Текущее время: Вт авг 25, 2026 17:11
Начать новую тему Ответить на тему  [ Сообщений: 31 ]  На страницу 1, 2, 3  След.
 Заголовок сообщения: Проблемы с DGS-3100-24TG
СообщениеДобавлено: Чт сен 09, 2010 10:16
После перезагрузки свича началось такое:
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................PASS
Flash Image Validation Test.......................PASS
Restoring system configuration defaults
BOOT Software Version 1.0.0.04 Built 24-Oct-2007 18:51:36
Network Switch based on 88E6218 with ARM946E-S.
64MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Preparing to decompress...
100%
Decompressing SW from image-1
100%
OK
Running from RAM...
About to erase CDB. Terminal baud rate will now be set to default!
*** Running SW Ver. 2.00.47 Date 02-Mar-2008 Time 12:13:22 ***
HW version is 00.01.04
Base Mac address is: 00:22:b0:*********
Dram size is : 64M bytes
Dram first block size is : 45056K bytes
Dram first PTR is : 0x1400000
Flash size is: 16M
01-Jan-2000 01:01:09 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:09 %CDB-I-LOADCONFIG: Loading startup configuration.
scanning SMI addr 16:NOT FOUND
scanning SMI addr 17:NOT FOUND
scanning SMI addr 18:NOT FOUND
scanning SMI addr 19:NOT FOUND
scanning SMI addr 20:NOT FOUND
scanning SMI addr 21:NOT FOUND
scanning SMI addr 22:NOT FOUND
scanning SMI addr 23:NOT FOUND
scanning SMI addr 24:NOT FOUND
scanning SMI addr 25:NOT FOUND
scanning SMI addr 26:NOT FOUND
scanning SMI addr 27:NOT FOUND
scanning SMI addr 28:NOT FOUND
scanning SMI addr 29:NOT FOUND
scanning SMI addr 30:NOT FOUND
scanning SMI addr 31:NOT FOUND
01-Jan-2000 01:01:14 %ERHG-F-SEND: BOXP_perform_smi_scan_of_devices_in_slot - f0
***** FATAL ERROR *****
Reporting Task: ROOT.
Software Version: 2.00.47 (date 02-Mar-2008 time 12:13:22)
0x144370
0x1419d4
0x4d5ba0
0x331ff8
0x335980
0x353b54
0x353cfc
0x67be6c
***************** SYSTEM RESET *****************
Что это?
СообщениеДобавлено: Чт сен 09, 2010 10:31
viewtopic.php?t=124982 посмотрите здесь.
Прошивку я Вам выслал на почту.
СообщениеДобавлено: Ср сен 22, 2010 22:57
Заливал я прошивки DGS-3100_series_A1A2_FW_v3.50.23.ros, DGS-3100-xx-3.60.28.ros результат одинаков:
Startup Menu
[1] Download Software
[2] Erase Flash File
[3] Password Recovery Procedure
[4] Set Terminal Baud-Rate
[5] Stack menu
[6] Back
Enter your choice or press 'ESC' to exit:
Downloading code using XMODEM.
-- Download complete --
Calculating file's checksum...OK
Erasing FLASH ->>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Writing to flash 0x42f480 records...
100%
100%
OK
Running from RAM...
*** Running SW Ver. 3.50.23 Date 05-Mar-2010 Time 00:42:47 ***
Serial Number : **********.
HW version is: 04
Base Mac address is: *************
Dram size is: 64M bytes
Flash size is: 16M bytes
01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:10 %CDB-I-LOADCONFIG: Loading startup configuration.
Device configuration:
Slot 1 - DGS-3100-24TG ST
-- Unit Factory Default --
И висит дальше. Что делать?
Читал в ветке форума viewtopic.php?t=124982 что люди льют прошивку версии 2.00. Вышлите и мне ее.
СообщениеДобавлено: Чт сен 23, 2010 09:18
Выслал.Напишите по результатам.
СообщениеДобавлено: Чт сен 23, 2010 09:58
Залил прошивку DGS-3100-xx-2.00.53.ros -> вернулось
01-Jan-2000 01:01:14 %ERHG-F-SEND: BOXP_perform_smi_scan_of_devices_in_slot - fa
iled reading device id on device 0
Software Version: 2.00.53 (date 12-Jun-2008 time 10:43:17)
0x144370
0x1419d4
0x4d6280
0x331ff8
0x335980
0x353b54
0x353cfc
0x67c838
Попытался залить DGS-3100_series_A1A2_Boot_1.01.05.rfb
Startup Menu
[5] Stack menu
[6] Back
Error 1030000.Wrong image format. Writing aborted.;
Please contact tech support.
Что делать дальше?
СообщениеДобавлено: Чт сен 23, 2010 10:00
Обратитесь с данным коммутатором в наш сервисный центр или к продавцу.
