обратитесь в наш сервисный центр.