СообщениеДобавлено: Пт сен 24, 2010 08:49
А еще более раннюю прошивку можете прислать ( до 2.00.00) и загрузчик (до 1.01.04) ?
СообщениеДобавлено: Пт сен 24, 2010 13:58
Скиньте, более раннюю версию прошивки.
СообщениеДобавлено: Пт сен 24, 2010 17:25
Выслал.
СообщениеДобавлено: Сб сен 25, 2010 16:38
Продолжим. Название темы подходящее.
telnet 172.16.0.150
Trying 172.16.0.150...
Connected to 172.16.0.150.
Escape character is '^]'.
UserName:admin
DGS-3100# en gvrp
Connection closed by foreign host.
spiderx@user-desktop:~$ telnet 172.16.0.150
UserName:admin
DGS-3100# sh gvrp
Global GVRP : Disabled
Port  PVID GVRP     Ingress Checking Acceptable Frame Type
1:1   1    Disabled Enabled          All Frames
1:2   1    Disabled Enabled          All Frames
1:3   1    Disabled Enabled          All Frames
1:4   1    Disabled Enabled          All Frames
1:5   1    Disabled Enabled          All Frames
1:6   1    Disabled Enabled          All Frames
1:7   1    Disabled Enabled          All Frames
1:8   1    Disabled Enabled          All Frames
1:9   1    Disabled Enabled          All Frames
1:10  1    Disabled Enabled          All Frames
1:11  1    Disabled Enabled          All Frames
1:12  1    Disabled Enabled          All Frames
1:13  1    Disabled Enabled          All Frames
1:14  1    Disabled Enabled          All Frames
1:15  1    Disabled Enabled          All Frames
1:16  1    Disabled Enabled          All Frames
1:17  1    Disabled Enabled          All Frames
Total Entries : 17
DGS-3100# 01-Jan-2000 01:02:58 %SYSLOG-F-OSFATAL: CMNTSKG_create_timer: can not create a timer
Reporting Task: BRMN.
Software Version: 3.60.30 (date  12-Aug-2010 time  08:50:35)
0x144724
0x141d0c
0x546260
0x4b489c
0x3e8c48
0x3e9054
0x3eb3b8
0x3eb448
0x3b0780
0x5548c8
0x5ccc3c
0x33d008
0x3193e4
0x5daf98
0x4b445c
^^ this event was logged before the last reboot.
Проблема собственно в том, что я не могу включить GVRP на свитче на прошивке 3.60.30:
DGS-3100# sh fir i
Command: show firmware information
Unit  Image       Version          Update Time
1     1           3.60.26           15-Mar-2010  23:34:15
1     *2          3.60.30           12-Aug-2010  08:50:35
"*" designates that the image was selected for the next boot
Вот вывод из консоли в момент включения GVRP:
0x144724
0x141d0c
0x546260
0x4b489c
0x3e8c48
0x3e9054
0x3eb3b8
0x3eb448
0x3b0780
0x5548c8
0x5ccc3c
0x33d008
0x3193e4
0x5daf98
0x4b445c
Для воспроизведения достаточно зайти на свитч и сделать en gvrp.
Проверил en gvrp на 3.60.28 - все работает.
Сохранил.
Прошил еще раз свитч 3.60.30 (en gvrp остался в конфиге) - свитч перегружается при каждом применении конфига.
СообщениеДобавлено: Пн сен 27, 2010 09:36
Я проверю по Вашему описанию и напишу по результатам.
СообщениеДобавлено: Вт сен 28, 2010 11:11
Пришлите пожалуйста мне на почту полностью выгруженный конфигурационный файл.
СообщениеДобавлено: Вт сен 28, 2010 17:43
Добрый день! Надеюсь туда попал у меня стоит 2 dlink dgs-3100-24.
Сегодня залил на него новую прошивку. Начал настраивать link-aggregation на этих dlink-ах по оптике. Оптику выключил на момент настройки.
выполнял следующие комманды
Коммутатор А:
create link_aggregation group_id 17 type lacp
config link_aggregation group_id 17 ports 21,22,23,24
Коммутатор В:
Рекомендации по настройке описанные в этой статье http://www.dlink.ru/ru/faq/62/250.html не помогли так как в моем коммутаторе, походу нет описанных там команд команд.
После проведения всех настроек и подключения оптики в сответсвущие оптические порты. Оба коммутатора пошли в перезагрузку синхронно, и так по круга до бесконечности и выдавал вот такие сообщения:
BOOT Software Version 1.0.1.05
MAC Address : 00:26:5a:bd:1b:0c.
100%
Decompressing SW from image-2
100%
OK
Running from RAM...
*** Running SW Ver. 2.60.30 ***
Serial Number : F3Q329B000584.
HW version is: 00.00.a2
Base Mac address is: 00:26:5a:bd:1b:0c
01-Jan-2000 01:01:06 %CDB-I-LOADCONFIG: Loading running configuration.
01-Jan-2000 01:01:06 %CDB-I-LOADCONFIG: Loading startup configuration.
Slot 1 - DGS-3100-24 ST
Updating Database...
01-Jan-2000 01:01:33 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration change trap.
01-Jan-2000 01:01:45 %INIT-I-InitCompleted: Initialization task is completed
>To perform reset to factory defaults do not release the button for 5 seconds.
-- Unit Number 1 Master Enabled --
После удаления link_aggregation коммутаторы перестают перегружать и с сетью работают нормально
вот вывод моего sh sw
DGS-3100# sh sw
Device Type : DGS-3100-24 Gigabit stackable L2 Managed Switch
MAC Address : 00:24:01:eb:d7:aa
IP Address :
VLAN Name : default
Subnet Mask :
Default Gateway :
Boot PROM Version : 1.0.1.05
Firmware Version : 3.60.30
Hardware Version : a2
Serial Number : F3DR299000144(unit 1)
System Name : DGS-3100
System Location :
System Contact :
System Up Time : 0 days 0 hours 34 mins 13 seconds
Spanning Tree : Disabled
GVRP : Disabled
IGMP Snooping : Disabled
TELNET : Enabled
WEB : Enabled (TCP 80)
Не подскажите в чем может быть проблема в самих настройках или в прошивке коммутатора.
Заранее ОГРОМНОЕ спасибо!!!!!
СообщениеДобавлено: Ср сен 29, 2010 09:13
Пришлите пожалуйста мне на почту полностью выгруженные конфигурационные файлы.
СообщениеДобавлено: Ср сен 29, 2010 14:46
Конфиги своих устройств Вам на почту выслал!
А вот более точные сообщения которые мне дают D-Link-и при постоянных перезагрузках на экране:
DGS-3100# 01-Jan-2000 01:23:28 %2SWPHY-I-CHNGCOMBOMEDIA: Media changed from copp
er media to fiber media (1000BASE-SX) on port 1:21.
01-Jan-2000 01:23:29 %LINK-I-Up: 1:21
01-Jan-2000 01:23:30 %2SWPHY-I-CHNGCOMBOMEDIA: Media changed from copper media t
o fiber media (1000BASE-SX) on port 1:22.
01-Jan-2000 01:23:30 %LINK-I-Up: 1:22
01-Jan-2000 01:23:33 %TRUNK-I-PORTADDED: Port 1:21 added to ch17
01-Jan-2000 01:23:33 %LINK-I-Up: Vlan 1
01-Jan-2000 01:23:33 %LINK-I-Up: ch17
01-Jan-2000 01:23:33 %SNMP-E-NOMEMFORTRAP1: Not enough space for key of variable
1 of trap 72.
01-Jan-2000 01:23:33 %TRUNK-I-PORTADDED: Port 1:22 added to ch17
1 of trap 72.
01-Jan-2000 01:23:34 %OS-F-BUFFER: OSBUFG_buf_alloc: Buffer pool magic is invali
d
Reporting Task: SNMP.
0x144724
0x141d0c
0x546260
0x37437c
0x3789dc
0x547e90
0x33d904
0x33dc48
0x320788
0x34f8c8
0x351134
0x338ebc
0x4b445c
BOOT Software Version 1.0.1.05 Built 13-Oct-2009 15:37:32
MAC Address : 00:24:01:eb:d7:aa.
100%
100%
OK
Running from RAM...
*** Running SW Ver. 3.60.30 Date 12-Aug-2010 Time 08:50:35 ***
Serial Number : F3DR299000144.
HW version is: a2
Base Mac address is: 00:24:01:eb:d7:aa
01-Jan-2000 01:01:08 %CDB-I-LOADCONFIG: Loading running configuration.
-- Unit Number 1 --
01-Jan-2000 01:01:21 %Entity-I-SEND-ENT-CONF-CHANGE-TRAP: entity configuration c
hange trap.
01-Jan-2000 01:01:34 %INIT-I-InitCompleted: Initialization task is completed
01-Jan-2000 01:01:35 %Environment-I-FAN-STAT-CHNG: FAN# 1 status changed - opera
tional.
01-Jan-2000 01:01:35 %Environment-I-PS-STAT-CHNG: PS# 1 status changed - operati
onal.
Tapi Version: v1.3.3.1
Core Version: v1.3.3.1
01-Jan-2000 01:01:36 %SNMP-I-CDBITEMSNUM: Number of running configuration items
loaded: 36
01-Jan-2000 01:01:36 %SNMP-I-CDBITEMSNUM: Number of startup configuration items
loaded: 36
>01-Jan-2000 01:01:37 %Stack-I-STCK-CFG-CHNG: Configuration changed: chain
lcli
